Question about LG Flatron L1710B 17" LCD Monitor
19" Flatron LCD monitor flashing uncontrollably
My Flatron 19" LCD silver monitor is flashing uncontrollably. I tried moving any items away from it that could be magnitized. Monitor is 18 month old. Checked the plug, unplugged and plugged back in. Checked the connection into PC tower. What could I try next. I have no other spare monitor to change it out to test it. Could be Video card? Bad monitor?
Please help, My computer is our work computer...I'm out of business until I get this resolved...that's why the urgency. thanks!!
  • 3940 Answers
SOURCE: No. I recently bought from Circuit City (because
Here is a link to the user's guide
http://www.abt.com/images/products/PDF_Files/w2252tqtf_manual.pdf
Posted on Feb 24, 2009
tomhar
  • 20 Answers
SOURCE: How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Posted on Mar 08, 2009
  • 67 Answers
SOURCE: L1932TQ LCD Monitor won't turn on.
Try a cold reset for the computer by unpluging the power cord from the computer it's self then plug it back in if that doesn't work your monitor may have died
Posted on Jun 03, 2009
oldrogers
  • 53 Answers
SOURCE: why does my LG flatron 1953T LCD monitor (19') goes white
Because the fuse on scaler PCB is blown. Open the monitor, open metal cover, disconnect all cables coming between display and boards, take the chassis off the display.
On back side of display you will see metal cover, mounted with tiny screws, take them off. Unscrew the board also and carefully tilt it up. Observe tiny chip fuse (referenced F1 or FU1 or something with "F") somewhere nearby the connector, ring it, replace it with solder drop.
Take everything back together.
Posted on Sep 11, 2009
cinek79
  • 320 Answers
SOURCE: LG Flatron L2010P monitor. Says no input signal
Hi here you've got drivers for your monitor if you not instaled them allready http://devdrivers.net/Drivers/Download-4789/LG%20Monitors-Driver/ ( you need download drivers for analog and/ or digital connection depence witch you are use). After instalation reboot you pc and then check settings in your graphic card. Look for dual display or something similar. If you still have problem with it let me know. If it help please rate it. Regards
Posted on Oct 29, 2010
Testimonial: "Thanks cinek79, I'll try that now!"
LG HDTV Monitor Permenantly switched on but no display white screen with V.2.0.0 moving around the screen
sounds like you are possibly over resolution (setting resolution higher than the monitor can show. Try setting to low resolution and see if it shows up. Try VGA first and move up if it shows.
Jun 21, 2014 | LG Flatron N1910lzbf 19 Led Lcd Monitor 43...
LG Flatron L1710M (Silver) 17"
its better take it to the service center if it is under warranty or take it to some technician the fault is in the circuits
Jul 27, 2011 | LG Flatron L1710M 17" LCD Monitor
Flatron LCD Montor to a Dell Dimension XPS T500
> out of date?
Are you sure that it is "out of DATE" ???
Reconnect your old monitor.
Set the screen-resolution to 800-by-600 at 60 Hertz.
Shutdown.
Connect the new monitor.
Reboot.
The new monitor will be detected, and will run at 800 by 600 at 60 Hertz.
Change the screen-resolution to some higher value that both the new monitor, and your older video-card, will allow.
Jan 02, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
Lg Flatron W1934S Moniter Problems
You could have a faulty inverter board or a faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp and the CCFL lamp is a mini fluro tube.
Have a look at LCD Patrs WEB site for service, parts and DIY info Use this link to their WEB site :-
www.lcdparts.net
Oct 02, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Why does my LG flatron 1953T LCD monitor (19') goes white
Sep 11, 2009 | LG Flatron L1750S 17" LCD Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
MICROTEK 19 "C783
19" LCD comes on and goes out right away
Sep 06, 2008 | HP vs19 (Silver) 19" LCD Monitor
LG Flatron L1550S power light blinks green.
shorted components on the circuit. send it to a repair shop if you don't have experience on electronic troubleshooting!!!
Nov 27, 2007 | LG Flatron 995FT 19" CRT Monitor
LG Flatron L1710B 17" LCD Monitor Logo
60 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
