Question about Singer 1725
Singer 1725 I just handed down my Singer 1725 and it worked fine for one seam and her tests and getting used to it. It slowed down and then came to a stop. She has pulled all the thread out of it but it is still really hard to manually turn, and won't turn turn at all when she pushes on the foot pedal,
  • 27 Answers
The hook drive gear is seized and requires lubricant ,this is the gear right behind your bobbin case I believe you can access it from the rear ,I hope this helps
Posted on Jan 10, 2009
I NEED A SINGER MODEL 1725 MANUAL
Posted on Jun 14, 2009
Free manual for a singer sewing machine 1725
perhaps from singer ,,if your try Google use make model and manual
Oct 09, 2015 | Singer 1725
Sewing slows after use
The manual: http://www.singerco.com/uploads/download/446_5040_5050.pdf
Jan 08, 2012 | Singer 5050 Mechanical Sewing Machine
I am doing some sashes for a wedding and i want to know on my serger 14SH654 ultralock how to do a rolled hem
A rolled hem on any overlocker is formed by using the right hand needle only, and the two loopers to form a narrow three thread seam. You also need to retract the seam width finger as Trial2962 said. This is a little finger that sits on the stitching plate and the loopers form the stitching over it. By retracting it, the looper threads can form a narrow seam and in fact, roll the fabric inside the seam. You need to move the cutting blade as far right as it will go so you are trimming as wide as possible from the needle, turn the tension on the top looper rigth down to 2 so it is very loose and this thread wraps around to the underside. And tighten the lower looper tension to about 7 so it hardly shows and sits right up against the needle thread. Adjust and test until you get the seam looking like this, then turn the stitch length dial (on the right side by flywheel) down to 0.5 to close the seam right up tight. Lastly, if you can source it in the right colour, buy woolly overlock thread and run this through the upper looper only, this thread is fluffy and when not under tension, relaxes and "fills" out so the seam appears like a continuous coverage over the fabric.
You will need to practice a few runs and go slowly on corners, a curve is obviously much easier to serge than a right hand cover so if you can, cut the fabric with curved ends, much easier to get a great finish. When you chain off at the end, you need to unravel the tail threads and pull them inside the seam for a few mm with a needle to get a smooth finish, then trim the tail and seal with a drop of Fray Stop.9_26_2011_11_26_51_pm.jpg
Sep 04, 2011 | Singer 14SH654
My singer touch & sew suddenly didn't stop
There might be something jamming the petal open so it won't slow or stop when you put your foot on it.. I would try that, get some canned air and blow it out and see if it helps.
Apr 28, 2009 | Singer 1120 Mechanical Sewing Machine
Looping of stitching on the reverse of the material.
put the tension to about 4 and make sure it is threaded in a N shape and remember the thread catcher above the needle from the bobbin to left down round tension up to arm down the side.
Mar 26, 2009 | Singer 1725
Singer merritt 8834 sewing machine slows then stops
Did you ever get your sewing machine to speed back up...mine does the same thing Singer Quantaum 5430, runs great for about one minute and then so slow I can't run it any longer
Jul 26, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 1725 Logo
314 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
