Question about Frigidaire FMV156EM Microwave Oven
Frig FNV156DCC Microwave
How do you get the front panel off to get to the door switches. It has a stainless cover over the control panel, but I cannot find any screws
  • retread2006 Dec 02, 2008
    I checked all three switches. The Monitor Switch checeked OK. The top switch OK. The bottom switch did not react either way, open or closed. I am trying to find this Omron Switch around Indianapolis.
    Thanks !!
  • Anonymous Mar 02, 2009
    I have the same problem, I believe the switches are
    ok, I noticed that the door is not aligned properly, it
    drops down, when I push upward on it it appears to operate fine.
Take the case off to axcess front pannel switches and door switches..THis should only be done buy a quilified repair tech tho..
Posted on Nov 30, 2008
My microwave oven will not turn on.
touch panels do go faulty. Claim on the warranty.
Jun 19, 2016 | Sharp R-331ZS Stainless Steel Mid-Size...
Frig.Model FMV157GS: When door is closed it is heating without lite on or turntable rotating. If time is entered with the door open it then heats as normal when the door is closed. Thanks, Jim
Good Morning Jim Cole, thank you for your post!
From what you are describing it sounds like it could be an issue within your control panel or door switch. I would recommend having a technician out to properly diagnose your Frigidaire microwave to avoid any unnecessary part purchases. I hope this is helpful. -Matt
Sep 24, 2014 | Microwave Ovens
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
Door switch not making reliable contact, is there a door adjustment procedure? Panasonic NNCS597 steam microwave
If you take off the cover panel, you can see the microswitch and its adjustment slot on the control panel side. This can be adjusted to operate correctly.
Apr 05, 2011 | Panasonic NNCS596S Microwave Oven
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
In order to start the microwave i have to push the door
The door switch is loose or fualty you can adjust the switches first to see if it hase just moved if this does not work then replace it.unplug the unit and remove the cover panel look between the controll panel and the cavity on the back of the front panell you will see two or three switches the (GREY or BLACK ) look for the retaining screw loosen slightly and adjust if this does not work the take notes of the wire positions etc on the switch get a new on eand replace close unit plug and play
Dec 29, 2009 | Whirlpool GT4175SPS Stainless Steel 1200...
I have a Fridgidaire FNV156DCC Light and timer work
check fuse inside inline with black wire and micro switches on door locks
thumbs up
Aug 17, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Changed one of the door switches on my microwave now no power
check the green ground ground cable on the control panel
Aug 05, 2009 | Frigidaire FMV156DC Microwave Oven
Aplliance fronts in stainless steel
I'm not sure about some of those appliances but ApplianceArt.com maybe able to help you. They sell stainless panels as well as the Softmetal adhesive stainless that's been on HGTV's "I Want that," "Design on a Dime," and "Real Estate Intervention." And I think some others.
May 08, 2009 | Maytag MMV4205 Microwave Oven
Keypad doesn't work
check control panel and clean the control circuit, any moisture is there clean the circuit. any dry solder is there check overall circuit and confor it ...door switches and sensors
Oct 26, 2007 | Emerson MW8779W Microwave Oven
Frigidaire FMV156EM Microwave Oven Logo
159 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
