Question about HP PSC 1510 All-In-One InkJet Printer
Test Page Printing
Every time I turn the printer on it prints a test page?
  • 2 more comments
  • Anonymous Mar 13, 2014
    HP 1280 Printer printing test page every time I turn it on.
  • Anonymous Mar 17, 2014
    new printer wont all it will print is a test page
    How to print test page with printer only on dx7450
  • Anonymous Mar 20, 2014
    printer autometicaly print test page
  • 624 Answers
Tdragon, Every time you install a new cartridge the printer wants to run an alignment page. If the alignment process is not completed it will print a page every time the printer is turned on. Your manual will describe how to do this procedure; if you don?t have one you can download it here: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=us&docname=c00473778&dlc=en&product=428800&lang=en& Let us know if this helps and please don?t forget to rate this posting.
Posted on Jan 20, 2007
SOURCE:
When printing, it keeps printing the test page first. How can it stop printing the test page??? thx
reset the printer by pressing the reset botton for atleast 5seconds. then it ask for printing the test page.............. and you have to print the test page completely... otherwise it will ask for printing the ttest page at every print......................
then switch off the printer and again on it..........
then you will see th\at the problems will be solved..................
thnx
Jun 22, 2011 | Epson Stylus Pro 4800 InkJet Printer
Prints test copy every time I switch it on.
All right so you are getting print test copy every time you turn on or switch on your printer. You can follow the following steps to fix this issue:-
1.. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place the test page on the scanner glass and press the SCAN button on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages! Yay!
(You may now reconnect the printer to your computer via the USB cable.)
let me know if it fix this issue and helpful to you.
Mar 03, 2011 | HP PSC 1510 All-In-One InkJet Printer
Each time the printer is turned on, it prints the test page
You need to scan the test page in order for the printer to stop printing a test page every time you turn it on.
Sep 24, 2010 | HP PSC 1350v All-In-One InkJet Printer
Stop printing test page
take test page and scan it this will clear it up
Aug 21, 2009 | HP PSC 1410 All-In-One InkJet Printer
Hp C3180 printer prints test page every time i turn it on
You were being cheap when you ran out of ink and replaced only the Black Ink Cartridge.
Replace the Color Cartridge and the test page will stop printing when you turn it on.
Dec 24, 2008 | HP Photosmart C3180 All-In-One InkJet...
Test printing
If you've recently changed your cartridges, the printer will try to print a test/alignment page. Note the instructions on the test page indicate what to do to complete the testing/alignment procedure.
1) Let it print.
2) Place the test page upside down on the scan plate.
3) Hit "Scan" and let it finish.
When the machine completes the scanning procedure, you'll be able to switch the printer on and off or reboot your computer without it printing the test page. By Dubbya
Sep 16, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer printed test page but won't stop printing
Please follow exactly and IN ORDER.
1. Turn off the printer and wait 10 seconds. Turn it on again
Aug 27, 2008 | HP LaserJet 1320 Printer
Canon BJC 4300 InkJet Printer
i assume the cleaning method that you perform is offline (taking the cartridge our and clean them). I suggest you clean the head during the printer on.. try to perform below steps per the manual Cleaning the printer Printing the test pages Cleaning the print head I assume you do not have the manual anymore (no DVD) i list down the step below Its a bit long manual I suggest you download them from the canon website.. if you still have problem I can send to you the BJC 4300 manual Cleanning printer Make sure the printer is turned off before cleaning it. It is a good idea to unplug the AC adapter also. Do not clean the exterior of the printer with volatile liquids such as thinners, benzine, or any spray-type or chemical cleaners; doing so will damage the surface of the printer. When cleaning the printer, avoid the area near the print head on the BJ cartridge. Do not touch the print head. Ink may leak out and cause stains. Clean the printer regularly to avoid printing problems. Remove any ink mist or paper debris from the interior of the printer using a soft cloth moistened with water. Clean especially well around the platen area. If the rollers become dirty, you can clean them using a small soft brush. Clean the exterior of the printer with a soft cloth moistened with water. Clean away smudges and dust. Do not use paper products (such as paper towels or tissues) to clean the inside of the printer. Printing the Test Pages You can print these test pages to check the operation of your printer and your print quality. Test A This test prints a repeating pattern of characters. Demonstration This test prints a sample page describing the printer's features. Printing the Test Page From Windows You use the Test option on the Control tab in your BJC-4300 Printer Driver for Windows to print a self test, demonstration page, or a nozzle test pattern. Before selecting a Test option, make sure paper is properly loaded in the sheet feeder (see Automatically Feeding Paper starting on page 3-7). Click on the Test option and then click on the Print button. Printing the Test Pages Using the Operators Panel To print a test page, make sure the printer is turned off and paper is loaded. Press and hold the POWER button until you hear the number of beeps that correspond to the test page you want to print. Test Page Number of Beeps Pages Printed Demonstration 1 Continuous Printing Status Information 2 1 Page Test A 3 Continuous Printing Nozzle Test 4 1 Page When you release the POWER button, the test page starts to print. *All self-test prints require Letter or A4 size paper. Using a smallersize paper for a self-test print will result in parts of the printoutbeing printed directly on the platen. All self-test prints are printed in accordance with the current printing settings (font, printing mode, etc.) *Red- Information for technician not included in the user manual Cleaning the Print Head Your printer is equipped with a print head cleaning function to ensure constant high quality printing. Cleaning the Print Head From Windows If you are using Windows, you can execute print head cleaning from the Control sheet in the printer driver. Simply click on Clean Ink Head. 4300 Chapter 4 Page 6 Cleaning the Print Head Using the Operators Panel If you want to clean the print head from the operator panel, follow these steps: 1 Make sure the printer is turned on. Make sure the green POWER light is on. 2 Press and hold the RESUME button for at least two seconds until the printer beeps twice. The POWER light will blink for several seconds while the print head is being cleaned. Perform the print head cleaning only when you encounter a print quality problem. Unnecessary and repetitious cleaning will waste ink. If you execute the print head cleaning while paper is manually loaded, the printer will eject the paper and then perform the cleaning. 4300 Chapter 4 Page 7
Aug 24, 2007 | Canon BJC 4300 InkJet Printer
Test page
I had the same problem and being helped by HP operator.
first take the USB cable out of your computer, then put it off and then on again...it starts to print the test page again...then after the printer stops printing, put the just printed testpage face down on the scanner(glas) and press scan manually...after the scanning(you wait till that is finnished) and then put the printer off and on again....then connect the USB cable to the computer and that will stop the printer from printing the testpage every time you startup your printer....
hope it wil solve your problem, it did for me...
Dick van den Broek
The Hague
The Netherlands
Feb 23, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
121 people viewed this question
Clive
Clive
Thomas F. Schneider
