Question about Toshiba Satellite A105 Notebook
Laptop will power off on the 1st to 10 boots with or without battery installed. After the 10 boots if I hit setup it will take me go there and let me save and exit and then the computer boots up. The toshiba sat p105 will not boot from the DVD drive or will it read a CD or DVD after I get it to boot up. Help!
Installed 10 will not boot
If you can get to a working computer, you can download the "Media Creation Tool" (google it) from Microsoft. This will allow you to download an .iso (disk image) of Windows 10 in whichever version (Home/Pro) and type (32 or 64 bit) you have installed on the laptop. Once you have the image, burn it to a DVD and then insert it into the laptop and boot to it. You should then be able to do a repair install of Windows 10 without losing any applications or data. Should that fail, you can always then use the disk for a full, clean install, but that will wipe out everything on the disk, so do it as a last resort.
Sep 16, 2015 | Dell Latitude E5410 Core i5-2400, 2 GB,...
I undocked my compaq 6320 laptop - just after accidently hitting the dock- power button (before hitting the eject button). I ejected the computer but noticed it began to start-up but shut down because my...
Try removing the laptop from the doc, pulling out the battery, hold the power button down for 10-20 seconds, and re-install the battery.
This should drain out the laptop and it should boot up properly without the dock.
May 27, 2011 | Computers & Internet
I PLUGGED IN MY LAPTOP ADAPTER AND THE PLUG LIGHT BLINKS BUT DOES NOT POWER UP. THE PLUG ICON ON LAPTOP BLINKS BUT LAPTOP WILL NOT BOOT UP.
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for possible motherboard issue.
Mar 21, 2011 | Toshiba Satellite A215-S4807 Notebook
When i switch on my laptop, the lights on the laptop come on but the screen remains blank, not booting
Hello, that sounds a motherboard graphic problem, try this befor you sen the laptop to fix :
1- take the battery and the power cable from the laptop
2- press and hold for 10 seconds the power button
3- connect only the power cable without the battery and try to boot.
if this dont help you need to repair the motherboard
Thanks
please rate this answer
Jan 25, 2011 | HP Pavilion TX2000Z Notebook
Left laptop on bed in morning screne would not appear
try reseating the battery but before your return the battery after romving it Press and hold down the power button for 5-10 seconds then return the batt and try turning system on if it boots that will be good but if not try reseating the Hard Drive from the system then try booting again ^_^
Possibly the fan is not spinning in your computer, but if the above still does not let the system boot into windows and nothing is on the screen and u hear high pitched noise most probably the Processor on your system is toast only thing that can cause a no post with a high pitched sound is your processor
Jun 04, 2010 | Compaq Presario 700 470024-192 Notebook
My Dell laptop is powered using the ac adapter without the battery. It worked well, however, it stopped powering on (booting etc). The laptop, when connected to the adapter, has the power light on. When...
Most probably is that your MB is fried. The battery does not serves as the power supply, it is also a regulator for the electricity. A small amplitude in electricity and the MB is dead without batt
Nov 18, 2009 | Computers & Internet
Dell inspiron 1525 battery doesnot charge
1. remove all external peripherals 2. try to use ac adapter alone check if laptop will power on. 3. put back batt in with ac adapter. 4. check bios (power on laptop keep tap on F2) 5. check for the bios version, battery info and battery health. 6. check if batt is 0% or 10% charge 7. check battery health and info if the ac adapter is determine or not. also check if batt is performing normally. 8. if batt has 10% charge then download the latest bios for your system. download it from support.dell.com
Nov 12, 2009 | Dell Inspiron 1525 Notebook
Should my HP510 laptop work without a battery
Yes your laptop should power on with just AC power. The issue could be a loose connection for the AC power which caused the battery to stop being able to charge also. Unfortunately only solution for that if it is incase the problem is to open the laptop and have the power connector re soldered onto the board.
Apr 09, 2009 | HP 510 Notebook
Will not boot up or turn on though it is getting power
The Charger could be bad, Try replacing that, or let charge, then try to turn on. The laptop might not boot with AC power. kinda stupid but maybe. If that doesn't work, the AC adapter is bad.
Jun 12, 2008 | Lenovo 3000 N100 0689 Notebook
Toshiba Satellite A105 Notebook Logo
85 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
