Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Removal of dispenser assembly
Front cover plate removed. Is dispenser assembly just foamed in? Are there any more internal screws?
  • mymheichen Nov 29, 2008
    I broke off the water supply line , which feeds the water dispenser, at the bottom of the door. I'm trying to remove the water/ice assembly to get to that line. It seems to be held in by the spray foam, which we are trying to cut around.But it seems pretty solid and I don't see any other screws. Do you have any suggestions? Or would we be able to call you to explain the problem better?
    Got it. Thank You.
    Sergeant:
    Champion:
  • 291 Answers
Only the water hose is there going up to disp assy ,,,,,,,, lets start again ,,,, tell me what is going on and what all you have done so far / larry
Posted on Nov 29, 2008
  • Larry Youngblood
    Larry Youngblood Nov 29, 2008
    stop what your doing ,,,,, order or go buy a bracket dispenser part number 2304673 ,,,, the hose fits inside the front cover and the hose part slides thru a opening in the from liner ,,,, you cant dig it out they the liner ,,,, after you get the part the front cover snaps off the front by starting at bottom of cover and then you will see the hose assy ....... its gonna be some work but the part is cheap / larry
  • Larry Youngblood
    on the water disp lever there will be one screw holding the tube to it and after it is took loose the hose pulls up and slides out
I have a jenn-air jcd2389ges. The hole in the door where the ice comes down into your cup is broken. i believe the foam piece is busted
Here is a kit of the most likely parts that you are talking about=> 12001991 Ice Dispenser Solenoid and Door Kit Just disconnect the power and turn water off before beginning to ddisassemble the fispenser components seen here=> JCD2389GES Dispenser Components
1. Unplug the refrigerator power cord.
2. Remove the overflow grille from the housing.
3. Unsnap front cover at the bottom of the housing.
(using a flat blade screwdriver, and tape or pad, twist the screw driver, or pry out the bottom trim using the molded slots in the bottom of the trim panel).
4. Disconnect the front cover switch harness connector and set the cover aside.
5. Disconnect the power wire harness connector (BL/BK and W wires)
6. Disconnect the flapper door heater wire harness connector (if one is present).
7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart.
8. Disconnect the wires from the terminals of the lamp holder.
9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.
10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.
11. Unsnap the ice guide and remove it from the ice dispenser lever.
12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.
13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.
14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.
15. Remove the water dispenser lever.
16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly.
17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly.
18. Reassemble in reverse order.
Need Help let me know, Thanks Sea Breeze
Jul 02, 2012 | Jenn-Air JCD2389G Side by Side...
Tip
Maytag Square-Front (1998) and Sloped-Front (1999) Dryers Front Panel and Top...
Most of the internal components of Maytag Square-Front (1998) and Sloped-Front (1999) Dryers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip. Open the door then lift the front of the top cover and tilt it toward the rear of the dryer.
The internal components of the dryer can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Neptune Front-Load Washers. The only difference is the dispenser bezel removal.
on Apr 28, 2010 | Maytag Neptune MDE4000 Electric Dryer
Tip
Maytag Neptune Front-Load Washers Front Panel and Top Cover Removal
Most of the internal components of Maytag Neptune Front-Load Washers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the machine.
Remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Open the door then lift the front of the top cover and tilt it toward the rear of the machine.
The internal components of the machine can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Square-Front (1998) and Sloped-Front (1999) Dryers (Maytag Neptune Dryers). The only difference is the dispenser bezel removal.
on Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
May 01, 2011 | Refrigerators
Maytag front load washer Neptune MAH5500B codes FL and DO
There is an emergency access cord provided for the manual unlocking of the washer door and can be accessed by removing the dispenser bezel. Open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Once the bezel is removed, look for the nylon cord near the door lock assembly through the opening left by the dispenser bezel. Pull the cord away from the door lock assembly to pivot the mechanical opener and push the locking lever into the open position. Open and close the door several times then start a new cycle.
Check the door lock assembly if the problem persists and replace it when necessary. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Access to the door lock assembly requires the removal of the front panel, dispenser bezel, and lifting of the top cover.
Open the washer door and remove the two screws securing the door hinge and the front panel to the front shroud assembly. Do the same to the two screws on the opposite side of the door opening.
Disengage the front panel posts from the clips located on the face of the cabinet by grasping the upper part of the front panel posts and pressing in on the outer edges then twisting it inward. Once the front panel posts are released from the cabinet, tilt the front panel away from the cabinet and remove it.
Remove the two 5/16" hex-head screws securing the two top cover hold down brackets; one on each side. Swing the brackets to the outside to unhook it from the lip of the top cover then lift the top cover to expose the door lock assembly. Prop up the top cover to prevent it from falling back into position while accessing the door lock assembly.
Disconnect the wiring harnesses from the door lock assembly and the two mounting screws then rock the top of the assembly forward and lift it off the front shroud assembly.
Clean the wiring terminals and the connectors then reseat the connectors several times. Replace the door lock assembly when the problem is not resolved.
