Question about ION Audio TTUSB10 Turntable
LP audio recording seems to be at the wrong speed
I just bought an ION USB turntable from Costco. when I am attempting to record to the computer the audio through the speakers sounds like the 'chipmonks'' and the same result when I play the audio back from iTunes?
What am i doing/not doing?
  • caper70 Dec 02, 2008
    I appreciate you took the time to reply with a possible solution. I checked out what you said and all was in order. I received another solution involving the drive belt. I discovered the belt was incorectly installed and had slipped up on the brass motor spindle and was causing the turntsble to rotate too fast. Thanks again.
  • dougirldi Jan 05, 2009
    My problem is my audio recording seems to be at the wrong speed. It sounds too slow. It helped to change the speed to 45 from 33rpm, but that solution only lasted for a couple of records.
    Scholar:
  • 140 Answers
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Posted on Nov 29, 2008
How can I record from the turntable on my Ford Mustang Ion to my Ipod nano?
Advertising says;
4-in-1 retro music center with turntable, radio, USB and aux input
  • 3-speed belt-drive turntable plays all your records
  • Records your albums onto USB flash drive
  • Sensitive FM tuner with speedometer look
  • Built-in speakers and headphone jack for private listening; Auxiliary input for connecting and playing other devices
  • So record to USB, put the USB into the computer and transfer it using Windows File Explorer, using right click, drag, copy here, so a file location on the hard drive like 'My Music'. Then connect your iPod and transfer it. You may have to buy the 'iTunes Match Package' to allow you to use music not purchased from Apply. It is $24 a year.
    Amazon com Ion Audio Mustang LP Ford 4 in 1 Classic Car Styled Music...
    Apple Music vs iTunes Match What the difference
    Dec 27, 2017 | The Audio Players & Recorders
    How to connect ion turntable to bose radio?
    Why whole you try to connect a computer accessories to an audio system? Even when both things are made for audio.
    To bring digitising vinyl, closer to the computer user, ION produces record players, which don't output audio signals, but digital signals.
    The digital signals can be read by a computer, when connected to a computer with the appropriate software installed.
    If you want to connect the record player to an audio system, you need to rip it down. Trow out the digital part, and connecting correct cabling, straight to the cable coming form the PU element. Then you will be surprised, how little modern amplifies still can handle the low signal levels a PU element produces.
    I'm sorry I have to say you can't use the ION turntable in a normal audio system, like you can connect any USB connector to a normal audio amplifier, unless you modify the whole system. And if you would modify, the sound coming form that system, would sound poor, considering what you have to pay for the ION, and the modification. A normal record player, with a correct pre amplifier that can be connected to the Bose, would be cheaper.
    Jan 01, 2015 | ION Profile Pro Lp Usb Turntable With...
    I have had Roxio Creator 2011 for 3 years and have been able to copy many of my vinyl Lp's onto the system. However I have not used it for about 8 months and when I tried to 'record' some more LP's I...
    If you didn't install the driver of the USB record player, it won't pick up all but the basic functions of the unit. try upgrading the driver of the LP usb player.
    Nov 18, 2013 | Roxio Creator 2011
    Not all of the sound/music is being transferred from the LP.Hard to explain, but its when the LP has sound coming out of each speaker independent of one another, only one side is coming out on the recorded...
    I know this is an old post, an I dont' have a solution yet, but t seems the same problem as on my Ion USB recorder - One of the input channels is not working. Like you, I found one of my music tracks not plying right - there was only the instrumental and no vocal. When I experimented, and changed round the jacks on the cable coming from the turntable (red and white plugs), I then got only vocals and no instrumental. Obviously one of the input sockets on the USB recorder is no longer working (I already checked the turntable and cable itself by playing back he same track with both stereo channels through my amplifier). You can either get the item replaced if its still under guarantee, or fix it yourself, if you have the necessary skills, neither of which apply to me.
    Apr 22, 2011 | ION Audio Vinyl Recording Turntable
    ION USB recording mainly room sound, only little album sound!
    Sound input option was routed to microphone in System Preferences. Needed to change it to the turntable input.
    Feb 19, 2009 | ION Audio iPTUSB Turntable
    Appears to be installed properly but doesn't record
    What computer, and are you using the ion software, or 3rd party software to record?
    Keep me posted.
    Dec 09, 2007 | ION Audio iTTUSB Turntable
    ION Audio TTUSB10 Turntable Logo
    496 people viewed this question
    Top ION Audio Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Morne Olivier
    Ben Armstrong
    Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
