WESTALL MODEM WON'T WORK WITH netgear router. PPPoe
    Scholar:
  • 81 Answers
Are you using dsl or cable? make sure you have the modem setup then connect the router. contact your provide and they will walk you through setting up the modem then add the router.
Posted on Dec 01, 2008
Il netgear 33 supporta pppoe?
it is not a routers job to do Point-to-point protocol over Ethernet , a dsl modem would be set up with pppoe then the router would provide the LAN access and wireless network
Sep 03, 2013 | NetGear Computers & Internet
Trying to connect a netgear router for at&t company. att only uses 2wire or motorola and works on dsl. can i use a netgear with att
Yes, just make sure you have all your authentication codes ( username and password) when already setting up the router for the first time for PPPoE...
Apr 07, 2010 | Computers & Internet
Well anandg27, I performed the instructions to my laptop, then router and after I press ?apply? it takes me back to basic settings. So I checked the router status and this is the result Account Name...
Hey Gary,
In that case, make sure that you enter the correct PPPoE information on the router and also please confirm me about the following details:
# When you are connected to your modem, do you key in your username/password before you can go online or are you able to go online directly?
Oct 11, 2009 | NetGear WGR614 Router
Same old question, but I cannot get a connection between my Netgear wireless router WGR614 to my cable modem.I follow the set up via the router's wizard. But no luck. Even unplugged the modem for 15 mins...
Can you pls confirm if you have cable or PPPoE connection. Also, please connect the modem directly to the computer and let me know the results:
A. Click on Start—Programs—Accessories—Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here.
Once I have this information, it will be quite easy to configure the router.
Oct 09, 2009 | NetGear WGR614 Router
I have a WGT624 router. I have had verizon internet for about 2 months. Recently, I could not get on the internet using wireless but could when just using the modem. I have unplugged the router and then...
either you need to reconfigure the router for the wireless configuration or setup the router for PPPoE connection. if you have internet directly to the modem contact your router manufacturer if not then you need to contact your ISP and ask if you need to setup the route rwith PPPoE connection and get the user/password
Sep 07, 2009 | NetGear WGT624 Wireless Router
Need help with wireless router and wireless verison card.
You need to bridge your modem first before you can use your netgear wireless router. You can reconfigure your netgear without bridging your modem and it will work, but the connection will not be as stable. You'll only need your Verizon password and username if your connection type is PPPoE. If your connection is DHCP, you don't need your username and password anymore, but you may have to ensure that your connection type inside the netgear router is set for DHCP as well. If you're a PPPoE, then you don't have to worry, even if you don't know your username and password, you can give Verizon a call and they will reset your password and give you your username after you've verified your information with them so you don't have to worry about anything. Whatever issue it is, they can help you with it. I suggest you have them bridge your modem first before using your netgear. If I know the brand and model number of your modem with verizon I can definitely give you instructions here on how to bridge your modem properly. Just let me know.
May 24, 2009 | Sony Playstation 3 (PS3) Console
DSL connection not being shared by Linksys RV042 Dual Wan router
Looks like your "modem" is actually a gateway, as is common with DSL devices. It's acting like a modem and a router. So you're actually connecting a router to your RV42. You could get this to work a couple ways.
1. Leave the modem acting like a router and configure the WAN connection on the RV42 as a static IP, and use the IP of the modem. You may also be able to use "obtain IP automatically" in the WAN connection. This way, the modem stores your PPOE information and just forwards the traffic to the RV42. Any devices behind the RV42 won't know the difference.
2. Configure the modem as just a modem (no routing). Your ISP should be able to talk you through this, but in the modem configuration you can look for what's usually called "bridged mode." Then you would enter the PPOE information in the RV42. This is my preferred method.
Feb 24, 2009 | Linksys RV042 VPN Router
Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Jan 19, 2009 | NetGear WGR614 Wireless Router
Netgear wireless wpn824
Sounds link you need to setup PPPoE on your router. Not knowing who your ISP is, Netgear has this website that lists a lot of ISPs support on setting PPPoE up. that is located here: Netgear
If you can't find the info there, basically what you need to do is on your router, typically the main page, you might see an area that lists: DHCP, Static, PPPoE (or something similar). What you need to do, is select the PPPoE option and put your ISP login information (that is on your DSL modem now) there should be a connect or login button once your finished. Once that is done, your router does the logging in, instead of the modem.
Feb 03, 2008 | NetGear RangeMax WPN824 Wireless Router...
ISP SBC SpeedStream 5100b Modem Causes Install and Connection to Fail
Symptoms * You have a new router, and cannot get online to the Internet. AND * The Setupwizard will detect dynamic IP even though you have a PPoE connection. (Going to router status on the administration page, there is a private IP address on Internet port. 192.168.x.x range.) Cause The SBC DSL modem SpeedStream 5100b, used on new DSL and Yahoo SBC DSL installations since Feb. 2004, causes the NETGEAR router Setup Wizards to fail, and prevents routers from connecting to the Internet. This problem affects many router brands. The modem can be distinguished from the earlier 5100 by a 5th light labeled "Internet". The SpeedStream 5100b's default configuration is "PPPoE on the Modem" ? matching a built-in PPPoE client convenience feature that sends login ID and password to SBC. To Work Around These Issues, Configure the Modem for Bridged Mode Note: In Bridge Mode you cannot to connect to the modem's configuration menu, except by resetting it as described below. 1. Disconnect the router from your network, and connect the computer directly to the SpeedStream modem 2. Open an Internet browser. 3. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 4. Click Advanced. 5. Enter the "Access Code" printed on the bottom of the modem. 6. Click PPP Location. The PPP Location screen appears. 7. Select Bridged Mode (PPPoE is Not Used). 8. Click Save Changes. 9. Connect the router between the computer and the modem. 10. Power off the modem. 11. Power off the computer. 12. Connect the Internet port of the NETGEAR router to the Ethernet port of the modem. 13. Connect the computer to a LAN port on the NETGEAR router. 14. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 15. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 16. Power on the computer. 17. Log in to the router by typing 192.168.0.1 in your browser. 18. When prompted, using lowercase letters, type admin for the user name, and password for the password. Some older routers use 1234 for the default password. If you forgot your router password see http://www.fixya.com/ThreadView.aspx?thid=102081&prdid=252188 19. Use the Setup Wizard to connect to the Internet. To Reset the Modem To Enable Access to the Configuration Screen 1. Disconnect the computer from the modem. 2. Power off the modem. 3. Power off the computer. 4. Connect the Ethernet port of the modem to the computer Ethernet port. 5. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 6. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 7. Power on the computer. 8. Open an Internet browser. 9. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 10. Click Advanced. 11. Enter the "Access Code" printed on the bottom of the modem. 12. Click PPP Location. The PPP Location screen appears. 13. Select PPPoE on the modem. 14. Click Save Changes. 15. At the login screen type in your SBC member ID and password (which is usually the primary email address on the SBC DSL account and the password for the primary email address). 16. Click Connect. * If successful, a screen appears reading "You Are Connected", and the Internet light goes solid green. * An error will display if the username or password is invalid. * If there are other problems the message "The DSL connection is down" appears.
Feb 19, 2006 | NetGear FR114P Router
Computers & Internet Logo
53 people viewed this question
Alun Cox
David Payne
David Payne
