Question about Pentax ME Super 35mm SLR Camera
How to open Top-plate of Pentax MG
My Pentax MG has not used for many years. I tried to checked for its functionality and work just fine, but I saw strange object in the viewfinder. It's like drop off a piece of metal-plate. I tried to find a service shop how can repair here but come out w no result.
So, the only way is DIY, but how to open the top plate ? Many thanks for the advice.
    Scholar:
  • 58 Answers
Sounds like the pressure plate for the viewfinder lens has dropped in front of the lens. If the viewfinder surround is craked this is very likley.
To learn how to remove the top of these cameras and other Pentax's there is a camera repair website where you are shown how to do this. Just click the link.
Posted on Jan 21, 2009
    Scholar:
  • 185 Answers
Dust speck on fresnel lens, has no effect on print quality. But it is annoying. You can get a can of compressed air at any photo shop and try to blow it out of the way, just be VERY careful you don't hit the shutter blades. Point the air only in the front by the lens mount.
Posted on Dec 07, 2008
How do I remove the focusing screen from a pentax mg camera
Thereis a little clip that holds focus screen up in mirror box. You need to use tweezers to release and pull screen. Keep dustless or youll see it all. Katzeye?
Sep 02, 2015 | Pentax Cameras
My saw won't run when I press the switch trigger.
First, check the outlet it's plugged into.
Power cords can go open, try holding the trigger (careful), and bend the power cord near the plug, and near the saw.
Trigger switches can go out.
saw motors can go out.
Jun 08, 2015 | Ryobi 10 In Miter Saw With Laser
DeWalt 742 Flip over bench/chop saw. 110v. Approx 7 years old, and used infrequently. The saw tries to start and momentarily spins for a second or two. Then it seems to trip out 'internally', and if...
The motor or brushes are burn by symptoms you refer.If you can,try to open the saw case and look inside.At the motor check for the cooper wires and the brushes if there some "carbon like burn".
Nov 10, 2010 | Saws
Makita LS1030 miter saw, base doesn't rotate as freely as it should
dust and debris get under the plate; remove the fence from the base and the lock mechanism from the plate; flip saw over and remove the retaining nut from the spindle, the base should pull easily away from the plate.thoroughly clean the bottom of the plate and the top of the base and check for/remove any imperfections in either with emory cloth. use a mineral oil based lubricant when reassembling and be careful not to overtighten the retaining nut.blow out the base after use with an air gun and lube lightly after each day's use to avoid this in the future
Nov 18, 2009 | Makita 10" Miter Saw LS1030N
I just fixed a me super but the frame counter doesn t reset when the 36st is reached or when I attempt to open the camera. HOW DO I RESET IT without openning it?
By opening, do you mean the back cover or the top cover?
after rewinding the film opening the back door will reset the counter. if it does not reset, try firing the shutter with the back door opened a few times. this counter is mostly plastic.
with the back door opened try taping the top cover over the counter to free the counter gear.
if it still wont reset the top cover will have to be removed and the counter repaired.
there are no new parts available for this model Pentax so a good used counter could be expensive.
if you take the top cover off, usually the pointer plate on the right side of the counter is rubbing on the counter preventing it from resetting.
Oct 15, 2009 | Pentax ME Super 35mm SLR Camera
Flash stops working
The flash bulb may be broken. Try contacting Pentax to get it fixed.
Jul 15, 2009 | Pentax Optio T10 Digital Camera
SD memory prohibits functioning of Pentax E30
I know that usually, you should format the card for the camera that your going to use. Try formating it in the camera and see if that works. Let me know if I can do anything else for you,
Rob
Feb 22, 2009 | Pentax Optio E30 Digital Camera
Pentax ME shutter triggered just from advancing film
miraje,
the shutter locking lever is sticking. time for a clean, lube & adjust.
i would take, or send this fine rugged camera to a reputable camera repair shop, have an estimate for a cla.
This model pentax is made with very little plastic and will last a long time with an occasional cla.
Apr 02, 2008 | Pentax ME Super 35mm SLR Camera
Optio 33WR Sluggish Buttons
I had the 33WR last year, and opened it up. My subjective opinion is that it cannot withstand the pressure underwater. Someone tried it and water got in.
Sep 08, 2005 | Pentax Optio 33WR Digital Camera
Pentax ME Super 35mm SLR Camera Logo
381 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
