Question about Gateway AR-230 DVD Recorder
My DVD Drawer will not open on my Gateway Laptop
The drawer will not open when I push the button for it to open.
  • Anonymous Mar 10, 2009
    My Drawer will not open on my Gateway Ar-230 DVD recorder.
My dvd drawer will not open on my
Gateway Laptop
Posted on Mar 08, 2009
2 Suggested Answers
Grubhead
  • 5515 Answers
SOURCE: DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
Posted on Apr 05, 2010
How can i open my dvd drawer on comp when the button wont do it
Use a paperclip and push the unit open through a tiny hole in the front, just underneath the tray
Aug 04, 2014 | Gateway Computers & Internet
NEW LAPTOP CANT OPEN CD DRAWER, WHERE THE HELL IS THE BUTTON, IT SEEMS STUCK.
When first powering on this laptop, you should push the button on the left side where the CD/DVD drive is located. You should also push F10 to stop it from loading an OS and it will enter into bios where the CD tray can be opened.
Feb 24, 2014 | Compaq Presario X1000 Notebook
Dvd drawer
There should be a very small hole that you should be able to push a paper clip into. This unloks the mechanism even when powered off so you should be able to manouvre the trapped DVD out without it vibrating
Jan 23, 2013 | Fujitsu Computers & Internet
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
Apr 05, 2010 | HP dc4000
DVD drawer on my gateway computer will not open
You can eject from My Computer open it right click your dvd drive and select eject or you can insert a pin (sewing needle or safety pin) into the tiny pin hole near the eject button and push lightly this will eject it as well.
Jan 09, 2010 | Gateway Computers & Internet
As I was powering up my laptop I opened the cd drawer placed a disk in it. Now it won't close. Tried rebooting, hitting the tab and closing, control panel open drawer, nothing seems to work ????
If the door has shut then look at the facia of the dvd panel and there should be a small hole in it
Get a strong paperclip and push it into the hole, that will eject the drawer
If you have jammed it in real tight get someone else to push the paperclip in the hole while you carefully use two blunt knives to lever on the sides of the drawer
Worse case scenario is that you have to take out the two screws on the base of the laptop and remove the drive altogether to gain access
Jun 17, 2009 | Gateway Computers & Internet
Acer Laptop DVD drive stuck in 'open' position
The solution turned out to be just pushing the DVD drawer in and popping it out a few dozen times. Probably not the best solution, but the DVD player works and it slides smoothly now.
Dec 25, 2008 | Acer (KV.16X04.007) DVD Drive
Gateway AR-230 DVD recorder
I read about some magnetic thing failing as the unit gets older. Mine does this sometimes and I gently tap top of unit as I hit the eject button. Works on mine so far.
Oct 09, 2007 | iLO DVDR05 DVD Recorder
Gateway AR-230 DVD Recorder Logo
603 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
