Question about Acer Aspire 5100 Notebook
Dial up conncetion
My dial up isn't dialing up when i turn on my computer i had it set to dial up when i turn on my computer so every time i turn on my computer i have to connect to the internet manually. i have my dial up set to always dial my daulft connection can you help me
  • 659 Answers
Well all you have to do is create a shortcut on your desktop for it and then drag and drop it into the startup folder, you can drag it onto the start menu to open it up and then goto programs and then startup and then drop it in there and there you go it will automatically dial up everytime your laptop is turned on
Posted on Nov 30, 2008
Tip
Setting Your Timer
1. Move the control lever to the OFF-CLEAR position for about 20 seconds. The red indicator light will go off and any previ- ous time settings will be cleared from memory.
Program Using "Quick" Method:
2. Move the control lever to the ON position. The Red indicator light will start fashing.
3. Rotate the time dial clockwise at least one click, stopping at the half hour nearest to the present time.
NOTE: During programming, be careful not to press the dial while turning it. If you press the dial, you will ac- cidentally set a wrong time.
4. Press the dial once to set the present time. The Red indicator light will go off.
5. Rotate the time dial clockwise to the frst desired ON time. The Red light will pulse momentarily with each click.
6. Press the dial once to enter the ON time. The light controlled by the switch timer will turn ON.
7. Rotate the time dial clockwise to the desired OFF time.
8. Press the dial once to enter the OFF time. The light controlled by the switch timer will turn OFF.
Repeat Steps 5-8 for each additional ON/OFF setting. Continue to rotate the time dial until the Red indicator light comes ON and stays ON, indicating that the switch timer is in AUTOMATIC mode
on Oct 06, 2009 | RTO Intermatic Inc Ej351c Timer Night...
Where is the power button for canon eos elan iie?
There isn't one. To turn on the camera, hold down the lock release button (just inboard of the command dial) and turn the command dial from the "L" position. To turn off the camera, hold down the lock release and turn the dial to the "L" position.
If you need a manual you may download a copy from here.
Oct 31, 2012 | Canon Photography
How do I set a plug in timer GE 24 hour Model 15075? There are tiny switches for every hour and can be pushed towards the inner circle or pushed outward. And there is a turning arow near the center and a...
Following link has a close-up photo of on-off pins on GE 15075 timer
http://waterheatertimer.org/GE-timers-and-manuals.html#15075
Pins are located around timer dial
The pins divide 24-hour day into 1/2 hour segments
Pins are out for ON
Pins are inward for OFF
Notice that numbered dial is divided into dark and light areas ... the dark areas are PM, light areas AM.
For example you are connecting chicken coop lamp to this timer.
Turn lamp on and make sure bulb is working.
Plug lamp into timer.
Set pins in and out as follows: all pins outward between 4:30 pm on light part of dial to 8:00 pm on dark part of dial. And then set all pins outward between 5:00am on dark part of dial to 7:00 am on light part of dial.
Plug timer into outlet
Move switch located on top to TIMER ON
Manually rotate timer dial clockwise to see lamp turn on and off.
Lastly, set current time: Manually rotate timer dial clockwise until current time lines up with arrowhead located on inner dial. So if current time is high noon, then rotate dial until 'sun' symbol located on light part of dial lines up with arrowhead.
As time passes, the timer dial rotates, and the pins click circuit on-off.
To override timer, move switch to outlet-on.
Jan 09, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
How do you set the timer
You posted under mechanical outdoor timer with time dial located on face.
If you have different timer, add a comment.
Instructions:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There are segments or pins located around outer edge of dial.
If timer has segments.
Pull these segments outward, or leave them in place to set on-off times.
Pull out a few segments and then rotate dial clockwise to see if lights turn on or off with segments out.
Then pull out segments for the times you want timer to turn on-off.
If timer has pins.
Click pins outward, or leave them in place to set on-off times.
Click out a few pins and then rotate dial clockwise to see if lights turn on or off with pins out.
Then pull out pins for the times you want timer to turn on-off.
Some timers also have an override button located on inner dial or somewhere on body of timer.
Move this switch to TIMER or AUTO, depending on your timer
Dec 05, 2010 | Stanley 38445 TimeIt 24Hour Daily Outdoor...
