Question about Compaq Presario 5000 PC Desktop
Pc dvd tray don't open
It makes a funny noise wen't the ligth blink and them it stop
  • ponores008 Nov 29, 2008
    is not the answer, please get a better solution for this problem..
  • 3 Answers
It sounds like the drive mechanism in the DVD drive has either broken or the drive gear is out of sync with the drive bar. Can you open the drive by inserting a paper-clip into the hole in front of the drive? If you can, look under the tray and you will see the drive bar, a piece of straight plastic with teeth on one side. This connects to the drive gear, which pushes the tray in and pulls it in when the button is pressed on the front of the drive.
Pull the tray in and out a few times and see if it re-engages. If it does not, you cannot open the drive to correct this so you will have to replace the drive.
Posted on Nov 30, 2008
  • Compaq Master
  • 4,338 Answers
The cd you out in it may be un-readable. If it does it on many cds, then your drive is bad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 29, 2008
Dvd door won t open
Remove the unit and open it up to remove disk and examine the tray drive.
Jun 19, 2017 | Curtis Audio Players & Recorders
Have a panosonic dmr-ez485v dvd recorder that cycles 5/6x when tray is closed with/without a dvd, and get "no read' message.
1.The DVD Drive makes two-three times noise than stop spin the media CD
or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray,
close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Feb 01, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Hi my problem is with the dvd tray it does not open . it make a funny noise but it does not open thx
OK I fixed it. One of the CD's had gotten stuck between trays in the loader. I pulled out a few CD's by forcing open the trays gently. However even after removing as many cd's as possible one was still stuck. 1. Remove screws holding cover plate on in back and sides. 2. Remove cover. 3. Lift face plate latches and lift over top of unit. Remove serial cables from connectors on board. Take face plate and place aside. Remove screws from back of CD tray unit and bend back metal tab with flathead screwdriver. Lift CD unit up on one side so you can get your fingers up inside underneath and push stuck cd towards tray openings. You can gently force top few trays out. You may need to shake unit so that stuck cd reaches open end. Pull out CD. 4. Replace faceplate and connect serial cables. Plug in power cord, power on unit and make sure trays will eject normally. 5. Put it all back together!
Jan 31, 2011 | Panasonic SC-PT660 Theater System
I got LCD22-208 want play dvds it makes funny noise
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG DVD roms and DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
Feb 28, 2010 | Televison & Video
Won't read diisc and makes funny noise
Check first to make sure there are not Two (2) disks in the tray.
The disk may not be seated completely in the tray.
The disk may be upside down.
Try a different disk. If it plays properly, the disk in question is probably bad
Read Ya,
Z
Jan 01, 2010 | Televison & Video
My dvd rom doesn't read cds.when i put one in it just makes funny noises, spins for a while, and stops. what's wrong with it??
Sounds like your DVD/CD rom has failed. Take your PC to an shop for a replacement/install.
Nov 21, 2009 | Computers & Internet
Stuck DVD tray
Turn off the computer and then use the paper clip to open the DVD tray.
If this doesn't work, then something is jaming and stopping the tray from opening. In this case, remove the DVD drive and dismantle the drive (ie. remove the metal cover to reveal the internal components and remove the CD ot DVD disc.
If nothing works the the DVD drive is faulty and needs to be replaced, these drives are not expensive.
Jul 21, 2009 | HP Pavilion DV5234US Notebook Laptop
DVD tray makes noise when it rotates
This noise can be casued by two things:
1) The tray is not completely in the loaded position and the "clamper" is rubbing. Replace the loading belt and the loading sequence will complete and the noise should stop.
2) The "CD table" that is part of the spindle motor assembly has slipped a bit. This will make the CD/DVD ride too low and strike the lower tray support. This will require that the table be "re-aligned" to the proper height which may not be possible on your model without special measurement equipment. The height is critical to proper operation of the unit.
Try replacing the load belt first and report your results.
Thanks,
Dan
May 30, 2009 | Kenwood DV-605 Multi-disc DVD Player
SAMSUNG GT9OOO DVD ROM
your DVD drive need replacement you can buy one online at ebay stores
Jul 15, 2008 | Samsung P10 C XTC 1900 Notebook
My 360 want play games and makes a funny noise when the tray opens and closes
hi man. it appears your dvd drive on your 360 has gone bad. i offer a replacement service if you want to email me at blue_dragon45801@yahoo
Jun 18, 2008 | Video Game Consoles & Games
Compaq Presario 5000 PC Desktop Logo
29 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
