Question about E-Machines eMachines Desktop PC
EMachines T6528 desktop will not boot up
My eMachines desktop power turns on but the hard drive does not boot. The yellow hard drive indicator light comes on when I first turn press the on-off button but no other lights as it used to when the hard drive engaged in the past. I cannot get the CD ROM to read a recovery CD. When I power on the computer, all that happens is the fan engages and continues to run. I can power down the computer from the on-off button. The monitor does not turn on when I turn on the computer but it does work - I connected it to my laptop to verify.
  • harldavi Feb 20, 2009
    I have the same computer with the same exact symptoms. Did you have any luck so far resolving the problems?
    I Have the same computer with the same problems. It doesnt appear to be a failure of the power supply as all the LED's and various fans powered both direct and through the MB all appear to be working fine. Other than that though the PC shows no signs of life. It will not prompt a display nor does it appear to be running any kind of POST upon power up.
  • E-Machines Master
  • 5,568 Answers
The power supply fan runs from either 5V or 12 so that only tells you that the voltage for fan operation is present.
If you don't have a multimeter already, I would highly advise that you buy one. They are available for <$20 US at auto parts stores and electronic outlets. If you have one, remove the couple of screws that hold on the side panel that will let you access the guts. For an initial check, turn the power off and if your cables are long enough, don't bother to disconnect anything since changing the load on the supply might make it appear OK again. Turn it back on once you have it in position and are not moving it anymore.
Locate the main connector from PS to the mother board, insert the negative probe into any connector hole with a black wire.
All supplies will have 5V, +-12V (these are the primary voltages used by many devices) and you will find (probably) -5 and some that seem stable but undefined which are used for monitoring supply health.
Many supplies have the voltages listed on a label which often will tell you the orientation (location) of the various voltages.
I think you have a supply dying but you need to measure its outputs before assuming I'm right - been wrong before.
While you have the case open, but power off, clean out the dust bunnies you'll find using a clean paintbrush that has been dampened and made nearly dry again or buy a 'can of air' to blow them out. I recommend against vacuuming due to the horrendous static charge they can build and this is death to most semiconductors.
If you have established that the supply is failed or failing, you can buy a new one (don't repair) for about 20% of the cost of the parts inside - yeah, it's nuts. Your system will probably use the ATX form factor (so it fits mechanically) and any of these will have the basic connectors but examine the pictures and compare them to yours to be sure that some non-standard connectors your system might have are present on  the new one. If your supply says 350 watts, add another 50 or 100 watts to the replacement; it won't cost much more but will let the supply run with less stress.
If you feel the need, you might want to label stuff before you disconnect things if you haven't done it before but the connectors are made so you can't screw up without trying real hard.
Posted on Nov 29, 2008
  • Steve Allison
    Steve Allison Nov 30, 2008
    Should have mentioned this before; the supplies can be had sometimes for $10 from a number of eBay stores (I once paid more for the shipping than the supply) so I would be reluctant to buy from a repair shop or local store; their markup can be horrendous.
    I was in the business for years, knowing what the things cost so I was really annoyed when I wanted to buy one from a service company near home and was quoted $50 for a (then) $5 supply.
    Scholar:
  • 172 Answers
You have a blown motherboard. The fact that the fan runs and there is no monitor and the orange light remains on standby are all classic symptoms of the failure of the processor socket. There are capacitors along one side of the processor socket which form part of the function of the processor socket. When these fail, the processor socket fails too. In addition to this the pc's power supply often fails because the feed to the processor is the small square plug beside it, with 2 x yellow and 2 x black cables. On this basi some items within the pc can be heard running whilst others are not.
Replacing the power supply and the motherboard ALWAYS sorts this problem out. My experience with these Emachines and similar computers sold throught the same retailer networks, including model such as Medion,Advent,Packard Bell,Compaq Ei Systems to name but a few all suffer with the same problem.
Posted on Nov 30, 2008
I want upgrade my emachines t6528 hard drive and ram.i need help
Memory Upgrade for eMachines eMachines T6528 Computer, the eMachines eMachines T6528 Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T6528 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
As for the Hard Disc.... the following address will give step by step instructions on installing a new HD. http://www.manualowl.com/m/eMachines/T6528/Manual/
Thank You for using FixYa
Tom Miller
KD4DTK
Aug 19, 2012 | E-Machines T6528 PC Desktop
T6528
See http://www.manualowl.com/m/eMachines/T6528/Manual/119527 which is the manual for your eMachines T6528 system and has information on replacing hardware components including disk drives.
Dec 31, 2011 | eMachines T Computers & Internet
How do to change the boot order in a emachine t6528
When the machine are start to boot press F2 before start windows, That is the setup of the Bios and there you can change the boot order
Dec 29, 2010 | E-Machines T6528 PC Desktop
T6528 has no video. Using a working monitor, tried differnet video cards but still no video.
1) So you tested the monitor on a working computer? Reason I ask, is that you will be testing the monitor cable also.
If it is a monitor with a detachable monitor cable, suggest you test the cable also.
2) Each graphics (Video) adapter card has it's own specific driver.
The driver should be installed Before, the graphics card is installed.
