Question about Pioneer DV-606D DVD Player
Optical Audio output from My DVD player
DVD player: Pioneer DV-606D Receiver: Yamaha HTR 6090 Problem; When connecting my DVD player through the optical output, there is no sound coming out either through PCM or DTS output. Any suggestions?
Panasonic TV, TC-P50S2.Yamaha DVD Player DV-C6280.Yamaha Receiver HTR-5450.DVD audio working fine thru receiver. Not sure where to place white/yellow cords to get video feed.
Hello. Usually when you mention white and yellow, there should be a red also, the red and white are right and left audio and the yellow is the video. The audio should be connected to the receiver, and if the receiver has video inputs and outputs, that should be connected to the same receiver input as well, but if the receiver doesn't have video capability, the yellow should be connected to the TV video input. I hope that helps.
Aug 01, 2016 | Panasonic Televison & Video
How to connect bose 901 to yamaha htr -6090
Sorry, it doesnt look like you can hook up an external EQ while still using the amplifier section of the yamaha. Instead, You would have to use the preamp out to go to 901 EQ, out of the EQ into another stereo amplifier, then to the 901 speakers. Personally, to power the 901's properly, I'd use another external amplifier. You will barley get 35 watts per channel out of the receiver to power the 901's
Oct 07, 2014 | Yamaha HTR-6090 Receiver
I have a yamaha receiver with HDMI outputs for direct tv, and a DVD player. How do I hook up the direct tv, HD DVD, and yamaha receiver? Where do the inputs go?
Does the Yamaha have HDMI inputs? Usually you would connect the directv and dvd player via individual HDMI cables to the Yamaha (input)and then the Yamaha (output) to your TV also via HDMI.
Dec 21, 2009 | Yamaha HTR-5640 Receiver
Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
I'm trying to hook up my Acer Aspire x1700 to a Yamaha HTR - 6130 AV Receiver using the Optical digital audio cable plug. Not getting any sound, not sure what source to set on the receiver.. talks about...
You can set the receiver to any source that uses a optical connection. Then make sure that whatever you select whether it be CD/DVD you also have the source connection set to optical too on the receiver setup menu.
That being said, after that is done you will need to set up the computer to output audio. That usually just involves changing the output mode on the computer and adjusting the levels...open the Acer audio managment application, choose the audio output mode to stereo or dolby digital and turn everything up on the computers level controls. Then, when you open whatever software you're going to use to play your discs you may also have to adjust the volume level there as well.
Apr 30, 2009 | Yamaha HTR-6130 Receiver
How do i hook up my pioneer dv 333 dvd player
hook up to your receiver or ampli? your DV has got dscrete audio channel connections, now check first your receiver or amp if it has got that same discrete connections. but the simpliets connectgion is just uise your right/left channels. color red/white audio out of your DV. then connect to your receiver/amp DV input. or your DV should also have an fiber optical out (single link only to your amp) if it has got an option for optical. then connect your DV video out to your TV or through your receiver if it has got a video input function.
May 03, 2008 | Televison & Video
Setup
dvd and dish tv optical inputs from both dvd and tv if tv has opticl out or give optical out from hd receiver. or rc pins from hd or tv to dtv/cable input of yamaha
Jan 02, 2008 | Yamaha HTR-5830 Receiver
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Yamaha HTR-6090: fire hazard?
I would check your Outlets to make sure you have Clean Power and are Properly Grounded. That's usually an Electrical Problem, Not the Equipment. Although Sometimes you get Bad Apple!
Dec 24, 2007 | Yamaha HTR-6090 Receiver
Pioneer DV-606D DVD Player Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
