Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
The farthest two molds from supply not filling
I have checked water supply to the filter, good. The first five molds fill partialy. I am on well water. Is there any way I can adjust the flow to the ice maker?
  • tommyratliff Nov 29, 2008
    If the filter/flow control valve are on a timer, do I need to replace the filter? I am a home owner, not a contractor. Thanks in advance for any help.
    Thanks larryb,
    What info do I need, and where do I go to purchase replacement filter?
    I do agree with your assesment. We have had problems with faucets in the past.
    Sergeant:
    Champion:
  • 291 Answers
You will need to replace your water valve / iron from well has built up in it / larry
Posted on Nov 29, 2008
  • Larry Youngblood
    Larry Youngblood Nov 29, 2008
    send me the model number from the inside of your frig and i will get you the part number and price and even check to see if i may have one in my stock / larry
Water filter status has red light. Did not replace and now has green light and Ice maker stopped making ice.
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing.
Check the screen that filter debris, If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve.
Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If you find nothing the problem is definitely from the water inlet valve
Jun 04, 2015 | Refrigerators
Ice maker is not producing ice and the control light is blinking red
Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve.
WATER IS FILLING UP ONLY 2 OR 3 SLOTS IN ICE MOLD. HOW DO I DETERMINE WHY WATER IS NOT FILLING UP ALL UNITS IN ICE MOLD TRAY?
Possible restriction in the water fill line to the ice maker. Possible ice build up in line.
Oct 07, 2014 | Refrigerators
Horizon Group Power Balls Super Balls made by me! has no instructions, can you help?
From the box:
Cover work area with scrap paper.
- Decide which shape mold and colors you are going to use to make your power balls.
- Next snap together the two parts of the plastic ball mold
- Open the color crystals package that you would like to use first and pour the desired amount into the funnel on the top of the ball mold. Do not fill the funnel part of the mold all the way to the top or your ball will not bounce very well when you remove it from the mold.
- Holding the funnel part of the mold, carefully place the filled mold in a cup. While holding the mold, fill the cup with water right up to the bottom portion of the funnel. Let the mold sit in the water for five to ten minutes.
- Remove the mold from the water and wait ten minutes before opening it.
- Carefully open the mold and remove the ball. When you remove the ball from the mold it may feel a little sticky. Let it dry until it is no longer sticky before you start playing with it.
- Find a clean, flat surface to bounce the power balls on. When you are done playing, store each ball in resealable bags until you are ready to use them again.
Jan 01, 2011 | Roseart Toys
I;m not getting any water to my ice maker for it to make ice?
It isn't the water supply hose that would be frozen since that is outside of the refrigeration area.You need to verify (if you haven't done so already) that you actually have water supply to the back of the fridge first. If so then take and clean the mesh filter on the fill valve.Use a needle, pin, or a sharp pointed pick to remove it.
Clean the filter (by using toothbrush or a small fine wire brush, and brush it under a slow running water tap). You can see how well you've cleaned it by holding it up to a light and you will see whether there are areas which may require more attention.
Once you are satisfied that it is clean, place it back in and connect your water and test.
Also an icemaker has something called a fill cup, which holds the water from the supply hose as it is being drained into the ice mold. If this ice maker part is not aligned properly, water doesn't make it from the supply valve to the ice mold, and you don't get any ice. Check to make sure your fill cup is properly aligned. You can check this ice maker part by removing the ice bin and having a look, adjusting if necessary. If you have ice forming on the water spout, you could have a leaky water inlet valve, another ice maker part which will need to be repaired.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | LG LFX25960ST Stainless Steel French Door...
Hi, when i flush the water it sometimes works good and flush the dearty filling a clean water insted and sometimes just fill water without flushing the deart (or partialy flushing it). It happand random'...
Not exactly sure what you are saying but have you checked the flapper inside the tank? Mayneed to replace the flapper or the flush vale unit.
Sep 01, 2010 | Home
Not filling with water to wash
(1) Fill valve failed, check and replace
(2) Fill valve filter blocked , take off back supply hose and clean out mesh filter (Turn off water supply first and have a cloth handy to catch water remaining in hose under pressure)
Nov 05, 2009 | Dishwashers
My neptune washer will not fill up
by "fill up " I take it you have no fill.
If it partialy fills it is the water level switch
If you get hot or cold the hot or cold coil may be faulty
if you get no fill at all- and it spins - it may be timer
Jul 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Small ice cubes The ice maker is not supplying enough water. The result is very small ice cubes. The water supply pressure is on max, can there be a way to adjust the water level? The tray is not even...
The ice maker is time filled, it only has a certain time in which to fill. There is no way to adjust the water level. Check the pressure limiting valve which is in the water line before the filter. Have you replaced the filter? Remove the filter and pressure limiting valve and see if the ice maker receives more water. If it does, then replace the filter and check again. If it is still good, the pressure limiting valve is faulty.
Oct 27, 2007 | Samsung RS2630SH Side by Side Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