Install the new door lock assembly in reverse of the steps given above. Review the steps thoroughly for easy reassembly of the washer. Make sure the wiring harnesses are properly and firmly seated to the door lock assembly terminals. The door lock assembly is part number 22004435.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool model #GD25DIXH02. The front water dispenser tube cracked at the retaining screw. How do I change the filler tube kit?
Remove the top free door hinge cover and disconnect the plug there . This removes all power to the door . Remove the grill inside the dispensor , and remove the 2 screws at the bottom , holding the dispensor cover on . Lift the cover to remove , and disconnect the receptical , freeing the front . Next , remove the 4 screws holding the white dispensor switch mount , and slide out . Remove the screw holding the water fitting assembly .
Remove the bottom refrig kick plate . Follow the tube about 6 " to a connector , and disconnect the connector . The plastic compression nut , slips off the tubing after disconnecting .
Pull the dispensor tube , up thru the door from the top . Using the new tube with spout , pt number 4388152 . Insert the new tube into the hole from the top , and feed down , thru the door . Re-assemble in reverse .
Oct 26, 2009 | Refrigerators
BROKEN WATER SUPPLY LINE IN FREEZER DOOR
it should just snap off and on ,,,, something they are tuff to get loose
Nov 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
How can I get the case of my Singer Featherweight II open?
To remove the cover of the Singer model 117 Featherweight II sewing machine:
Referring to the diagram below:
1.Remove the face plate by removing the single screw fastening it to the left end of the chassis.
2.
To make things easier, remove the presser foot (raise the presser foot and release the presser foot from its holder by pressing the black plastic foot release found at the rear of the foot holder, the foot will fall off.)
3.Remove the plastic see-thru slide plate that covers the bobbin. Remove the bobbin, and remove the two screws that secure the needle plate.Lift off the needle plate.Don't mess with the feed dog screws( Look closely at the" bobbin case assembly" and note how it is installed. The black thing you are looking at is the assembly. The chrome thing that looks like a hook is a fixed "bobbin case stop plate" , the case assembly fits under that and is supported by the hook race. Approximately 180 degrees from the fixed stop is a spring stop- note that the bobbin case assembly is free to rotate/ wiggle approximately 1/8" between these two points, and it is seated evenly in the hook race.Remember what you see so you can reinstall it later)Remove the bobbin case assembly with your fingers.
4.Remove the detachable tool case from the front of the machine by sliding it to the left.
5.The face cover is fastened to the chassis with four screws- two on the bottom which also pass through the bottom of the rear cover, one behind the face plate just above the lower thread guide, and one on the front of the machine behind the tool case. Remove the screws on the front and the left end, and loosen the two screws on the bottom ( if you are planning to remove the rear cover go ahead and remove the bottom screws completely.) There is no need to remove the screws that hold the auxiliary leg bar.
6.The screws are out- HOW DO I GET THE COVER OFF!?!
There is a hidden locking tab located just beneath the mylar seal that warns you to disconnect the machine before servicing and to close the cover before operating the machine. It is located just to the right of the needle plate and directly over the seam that separates the front and back covers. Don't remove the seal just slice it with a razor blade or utility knife right along the seam, make sure you cut all the way through the seal.
Working from the needle plate opening, take a medium sized flat-bladed screw driver and slide it under the rear cover just behind the seam (see photo) carefully twist the blade in a manner that both separates and lifts the rear cover off the front cover- it takes quite a bit of force and it will let loose with a loud snap. After the locking tab is loose the front cover is easily separated and lifted off the chassis.
unlocking the case:
a closeup of the tab on the front cover
7.The rear cover is held on by three screws. There is one through the back at the handle recess, and there are two screws accessible from the front after the front cover is removed. Lower the presser foot lever, pull the screws and the rear cover will come off easy. Good luck with your repairs.
Nov 10, 2008 | Singer Featherweight II 117
Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
May 22, 2008 | Kenmore 53542 / 53544 Side by Side...
Maytag Neptune Door Boot Change
  Remove 2 screws holding door hinge to cabinet and remove door.  Then remove 2 screws opposite these. Grab front panel with thumbs at area of screws you removed and pull outward with thumbs. Panel will pivot forward.  Remove panel from lower clips.  At top of exposed area remove 2 5/16 screws.  Remove brackets under them.
  Open dispenser and remove 4 screws.  Careful not to drop in dispenser.  Remove dispenser frame assembly.
  You can now raise top of washer to a 90 degree position.
   Now back to front exposed area.  Grab boot where it contacts front and peel out of groove.  Also remove two screws holding light assembly and remove cover.  Remove all 5/16 screws holding front assembly and the ones on top area where it is on a bevel.  Remove front assembly by folding up and onto top.
  Now we are at the boot.  Remove spring and wire assembly holding boot to drum.  Make note on boot position and spring position.  Remove boot.  Install new boot onto drum.  wrap wire around drum with ends at top.  Now the fun!  Hook spring to on end of wire and using vise-grips,  pull to other end to hook into wire.  It can be done,  honest.
  Now just reverse to reassemble.  should be instructions with boot.   Good luck!
Oct 05, 2007 | Maytag Neptune MAH5500B Front Load Washer
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
183 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