Otherwise Windows will 'break it's neck', to find a compatible driver, from it's thousands of generic drivers.
Won't do. You will get a driver conflict.
Windows: 'Which driver do I use? These or THESE?"
Kinda' hard to do, since you can't see graphics on the monitor.
I would like to suggest you diagnose the Power Supply to start with. (After checking the monitor cable)
It may seem that the Power Supply is okay, but it could have a weak Voltage power rail.
Enough power to light LED lights, and spin fan's, but not enough power to turn the Processor on.
1) ALL the LED's use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor can use 51 to 125 Watts.
(Lower for older Processors)
The eMachines T6528 comes with an AMD Athlon 64 3500+, processor, that fits in a Socket 939 processor socket,
1) eMachines Support > T6528 > Specifications,
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T6528
2) Information on the AMD Athlon 64 3500+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#Athlon_64
Can use up to 67 Watts, or up to 89 Watts. Depends on what Core it is.
(Clawhammer Core, Newcastle Core, Winchester Core, Venice Core, Manchester Core, or San Diego Core)
(Also uses an MSI K8NGM-L motherboard. Below for specifications only,
http://www.newegg.com/product/product.aspx?Item=N82E16813130041 )
A) Not to down eMachines, (I have an old T1090 in my shop that works great), but they are budget computers, and use budget parts.
One being the generic Power Supply that is used.
B) The computer could be dirty inside, as well as inside the Power Supply.
The cooling components for the SMPS, (Switched-Mode Power Supply,) are it's Fan, and Heatsink's used inside.
Once a layer of 'Gunk' covers these cooling components, the cooling capacity drops tremendously.
Heat = Wasted Energy
The more heat, the more the Power Supply strains to keep up with the call for power.
Eventually hardware components inside the Power Supply fail, and the Power Supply is toast.
You can test the Power Supply voltages.
You can use a multimeter if available, or an economical unit can be purchased for around $5 to $12, that will suffice for testing.
You can also use a power supply tester.
One example:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471
Voltages produced by the SMPS used in a T6528 are,
A) 3.3 Volts (DC)
B) 5 Volts (DC)
C) 12 Volts (DC)
Testing should be done on the 12 Volt power rail.
11 to 13 Volts indicates a good Power Supply.
Less than 11 Volts means it's time to replace.
Orange wires are 3.3 Volts
Red wires are 5 Volts
Yellow wires are 12 Volts.
All the color coded Voltage wires, lead back to one individual power rail, for each Voltage produced by the Power Supply.
You can test any Yellow wire to test the 12 Volt power rail.
With a multimeter, the Positive (Red) probe lead connects to the power wire to be tested.
The Negative (Black) lead connects to ANY Ground wire.
ALL Black wires are Ground wires.
They all go back to one central Ground source inside the Power Supply.
[Power Supply unplugged from power before attaching probe leads. After connecting, the power supply is plugged back into power, and the Power On button is pushed ]
(Two C cell flashlight batteries produce 3 Volts DC)
Jun 20, 2010 | E-Machines T6528 PC Desktop
We have an emachines T2596. The hard drive indicator light shines yellow. The computer will not turn on when you press the power button. What is the problem? How do we get the light to go out if we...
not really sure what it is you are asking but i had a e machine that every time there was a power outage yellow lights came on an some times i was unable to turn the puter on so i unplugged it from the wall an waited 20 min or so then plugged it back in an it worked..
May 01, 2010 | E-Machines eMachines Desktop PC
When I power on my eMachines C2480, I do not get any video output. I never see the BIOS menu indication. I see the hard disk indicator flash yellow and then go dark. I have tried to boot from CD without...
Try all the normal stuff be sure the monitor is turned on, check the cable in the rear of the computer be sure it is plugged in good. Check the contrast be sure it is not down all the way. Hook it up to another computer or unplug it from the computer it should have a no signal notice showing.
Feb 23, 2010 | E-Machines C2480 PC Desktop
When I turn it on, only the fans run. I cannot hear the hard drive run and the hard drive light on the bezel is solid yellow
look on bios to see if detects the hard drive ...if does not boot to windows...the hard disk has no reason to go on ....and the issues could be many ....check the Ram memory if do not appear anything on screen at all ...and just runs the coolers and clicks without boot at all...in this case its the Ram memory ...so check it ...get it out ..put it back ...and remove the bios battery to force it see them again .....if it is booting until the operating system should appear ...and after that nothing ...reinstall ...
Also .....if there is anything written on the screen ..read carefully ..usually it will say whats wrong ...and advise in same issues..like replace hdd ...or files missing ...or blue screen error from memory issues..
Nov 07, 2009 | E-Machines T6216 (827103077834) PC Desktop
Cant boot my emachine 2984
Did you check the CMOS battery and the CPU fan. Those are two things that if aren't working the way they should be, then some computers will not boot up. Try this first then post a response if you still can't get it working.
Sep 01, 2009 | E-Machines eMachines Refurbished EMA...
Is there a space for a second hard drive in emachines T6528
you should have no problem in putting another hdd in to the case you should have space
May 17, 2009 | E-Machines T6528 PC Desktop
E-Machines eMachines Desktop PC Logo
1,404 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
