Question about Dell Inspiron 1000 Notebook
My problem is, that my laptop cannot work anymore its internet connection.
My laptop cannot work anymore its internet connection. I wan't someone to teach me how to solve this. please.. Once I connect the internet wire, it doesn't works. thanks
  • Hairylegs Nov 13, 2007
    I have an Inspiron 1000 laptop with windows XP. I have dial up internet and cannot connect to my service provider. I don't get a dial tone either. I believe the pins in the internet jack on the back of the laptop are broken. What can I do? Can I replace this part myself? If so, any advise on how to fix it and where I can purchase the part?
    Please help so I don't have to buy a new one!
  • lakenlondyn Nov 19, 2007
    My computer is not recognizing me internet connection by Ethernet cord, also the audio drivers are not working or per my computer not installed on the computer what can I do to fix this problem
  • 624 Answers
Some questions before we get started: -What operating system are you running? -Are you using DSL, cable or dial-up for Internet access? -If you?re using DSL or cable are you plugging your laptop directly into the Internet provider?s box? What is the manufacturer and model of it? -Have you tested your Internet connection to make sure its working? If it?s a phone line can you dial out, if its DSL or cable try connecting another computer to it. -When you plug your Internet cable into your PC does anything appear or change on your screen? Once you give us some more information to work with we can start figuring out what is going on.
Posted on Jan 20, 2007
No internet on PC when cables going through router
Hello there,
You have to start from the beginning and my solution would be:
1) Remove any connections(also don't forget to turn of wifi on your laptop) to router and except the power cord. With the unit powered ON locate the reset pinhole on the back of router.
2) Press and hold reset button for at least 15 secs. then release, wait for 20-30 secs. before the router can completely rebooted.
3) Configure your Computer IP address to “Obtain an IP address automatically” .
4) Connect internet cable to router on port labeled "WAN". Connect PC to any LAN ports available.
5) Now lets configure wireless router. Open any browser you have (IE, Firefox, Chrome, Safari, etc.). On the address bar type: "192.168.1.1" (without quotes). Default username: admin ; default password: admin click "OK".
6) Go through "SETUP WIZARD" until you reach the "Setup WAN Interface" page. On "WAN Access Type:" select "DHCP" then click next.
7) You may configure your "Basic Wireless Settings" to Public or Private until finished configuring.
8) On "Operation Mode" be sure you operate on "Gateway" mode.
That's it! Hope this helps.
Don't forget to vote.
Mar 12, 2010 | Encore ENHWI-G2 Router
Setup with roadrunner
Connect Router - Desktop
Open RSP By typing 192.168.2.1
On the Left side under Internet WAN Click Connection
Type
Leave the password blank and click Submit
The Connection Type Should Be Dynamic
Click Next
There should not be any Host name & Click apply
On the left Side Click MAC Address Under Internet WAN
Click Clone And Click Apply Changes
It Should Work
Dec 27, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Dont have internet connection on my laptop
First change your LAN ip range on WRT54g, leave the wan interface as dynamic IP client. Connect your WAN port to the DSL router interface. ping your DSL router interface (most probably your DSL router will be having 192.168.1.1). Make sure that your laptop is not assigned with any static IP (Incase you use the laptop in home n work).
Jun 12, 2009 | Linksys Wireless-G WRT54G Router
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Using Wireless + PPPoE at the same time kills router. SMCWBR14-G2
From your description, I am assuming you have a direct ethernet connection from an RJ45 connection in a jack in the wall. If this is the case, then you would just need to purchase a wireless router (linksys, D-link, netgear, etc). Connect the ethernet connection from the wall to the routers internet or WAN port. You will need to access the routers firmware configuration and set it to connect with PPPoE, so get your username and password from your ISP if you are not sure what it is.
You will be able to continue to have the PC plugged into the router with an ethernet cable, and then run the laptop with a wireless connection, just be sure to configure the laptop with the security key if applicable.
If you were using a software PPPoE connection on your PC, quit using it. Just set your network adapters on both computers to DHCP, and you should be good to go.
Hope this helps
Chris (ziraffa)
Jan 14, 2009 | SMC (SMCWBR14-G2) Router
Rangemax-internet only works when comp directly connected via LAN
it sounds like you have the wireless connection to the WAN disabled. Go through the wireless settings on the router and check to make sure it's not being blocked from the WAN/Internet connection.
Nov 11, 2008 | NetGear RangeMax WPN824 Wireless Router...
WAN
The wan port is what you hook your modem to. Wan stands for Wide Area Network, which in your case is the internet. Your house with your 2 pc's and networking equipment would be considered a Lan, local area network.
The 4 ports on the router are switch ports, when you hook the modem up to the switch instead of the wan port the modem will only allow traffic from one physical, (MAC) address to pass through, this is why only one of your pc's can access the internet. The wan port on the router has its own MAC address, so the modem will associate with the wan port and trust all traffic that comes from that port.
Finally, after you have connected the modem to the wan port, pull the power cord on the modem then plug it back in to reset it, this will force the modem to orient with the wan port.
Jun 01, 2008 | Computers & Internet
Hi I Have Problem
Hi Andy,
The WAN port on your Aztech DSL600EW (by default) is configured to be automatically assigned an IP address when connected to a cable modem (Motorola). Connect the WAN port of the Aztech DSL600EW to the Ethernet port of the Motorola, then configure the Aztech for wireless connectivity to your laptop as per the manual instructions.
Apr 18, 2008 | Computers & Internet
No internet connection through router D-Link DI-524
-Connect your router to the wall and connect your laptop to the router using a cable.
-Use Internet Explorer and type the following line in the address bar: http://192.168.0.1
-You should see a Username and Password Screen...type admin for the username and leave the password blank, unless of course you did give it a password.
-Next you should see the D-Link setup page with tabs across the top that say Home - Advanced-Tools-Status-Help
-Click on the WAN button on the left side of the screen
-Now you should see the WAN Settings Screen
-Click on "Dynamic IP Address" (You should not use PPPoE)
-Click on the Apply button at the bottom of the screen.
-Now close your browswer and restart your computer.
-You should now be able to access the Internet...through the router cable and wireless
-Let me know if you need more help with any of these steps.
-Good luck...and I hope this helps!!
Jan 14, 2008 | D-Link AirPlus DI-524 Wireless Router
Dell Inspiron 1000 Notebook Logo
176 people viewed this question
Alun Cox