We have the intermatic timer Model EJ351 and when I go to set the timer at the beginning it does not flash. It is when I start from off to on. Mary Ann
Mary Ann:
It appears that it will start flashing when you move from off to on. Here are the directions from the web site.
Gary
20 seconds. The red indicator light will go off and any previous
light will start flashing.
dial while turning it. If you press the dial, you will accidentally
set a wrong time.
light will go off.
Rotate the time dial clockwise to the first desired ON time.
AUTOMATIC mode.
Dec 02, 2010 | Solar Intermatic Ej351c Indoor Wall Switch...
How do i set timer to turn lights off and on
If I understand correctly, you have Intermatic electro-mechanical timer that has a yellow clock dial on front
And you want to set the timer to turn lights on and off
And your wiring is correct and the manual override turns the lights on-and-off correctly
To set timer:
Pull dial back toward you. Rotate clock dial until current time lines up with silver pointer.
On other brands of timer, you rotate dial until current time lines up with an arrow or the word 'time' located on lower right of clock dial
Timer has on-off trippers that fit outer edge of dial.
Intermatic trippers are labeled ON and OFF
Other brands of timer have dark and light-colored trippers >> I think the dark trippers on some brands are OFF
Place 'off' tripper when you want timer to turn off
Place 'on' tripper when you want timer to turn on
Turn on electricity and expect timer to run for 20 years
Dial has to be re-set to current time after power outage
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Oct 20, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I bought a house with a Night Sentry Solid State Timer model # EJ341 and have no instructions on setting or programming the unit.
rapid Programming.
1. Move control lever to OFFCLEAR for at least 5 seconds
• red indicator light goes off
• all time settings are
erased.
2. Move control lever to ON.
• red indicator light will start
flashing.
3. Check a clock; then turn pushbutton time dial clockwise at least one click.
• stop at the half hour nearest to present time (note
AM or PM).
Note: When turning pushbutton time dial, do NOT
accidentally PRESS at the same time.
4. Press pushbutton time dial once to enter present time.
• red indicator light goes off (present time has been
recorded).
5. Turn pushbutton time dial clockwise to desired
ON time.
• red indicator light blinks with each click.
6. Press pushbutton to enter ON time.
• controlled light(s) will turn on.
7. Turn pushbutton time dial clockwise to desired
OFF time.
8. Press pushbutton time dial to enter OFF time.
• controlled light(s) turn off.
9. Repeat 5-8 for other on/off times.
10.Turn pushbutton time dial for at least 2 more turns
from the first ON time to complete this program
• red indicator light will turn on and stay on (steady
light means timer is in automatic).
Note: Pushbutton time dial does not turn
automatically after setting to indicate time of day
Aug 22, 2010 | Hardware & Accessories
Programming
Use this procedure to manually program ON/OFF settings.
1. Move the control lever to the OFF-CLEAR position for about 20 seconds. The red indicator light will go off and any previous time settings will be cleared from memory.
1. Move the control lever to the ON position. The Red indicator light will start fashing.
2. Rotate the time dial clockwise at least one click, stopping at the half hour nearest to the present time. NOTE: During programming, be careful not to press the dial while turning it. If you press the dial, you will accidentally set a wrong time.
3. Press the dial once to set the present time. The Red indicator light will go off.
4. Rotate the time dial clockwise to the frst desired ON time.
5. The Red light will pulse momentarily with each click.
Sep 26, 2009 | RTO Intermatic Inc Ej351c Timer Night...
Setting time and date
From the manual:
1. Press the MENU button to open the menu.
2. Turn the SET dial to select [SYSTEM] and press the
SET dial.
3. Turn the SET dial to select [T.ZONE/DST] and press
the SET dial.
4. Turn the SET dial to select the setting option that represents your time zone and press the SET dial. To adjust for daylight saving time, select the time zone with the * next to the area.
5. Turn the SET dial to select [D/TIME SET] and press
the SET dial. The year display starts to flash.
6. Turn the SET dial to select the year, and press the
SET dial.
• The next part of the display starts flashing.
• Set the month, day, hours and minutes in the same way.
7. Press the MENU button to close the menu and to
start the clock.
Jan 15, 2009 | Canon Video Cameras
Acer Aspire 5100 Notebook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
