Question about Fisher and Paykel DEGX1 Electric Dryer
Dryer Model: AD55HK
The starting capacitor of this unit blasted. I need to replace it, but the rating of said capacitor is no longer readable. Can you please tell me the rating of said capacitor and where to buy it here in Singapore?
  • Anonymous Mar 30, 2014
    Capacitor chance
  • 144 Answers
Ok you need Fisher and Paykel Part number 427616 it's a 7uF PRL M8 Stud. But any 7 uF 240volt AC Capacitor should work AS LONG AS YOU CAN MOUNT IT SAFELY where it won't hit anything or fall off it's mount. cheers
PLEASE RATE MY ADVICE
Posted on Mar 25, 2009
    Novelist:
    Champion:
  • 244 Answers
Most mains filters are the same rating numbers just try 1 more than likely that it will work ill try and find u won and where u can get it from
Posted on Aug 11, 2007
Need part number for dual run capacitor for Armstrong Concept 10 air conditioner
The armstrong concept 10 comes in 7 different sizes. We need the model number off the outdoor unit.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 08, 2017 | Heating & Cooling
I have a carrier 38eh060330 outdoor ac unit. the fan does not work. I just hear buzzing, but I can turn the blade by hand. from the internet i learned that this is usually caused by a bad capacitor. there...
A capacitor only costs a few bucks. The condenser motor may tell you what MFD of capacitor to use. What you could do is 1. kill the power to the condenser 2. open up the electrical panel on the side 3. trace the motor wires to locate the capacitor. As you're tracing the wire, you may run across a low pressure sensor on the refrigerant line also. This would be a good start to diagnose where the problem is. If you're really going to be doing this, you should invest in a good multimeter.
Aug 11, 2011 | Heating & Cooling
I have an AMANA A/C unit. 31/2 tons. The capacitor is going out and need to have it replaced. will we need a 30 or 40 amp capacitor?
capacitors are not rated by amps, the are rated in microfareds, but that really isn't the issue, how do you know it is going out. The model number of the outdoor unit will be enough to determine the correct size capacitor if that is what is wrong. Mr. G
Aug 09, 2011 | Heating & Cooling
Blower fan starts fine sometimes circulating fan starts right away then after about 4 0r 5 min the small 3 amp fuse blows and shuts down whole unit. What is this fuse for and why does circulating fan...
Hi WFO9, It sounds as though the fan capacitor is under specs. It is probably losing its capacitance ability, they are usually rated plus or minus 5% of the value printed on the case. If however the capacitor is no longer within the rated specs. the fan motor will draw too much current and will then blow the fuse. either that or after the normal start delay built into the Ac, which is 3-4 minutes, the compressor tries to start and again draws to much current and blows the fuse. have all the capacitors checked and replaced if they dont meet the specs printed on the capacitor case. regards Col www.digitalcontrols.com.au
Feb 23, 2011 | Heating & Cooling
Capacitor problems!!
it's not the cap's fault that i see as the real problem,the cap is used to start the compressor and is rated for so many starts per hour and if you go over this rating it will stress the cap and after some time it will fail and this problem is known as short cycling and is normally caused by your thermostat.Or the unit is starting up under large gas pressure loads due to air in the system and or moisture and can only be fixed by a new gas charge
Apr 23, 2010 | Ruud Matching Split Air Conditioner
Dryer working to long to dry clothes
more than likely the belt needs to be replaced and the unit needs to be cleaned out (too much lint built up in the unit)
Apr 13, 2009 | Dryers
Frigidaire refrigerator model FRT21LRGW5-compressor sound is loud
If it is the compressor making that sound,The compressor is bad.
A fan motor can as make this type of noise as well when going bad.
If it is the fan motor stopping,this will also shut the compressor down,due to the thermal overload protection.
Please rate this a fixya.
Feb 01, 2009 | Frigidaire FRS26R4A Side by Side...
Fisher and Paykel DEGX1 Electric Dryer Logo
265 people viewed this question
Top Fisher and Paykel Dryers Experts
Craig Butler
Craig Butler
jimorris77
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
