Question about GE GSL25JFPBS Side by Side Refrigerator
Freezer ices up on bottom where the drain outlet is
When the bottom ices up on the frezzer water runs out bottom of door onto floor.
I poor hot water down the outlet at the bottom of the freezer and this seems to clear it for 1-2 months but then it keeps coming back
    Sergeant:
    Champion:
  • 291 Answers
Clear it again and then go underneith and make the drain hose to shape like a j-trap and it will fix the problem ,,, if you have to, cut a piece of clothes hanger and slide it up the hose and then shape it / larry
Posted on Nov 29, 2008
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Water is pooling on bottom of our Frigidaire Freezer and turning into ice-then it slowly leaks out of the door unto floor. This is not a freezer-frige-just frezzer. Freezer is around 8 years old.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | Frigidaire FRS26ZSG
My ge tfx28pb has water frozen at the bottom of the freezer, what is wrong
the drain is pluged with ice and causing the water to run onto the floor of freezer .. defrost drain with hot water and a turkey baster . this shoould solve problem .. mm
Aug 10, 2010 | GE PFS22SISSS Stainless Steel French Door...
I have MODEL#MB1952HEW S 10618291GE my problem is
This would be from the defrost drain being clogged. Every few hours the defrost cycle will melt the frost from the cooling coils, the water from this cycle should flow down a drain in the bottom of the freezer, if this drain is restricted the water flows out the freezer onto the floor. See the link below for details on how to clean this out.
Defrost Drain Cleaning
Jul 08, 2010 | Refrigerators
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Water not draining from defrost unit in frezzer compartment
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Oct 12, 2009 | Refrigerators
Freezer door leaking alot of water on floor no ice on door
This really sounds like a plugged drain. When the unit goes into defrost the water should run down the drain into the drain pan...when the drain is plugged it will run over and down to the bottom of the freezer thus leaking out the bottom of the door and onto the floor. You will need to take everything out of the freezer and remove the screws that hold the back panel on break out the ice at the bottom and use hot water to pour down the drain to clear it.....also if you have a small hose to shove down the drain that will help out alot.
Oct 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Dec 22, 2006 | Maytag MZD2766GES Side by Side...
GE GSL25JFPBS Side by Side Refrigerator Logo
102 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
