Question about Philips 28PW9536 28" TV
Blue tint and lines on screen.
I have a Philips PW9527 CRT set which is about four years old. Recently, it has developed thin blue lines across the screen about half an inch apart which get closer together near to the top of the screen. These lines are across the full width of the screen except for across the middle where they start about an inch in from the sides. Also, the picture has a decidedly blue cast to it with blacks looking navy. I have adjusted the colour, contrast and brightness which doesn't help. The tint setting is set to normal and I have tried turning off all the picture enhancement features as well as disconnecting all peripheral devices. There are no speakers close by or any other electrical equipment. Any suggestions very gratefully received!
  • 1 more comment
  • David Wells Jan 20, 2007
    To add to my initial post, here is a photo of the problem. Hopefully you can see the lines and the background should be black!
  • David Wells Jan 21, 2007
    Many thanks henlopen! I have since been back to the shop who sold me the set and they weren't too sure what the problem was. They tried to suggest a new 'painter' chip at over £300! Presumably this chip contains the video driver circuits that you mentioned. It sounds expensive and probably terminal - either a new tube or a new chip. Uneconomical to repair either way. The voltages should be set correctly as I have owned the set since new and the back has never been off.
    Thanks again for the advice - it is very much appreciated.
    Good advice, Bill. Sounds like a repair would be a waste of money. I think you're right about the tube being on the way out as it is very flat as well as blue. The shop did say that the 'painter chip' was a common problem on Philips TVs. I think I will have a look at the new Toshiba LCD sets. I haven't had much luck with Phiilps or Hitachi in the past and I hear mixed reports on Sony so maybe I will get lucky with Toshiba.
    Thanks again, Bill. Great to hear from you. You obviously know your stuff!
    Kind regards
    Dave
    (Freddythefox).
    Sergeant:
  • 308 Answers
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
Posted on Jan 21, 2007
  • Bill Heronemus Jan 21, 2007
    Usually those Video IC's go out due to intermitent shorts inside the picture tube, so if you did go ahead with a new "painter chip" it would probably not be a lasting repair. I have seen this problem with Philips and Zenith sets before with some newer Sonys exibiting the same problem also. Something to keep in mind when searching for a new TV. Thanks for the good words!
    Bill.
Phillips tv has red tint across screen
This brand is known for getting discolored CRT cooling fluid in the blue and green CRTs. At 10 years old, it's almost for sure .. unless never used. A bit expensive repair. Don't attempt this yourself unless you're both a TV tech and a transmission mechanic ,, LOL.
May 31, 2014 | Philips Magnavox 51MP392H Rear Projection...
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Blue Screen with thin horizontal white lines
THI IS THE INTERNAL CIRCUTRY FAULT BEST YOU
call the service person and dont try to open it other than in side of TV SET HAVING Hazard of electrical shock be handle most care fully .
and check video board and all.
Oct 19, 2008 | Philips Magnavox 20MS233S 20" TV
Philips Magnavox 13MT143S
Hello.
I believe from your description that the vertical circuit has failed. either the IC or a capacitor. Sorry, but being only a 13" set I don`t recommend you repair it. unless you have a friend that would do it for you for the cost of the parts only.
Feb 26, 2008 | Philips Magnavox 13MT143S 13" TV
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Jun 03, 2007 | Samsung LN-T4665F 46 in. LCD Television
Philips 28PW9536 28" TV Logo
424 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
