Question about Dewalt 18 Volt Compact Drill Kit
Stays in the lowest setting
I had used it as a hammer drill for a couple of tiles. now it sounds like it stays in that mode but i can stop it with my hand
    Sergeant:
  • 359 Answers
If clutch type ,sure clutch is in an acceptable level
Posted on Dec 03, 2008
Drill slips when in forward drill mode, sounds like a gear is grinding on another gear. Does not slip in reverse or in hammer mode.
Dewalt XRP drill gearbox - YouTube
? 3:16
https://www.youtube.com/watch?v=s262yXyUYD4
Nov 23, 2011 - Uploaded by Ultimate Handyman
This is extremely useful if the gearbox on your drill is damage... ... i was using my dewalt hammer drill in the drill mode and suddenly got slower i though the battery was running out. as i ...Looking forward to the repair video.
Nov 22, 2015 | Drills
How do you drill through ceramic tile
Go to Lowes, Home Depot, Menards or reasonably good Hardware store. buy a ceramic bit. They are usually with the wood, steel and concrete bits. Small bits arent to pricy. If you need a larger hole like the on the shower pipe goes through, you will need a ceramic hole saw. Hole saws are coated with diamond chips and will probably cost $40 or more. good Luck
Oct 08, 2015 | Porcelanosa Ceramic Wall Tile: : Mosaico...
Dewalt 36v SDS 234 drill issue! Could someone please help? When I pull the trigger on the drill the motor runs but the drive only turns for about 1 second and stops even though the motor is still running....
DeWalt says:
Number of drilling modes
3 modes. Rotation only, hammering with rotation, or hammering only with rotation stop for light chiselling applications in tiles and plaster and impact stop mode for rotary drilling only in wood and steel.
Maybe yours is doing the second one?
Dec 02, 2017 | Dewalt Drills
Will it go back and forth as well as rotate?
depends on the drill. give me the brand and model number and I will try and help. Some hammers have a selector on the side to go from hammer drill to hammer and then drill only. Let me know and I will try and help
Jan 08, 2012 | Dewalt Drills
We are concernened about screwing the tub into the floor for stability. We have to go through tile and into wood. There are no instructions included for this. Included were 5/16 lag bolt and feet but we do...
The main reason to screw the feet to the floor is to keep the tub from moving which could cause the pipes to leak (either the supply or the drain) Authentic old clawfoot cast iron tubs were usually bolted to the floor because they were so heavy that it took a significant effort to move them, especially on a wood floor. If your tub is light enough that you could move it without a pretty significant push, then you had best bolt it to the floor in at least two places. Drilling holes through tile can be intimidating, but it's not as hard as you might think using an inexpensive masonry drill bit and a carbide tipped scratch awl. I will leave it to you to figure out how to assemble the claw feet to the tub, but here are a couple of important tips for drilling the holes through tile: Mark the hole locations with a felt-tip marker. Then use the carbide tipped scratch awl to gouge a starter divot in the tile. This divot can be pretty small, but it's essential for being able to drill a hole in tile in the right place. Use a variable-speed drill at fairly low speed to drill the hole - don't use a hammer-drill. Also keep a puddle of water where you are drilling to prevent the tile from heating up in one spot and causing the tile to crack. Once you get the hole through to the wood below, switch to a regular drill bit of a smaller size. Good luck, Al K
Aug 24, 2010 | American Standard Reminiscence...
Torque settings freewheeled 2 days now locked on lowest setting
on the gear box where you locate the torque setting/drill/hammer mark;
beneath that is a flattened spring in the shape of
,-----^-----, you have to remove the gear box and motor from the case
under the inverted V may have been a piece of hard plastic(i found a piece of plastic that looked like it would fit but had been pinched when
the original spring had split at the inverted V
Nov 23, 2009 | Hitachi Dv18dl 1/2 18v Hammer...
Drill works fine but wont engage hammer. the torque ring goes from 1 to 21 ok but i cant engage the drill or hammer setting
On my DW988 the ring would go past 21 a couple of clicks to a symbol that looks like a yellow T and that would be hammer mode when I press down to drill.
Nov 18, 2009 | Dewalt DC925 Cordless Drill
Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Oct 10, 2009 | Makita Drills
Dewalt 18 Volt Compact Drill Kit Logo
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
