Belkin Router
Problem for Belkin (F5D5231-4) Router
Router does not connect
By rileyr on Nov 29, 2008
router does not connect
Same Problem
Dec 02, 2008
-   I HAVE PLUGGED THE ROUTER BUT POWER IS NOT ON AT ALL
-   ags93
Solution #1
posted on Jul 10, 2009
Not Rated)
aamir786k
Rank: Wiz
Rating: 82%, 64 votes
If there is no Light on Router Try other Power Socket. If still its same then Try Doing Hard Reset of the Router .......
How to Do it :
Check at the back of the router if you have any pin hole or a Reset button. Press in that pin hole with some pointed object contineously for 5 - 10 sec. unless the router gets restarted. (At the time of reset make sure that the power is on and the router is connected to the power socket.) If still problem persists then the router is Faulty. :)
Was this helpful?
Yes
No
Solution #2
posted on May 04, 2009
Not Rated)
palaboy
Rank: Wiz  Belkin Expert
Rating: 83%, 1256 votes
try typing 192.168.2.1 if you can access it, from there log in presto you have the configuration you can change it the way you want it
Comments:
May 04, 2009
- to the internet? try connecting the modem direct to your pc if it can then insert the router
Was this helpful?
Yes
No
Solution #3
posted on Mar 09, 2009
Not Rated)
lalaro_me
Rank: Wiz
Rating: 81%, 72 votes
Check the network connection (make sure that the modem is connected to the Internet / WAN port, then the computer to LAN port 1)
Try to access the configuration page of your router and reconfigure the settings.
Note: double the Internet connection from your Internet service provider.
Comments:
Mar 09, 2009
- Check the network connection (make sure that the modem is connected to the Internet / WAN port, then the computer to LAN port 1)
Was this helpful?
Yes
No
Popular Solutions for Belkin Router
Questions and Unsolved Problems for Belkin Router
Do you recommend Belkin (F5D5231-4) Router?
Answer
Answer
hi i cannot connect to my isp , the wireless works. I am able to run 2 other computers OK , but... (More)
Answer
Belkin N router model F5D8236-4 V3 causes motorola modem to fault out requiring reset from ISP. The... (More)
Answer
I lost the power adaptor cord and need another one. Does the voltage and amps have to match exactly... (More)
Answer
Have a belkin router model # f5d7230-4 . Power went off at my house and when it came back on my ps3... (More)
Answer
I have a belkin adsl g router model f5d7633-4 will this support voip and g729 codec
Describe your Routers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Router Experts
Top Computer & Laptop Repairmen
in , PA
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
