Question about Philips DVP642 DVD Player
There is a DVD in the player that wont eject or play.
The power button just blinks when plugged in, and i can't get the DVD out or to do anything like play. I got it in 2005 and has worked perfect until suddenly stuck.
  • 9 more comments
  • simsseth Nov 30, 2008
    There was no pin sized hole.
    Does anyone know where a reset button might be, or how to loosen the "clutch" it has on the DVD in the player. I have the top off the unit.
  • simsseth Dec 01, 2008
    Sorry about the "inappropriate" thing, I'm new. There are no chemicals or bursting.
  • maelen Dec 03, 2008
    I have a Phillips Model no.:DVP642/37. It has suddenly quit working. All the life I see in it is a blinking red light in the standy-on spot. Can you help me with this?
    maelen
  • bethercy Dec 19, 2008
    I have the same problem, there are no pinholes to use like on computer drives; i took off the cover and still there is nothing i can find to push or pull or hit that would make the disk eject.
  • PHL28 Feb 09, 2009
    Power button blinks on and off but nothing works dvd stuck inside
  • Anonymous Mar 05, 2009
    same problem with light blinking and no power. Cannot locate the reset button. any help?
  • tpup Mar 05, 2009
    nothing has burst. cannot find reset button. What now?
  • Sherrett Mar 05, 2009
    I have the exact same problem: DVD disc in player will not eject. Tried cycling the power as per the manual instructions and got no results.
    Called Philips support line and they offer a 1-year warranty. If your player is older than 1 year, you're out of luck and they have no time for you. They also have no solution for recycling the DVD players and rely on local recyclers, at consumer cost and initiative.
    After this very poor experience I would recommend very highly against purchasing anything from Philips in the future.
  • Anonymous Mar 13, 2009
    same problem disk in dvd player, no pin hole to pop it out, and the light keeps blinking red.
  • Anonymous Apr 01, 2009
    I cant get the dvd out. The power button keeps flashing red and it wont come up on the tv
Instead of a pinhole, there is a slot on the bottom of the DVD player that will force the disc out. There's a plastic lever visible on one side of the slot. I used a butter knife to push into the slot.
Posted on Feb 03, 2009
  • Philips Master
  • 5,568 Answers
Look for a pin-sized hole on the front panel.  If you find one, use an unfolded paperclip to push into it. Many optical drives provide this for just your situation.
They use a friction clutch (for safety) that eventually doesn't function right anymore.
The blinking light may be telling your that the power supply hasn't come up as it should which could also affect the eject operation.
Posted on Nov 29, 2008
  • Steve Allison
    Steve Allison Nov 30, 2008
    Despite the unwarranted 'Inappropriate' rating that is normally reserved for off-topic or obscene postings, I will suggest that you look for part using the guide below since you have removed the case.
    If anyone here responds when trying to help you and fails, then 'Thanks for trying' is the proper response.
    Check toward the back of the unit where components seem larger and perhaps you can identify a transformer, probably of the ferrite-core variety. THis will be the power supply section.
    Look at the cylindrical components with markings on them such as 'uF.' These are electrolytic capacitors.
    Defective ones will often burst at their tops or deposit chemicals around their bases.
    If you see any that appear this way, they will need replacement although they may not be the only failed components.
    Capacitors are not expensive but replacing them carelessly can damage the traces on the board and require a decent soldering iron, quality solder and some solder wick to absorb solder around suspect parts and let you remove the old components.
    If you do choose to try this repair, be advised that this type of capacitor is polarized so the newe parts must be installed with the leads oriented as were the original + & - markings.
Panasonic 1080p DVD Recorder flashes "Hello" cannot turn off, eject DVD, play or anything
I just had this problem the other day. Unplug the unit for 2 minutes. When you plug it back in and get a the 000 press the power button for about 5 seconds and that will put it back in stand by mode. Hit the DVD open button instead of the power button. Hope this helps
Aug 03, 2015 | Panasonic Televison & Video
My dvd wont eject. when i press open it blinks for a minute then goes to loading! then dvd will then play. I can hear it running but it will not eject the dvd.
unplug it for 10 - 15 mins... when you plug it back press the stop/eject quickly (player will automatic try to load disc)
Aug 09, 2011 | Toshiba SD-6000
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
Wont eject dvd
Pull out the power plug leave it out for a while and then put it back in and then hold open/eject button until the DVD player says open/eject let go..the DVD tray should come out.
Please vote if this helps..thankyou!
Aug 13, 2009 | Samsung DVD-P241 DVD Player
Dvd won't play or eject
If you want to get the dvd out
you can try this:
First turn of you dvd player at the mains, Then power it up, But the moment it powers up press the eject button a few times so it doesn't start to load. If it doesn't work the first time try it one more time since you may not get the hang of it at first.
then you dvd should eject.
With dvd players like this, corrupt, copied or really scratched dvds may make your dvd player do this.
Regards
Jul 25, 2009 | NexxTech DP3222 DVD Player
The power button on my Philips DVD player blinks.
The Front PCB might be damaged. Check the front PCB
Jan 10, 2008 | Philips LX3000D System
Dvd eject button does not respond
Had a similar problem after loading a suspect dvd (one I had buned myself) Could not do anything - stuck at loading.
Try this :
  1. Unplug and wait 10 seconds
  2. plug it back in and wait 1 minute. DO NOT PRESS ANY BUTTONS!
  3. With the machine still in the standby state, press eject on the REMOTE. It should eject without trying to read the disk.
Good luck. It worked for me.
Dec 03, 2007 | Samsung DVD-HR720 DVD Recorder
Dvd hr720
Had a similar problem after loading a suspect dvd (one I had burned myself) Could not do anything - stuck at loading. Don't remember if the fan was running. From what I have read these units are touchy to bad disks (DVD or HDD) If yours has a DVD inserted try this :
Nov 15, 2007 | Samsung DVD-HR720 DVD Recorder
DVD Drawer / VHS Eject button
My 1st suggestion is to pull the AC power plug from the wall, wait 5 minutes (have a smoke or a coffee) and plug it back in.
Then retry the functions that are giving you grief.
Report back with the results and we'll go from there.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating Other than Solved
Oct 18, 2007 | JVC HR-XVC19S DVD Player/VCR
Philips DVP642 DVD Player Logo
566 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
