Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
No suction how goes it.. my hoover windtunner v2 has no suction through the hose.. it does however have suction from the body, but once i put the canister in, it has very little through the hose.. no blockage in any of the parts.. whats up
  • bstu Dec 04, 2008
    I have the same problem. I think the vauum is just a piece of junk. It seems I have to empty the canister and shake off the filter and screen everytime I vauum jujst to get a little suction out of the hose. My beleive is that it's just a poor design. I can't even use the brush rollor for stairs and furniture, even if the canister and filter have just been cleaned. What gives???
  • Anonymous Jan 06, 2009
    R U serious????? Hello, don't you think I checked all the hoses front to back side to side up and down??????? I'm not an idiot!! It has to be something else....please dig further and come back with a more helpful answer for all of us who suffer with the same problem. I am not alone out here. May I suggest you view this same problem all over the internet. Since motors create vacuum through a blower, could there be a problem there? Possibly with the impeller?
  • 57 Answers
Check again for obstructions in the hose. Also underneath where the debri goes when it is being sucked up. Also make sure all your hoses are connected as this could effect the suction.
Posted on Jan 06, 2009
Hoover duros no suction
you must see any clogged from Hose, or nozzles, and clean, or repair.
Will be a good idea tha yur use user manual, or download from the Hoover.com and proceed according.
God bless you
May 27, 2012 | Maytag Hoover Duros S3590 Vacuum...
Light keeps flashing on top of canister of my Hoover Wind Tunnel but I emptied and cleaned it well. It sounds right when I turn it on then it goes into this sound like something is stuck but there...
sounds like a possible plug ,then when you first start it up the plug gets stuck a gain.
try taking hose off the unit and running water through hose .if water flows good ,check and see if lid is secure when closed.
Jul 08, 2011 | Hoover S3765-040 WindTunnel Bagless...
No suction throught the hose
sounds like its blocked stick the broom handle thru it , there might be something plugging the hose under the bottom at the connection
May 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Brushes spin but the dirt does not go into suction hose
Most likely you have a clog. Starting at the brush head check every part of the lines for debris. More than likely YOUR clog is in the hose... easy enough to take a broom handle and gently push it through the hose (while the hose is NOT attached to the vacuum) Once you find the clog, you may have to use a little more pressure, but do so carefully, as you don't want to damage the hose itself.
Jan 19, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover WIndtunner 7600 no suction
According to the manual on your machine, you can either have a broken belt, or the switches to the self-propel switch, and brush switch are in the off position. I have included a link to your manual. Please look at pages 13-14 under troubleshooting.
http://www.hoover.com/pdfs/manuals/U6439900.pdf
I hope this helps.
Jan 18, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suction
absolutely all the air in a vacuum would pass through the filter and if its clogged badly you could loose all your suction and if the belt is more than a year old then replace it even if it isnt broken ( they stretch out over time )
Sep 17, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Stair attachment has weak suction
Did you put the duct in for the hose? It goes in front of the tank, take out the duct (#3)that is there and put in the duct that is on the end of the hose. Is there a slit somewhere in the hose, if so you will loose suction.
Nov 17, 2007 | Hoover F5826-900 SteamVac Upright Wet...
My Hoover is picking dust , very poorly
The Telios has a bad design on the handle and it sounds like something has definately got stuck. Unfortunately the nature of the cheap European design means the handle can only be removed by someone who owns a vice in their garage without breaking the removal points. Alternatively find a long bamboo stick or pole to put inside the hose mount which connects normally from the main bin of the Telios (not the other way around up the handle) which has no sharp edges and push up and down vigourously to dislodge any clogged dirt which may have inadverntely got stuck either by the handle or in the hose itself.
Another thing to do is to check the suction from the Telios itself by removing the hose. If there is suction coming from the main dirt bag/bin door with the hose removed then there is no problem other than a clogged hose and handle. Hoover updated the handle and hose in 1999 and spares can be found by looking on Ebay.co.uk for cheaper prices.
Aug 12, 2007 | Hoover S3330 / S3332 Straight Suction...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
346 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
