Question about Panasonic TH-42PZ700U 42 in. Plasma Television
Scratch big scratch in my screen done with a fork
    Novelist:
  • 152 Answers
Hello, if there is a scratch on your reflective outer glass panel screen, it can be replaced if you are handy with tools or diy i happen to have the screen removal manual for this tv model th42pz700u you dont have to dissasemble the tv just the outer front housing remove the back panel and theres some screws that hold the front casing on those come of and the front refelctive glass can be removed without any trouble or dissasembly of the internals just the front casing
you may need to find a selling as is plasma tv with a broken internal screen usually they are this way that outer screen dosent break easily so unless you want to pay 489 for this reflective glass part i would try and find a 'for parts or repair 42 inch pany' they will fit if they are the same size make sure the outer screen is not broken or scratched. hope this help
Posted on Dec 09, 2008
93 virago 750 fork seal repacement i need pics to follow so i can relace them myself
remove fork from bike remove dust cap,remove circlip with flat screwdriver,prize the oil seal out with pointed driver,do not scratch the chrome stanchion,slide seal off the fork,oil the fork then slide new seal onto fork, tape the top of fork to protect seal,it saves dismantling the forks and time.
Oct 16, 2014 | Motorcycles
I hit a medium size bump and hear a clanking noise in the forks
Well, this is not unusual, especially on the Fat Boy or the dressers. You've got a lot of stuff up there that will rattle if you hit a big enough bump.
It could be being caused by either too stiff of a fork assembly or too soft in the case of it bottoming out. Bottoming out is a dangerous situation. The way you change the "stiffness" of the front end is by change the viscosity of the fork oil. Most Harleys use "H-D type E" fork oil that is stated by most websites as being close to 30 weight. A 20 weight oil would make the forks "softer" while a heavier weight oil would make them "stiffer".
On dirt bikes, I've drilled additional holes in the damper rods inside the forks to give them quicker action and more bump dampening but I've never done it on a Big Harley.
Good Luck
steve
Sep 23, 2010 | Harley Davidson FXDWG Dyna Wide Glide...
What, and how do I need to know about adding 2 and1/2 inch spacer kit to the front shock/cil spring system on a 1500 GMC 2 wd?
The kit will come with fair instructions,you might want to pick up a shop manual though.You're going to be removing parts that affect your alignment,so if the inst. say anything about turning the tie rod ends mark the thread location first.(scratch a line on the thread and bushing like you would removing a distributor).
You also need a balljoint fork and a spring compressor,plua a floor jack and good quality sockets and wrenches.You also will probably need a spindle nut socket that fits your model.And unfortunately,and impact wrench and compressor would be a big help.
It might add up to being cheaper to have it done.
Bob
Aug 10, 2010 | GMC Sierra 1500 Cars & Trucks
I have changed the forkseal on my zxr750 j model 3 times and it is still leaking.I am thinking I will need new forks but am having trouble finding them. Can I use zxr750 l model forks on my j model bike?
Hello first things first are your fork tubes inner scratched or dented?
If not take it to a motorcycle mechanic and have them inspected let the mechanic install a new set if finds there are no damage to the inner fork tubes or dee scratches to the outer fork tubes inner sealing area some times people use a screw driver to pry out the old seal and do not pay attention that they gouged a grove on the inner part sealing area.
May 01, 2010 | 1991 kawasaki ZXR 750
Changing oil in forks
when your changing the oil in the front forks you want all the weight off the front end from there you will take out the bolts on the bottom and let it drain what ever you do do not let the front wheel hit the ground. once it is all done draining put the bolts back in and go to the top of the forks there will be a big bolt that you take out in which thats where you put ur fluid in!
Mar 17, 2010 | 1983 Honda XL 125 R
What special tools are needed to replace the fork seals
Seal drivers are the big one, and they need to be sized specifically for your forks. Then the new oil has to be measured in either CC's or millimeters. Unless you have done these, or have worked with someone, I wouldn't recommend doing them, especially without the shop manual.
Nov 25, 2009 | Suzuki RM 125 Motorcycles
What oil and amount of oil suits the 1050 forks
its not that simple !
you need special tools & specific oil & measurements
Just get it done at the workshop as the damge you could do is BIG $$$$$
Jul 18, 2009 | 2007 Triumph Sprint ST
Will 1098 forks fit 996
will the 1098 Showa forks fit a 996 have done a search but haven't found much. I know they will fit in the standard 996 triple clamps but will my standard 996 wheel and brake rotors fit or will i need different offset rotors?The 1098 forks are actually pretty much the same as the xx9 forks. The xx8 bikes use a different diameter upper fork tube, so it won't just fit in. I think the xx8 is 53mm top and 54mm bottom and the 848/1098 is 54mm all the way through. So you'd have to change the triples, which isn't a big deal, you should be able to fit a xx9 triple on there. Even after that, they are radial mounts and you'd have to get a different set of rotors and calipers. Its not a big deal to do any of this... If you want a better front end on your 996, I highly suggest re-building the stock showa's with ohlins inserts. If you want better braking, buy a set of the older gold series 4pod/pad calipers, they work fantastic and mount to all the older forks. Radial mounts are a gimmick and a rebuilt fork is always gonna be better then a stock one...,,,
Nov 10, 2008 | 2001 Ducati 996
Fork seals
ZERO air pressure on these forks those air valves are to get rid of any built up pressure in the tubes. I also have a 1990 851 love it! What weight of oil are you running and how much are you putting in?,,
Nov 10, 2008 | 1988 Ducati 851 Strada (Tricolore)
Scratches on the tv screen
you can purchase a big screen -- screen cleaner from most Tv retail stores in your area.If scratches arent removed than they are permanent.
Sep 08, 2008 | Televison & Video
Panasonic TH-42PZ700U 42 in. Plasma Television Logo
350 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
