Question about Siemens SpeedStream 2624 (SS2624) Wireless Router
Status light stays on. No internet on pc or laptop?
  • luddite42 Dec 30, 2008
    Status light stays on. No cable internet connection on PC.
Switch it off
Posted on Mar 12, 2009
What connection symbol should i see when my bt hub 5 is wired connected to the internet as it looks like a wifi symbol
The power light should be a steady blue.
This symbol indicates internet connection status and should also be blue.
Feb 12, 2015 | Internet Computers & Internet
My DG834GT/GTB shows as no internet connection on my laptop hoever the internet light is still green and solid on the router. Any ideas?
ok , first enter your web router page configuration and check the WAN status if connected or not , is not call your ISP .
if connected , check DNS , proxy , restart your pc , try another PC .
Mar 05, 2014 | NetGear DG834G Router
My dell latitude d630 I have pressed and held down the "FN" key and powered the laptop on. Firstly, all three status lights on ones and then stay off. What does this error light sequence mean?
the thing i LOVE about Dell is their completely transparent with their systems.
http://www.solano.edu/technology/data/D630/trouble.htm#wp1311135
Apr 18, 2013 | Dell Latitude D630 Notebook
My Compaq Presario F756nr will not turn on. The blue light to the power cord is on and blue light on front of laptop is orange but when you press the power on button it comes on then goes right off.
Hold the Power button and at the same time attempt to continually press the button for the CD/DVD drive. Continue until the status lights for power, hard drive and power button stay on for 3 seconds or longer. When status lights remain on, remove your finger from power button and allow the machine to boot as usual. Enjoy.
Feb 19, 2011 | HP Compaq Presario F756NR Notebook
WLAN orange light blinking
Wi-Fi base station: Understanding and resolving a blinking amber status light Your Wi-Fi base station status light blinks amber.
Here are some of the more common reasons that the status light may blink amber:
  • The Wi-Fi base station has not yet been configured because it is new.
  • The Wi-Fi base station has been reset.
  • A new firmware update is available for the Wi-Fi base station.
  • No IP address is available for the Wi-Fi base station.
  • A Wi-Fi base station in Extended Mode is out-of-network Wi-Fi range of a primary Wi-Fi base station.
  • The WAN Ethernet cable is unplugged from the Wi-Fi base station.
  • The Wi-Fi base station lacks a path to the Internet (or local router).
  • Internet access may be temporarily unavailable from your Internet Service Provider (ISP).
  • Your AirPort Time Capsule has detected that the internal hard drive has reported a SMART error, and is failing (This requires firmware 7.5.2, and AirPort Utility 5.5.2).
A persistent, blinking, amber status light indicates that your Wi-Fi base station may require your attention.
How to resolve a blinking amber status light alert
Launch AirPort Utility to determine why your Wi-Fi base station status light is blinking amber.
Apple recommends that you use AirPort Utility 5.5.2 for Mac, AirPort Utility 5.5.2 for Windows, or a newer version of AirPort Utility if one is available.
  1. AirPort Utility 5.2 or later opens automatically if your Wi-Fi base station requires your attention. You may also choose to launch AirPort Utility at any time.
    Do not use any version of AirPort Utility earlier than 5.0.
    In Mac OS X, AirPort Utility is located in the Applications > Utilities folder.
    In Microsoft Windows, AirPort Utility can be located by clicking Start > All Programs > AirPort.
    Note: You may also locate and download the latest Wi-Fi base station firmware and software by clicking here.
  2. In the AirPort Utility window, locate your Wi-Fi base station and double-click on it to open the Summary window. Note: If you have more than one Wi-Fi base station, double-click on the icon for the Wi-Fi base station that has the amber circle next to it.
  3. When the Summary window appears, double-click the amber circle to the right of Wi-Fi base station Status to open the Status window.
  4. The Status window lists any conditions that require your attention. Respond to each item until there are no more items listed.
    Important
    : You must reset the Wi-Fi base station using the reset switch to re-enable checking for the conditions you ignored.
  5. Eliminating the blinking, amber status light may require making changes to a specific setting, or putting a checkmark in the "Ignore" checkbox beside any option you don't wish to change. A checkmark simply tells the AirPort that you are aware of the issue and you have chosen to ignore it. For example, you may wish to leave your AirPort open without a password so that anyone can join your wireless network.
  6. Click Update to apply your changes (the Wi-Fi base station will restart).
  7. After the Wi-Fi base station has restarted, the status light should be green and not blinking. If the status light stays amber in color and blinks after the Wi-Fi base station restarts, you may repeat the steps above.
Oct 03, 2017 | D-Link (DI-784) Wireless Router
Won't come on, if plugged in and battery light
the reason why the light stays on is because the battery is charging. you can go to control panel in the power options and see the status of your battery. you might have a battery issue.
Jan 23, 2010 | HP Pavilion dv9000z Notebook
Battery not charging.
I have the same problem at times. The life of laptop batteries is short if you are always connected to the internet. To save battery power / to increase the life of your battery overall and during each use, disable the internet when you are not using it.
Click on your "Local Area Connection Status", which is usually represented as an icon in the task bar menu at the bottom (blue bar) of your screen. Open that up and then click "disable" whenever you are not using the internet.
Unfortunately, at this point you might need a new battery though.
I hope this helps!
Sincerely, CBR2009
Aug 01, 2009 | HP Pavilion dv6000z Notebook
Wont connect to internet
Ok ,,, from what I can see you move the little slider thing on the front of the laptop ( the one that opens the lid) and HOLD IT to the open position until the Wireless status light comes on. It should start looking for wireless networks as soon as it is enabled.
Dec 31, 2008 | Acer Aspire One AOA150-1570 Notebook PC
Laptop won't start-up
Can you tell me if the status lights on the power adapter and/or the battery turns on? Because you are telling me the status lights only stay on for 30 seconds, this should be a power connection problem.
One other possibility: can you tell me the climate environment of where you use your laptop?
Nov 16, 2008 | Dell Inspiron E1505 Notebook
The internet light turns off very often
If your DSL light goes off and comes back after sometime...then there is a possibility of issue with your Broadband service provider....there may be some outtage in your area.
  1. In order to confirm check the phone status when there is an issue?
  2. switch off and switch on the CPE ( some CPE has this issue)
Jan 15, 2008 | Zyxel Prestige 660R Router (91004397002)
Siemens SpeedStream 2624 (SS2624) Wireless Router Logo
99 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
