Question about Kitchen Ranges
My Frigidaire oven Bake and Broil won't work.
Both bake and broil went out at the same time. Element is still good. When I turn on the bake the control board ''clicks 3x''. Can some body help me out. The oven is on 1 1/2 year old.
thank you
2 Suggested Answers
  • 713 Answers
SOURCE: Oven's bake funktion does not work
Hi,You need to replace the oven igniter. You will find that this is a very common problem with that model and other models that use this igniter. It is very simple to do.
Look inside the oven and you will find 2 screws at the bottom of the oven in the back. Loosen them up and remove the bottom panel of the oven.
Remove the broiler, and oven trays and it is a 10 minute swap out. Removing the above items allows you the access needed to get to the two screws that mount the oven igniter to the burner.
Using either a socket (1/4") or a nut driver, remove the 2 screws and unplug the igniter. The most difficult part of the exchange is unplugging the igniter. The plastic will most likely break because it has become very brittle by being exposed to the heat. Be careful to break only the part that is being replaced.
If you do happen to break the fittings, they can be replaced with any male/female connector. If you need to replace this, I recommend that you stay away from plastic encased plugs.
You then install the ingiter, plug it in, and you are back in business. It is a very simple part to replace, but it is costly.
Thanks and take care
Posted on Apr 27, 2010
  • 842 Answers
SOURCE: bake element burned out on
HI,
You should have 120 to the element when not in bake mode, while in bake mode you should have 220 - 240 volt. Sounds like you lost a relay to send the additional power to the element, or you have a High Limit thermostat which could be open. This is a safety device to protect the unit from over heating, this only goes if temperatures increase higher the safety levels, normally set about 200 degrees or so along the air flow channels. I would trace from the elements to the clock and find the missing source of current.
I hope this helps
Be safe with electricity......
Posted on Jul 26, 2011
Testimonial: "Perfect! it was the high limit thermostat.Thank You for your help"
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Oven won't bake
Sounds like a connection issue to the control panel and the lower portion of the unit. Contact a professional to have the unit diagnosed unless you find the ohm reading to be off for either broil or bake element.
Dec 26, 2012 | Frigidaire FEF352 Electric Kitchen Range
Was cooking I'n oven. Heard a big pop sound and saw lghtning I'n tne oven. Now oven will heat a little but won't cook or broil ?
That sounds like the heating element went out when it first goes it could look like a lightning strike. Replacing the bake or broil element ,depending which one was on at the time will fix your oven. If you were baking replace bake element if ya werebroiling replace that one.
Reply with EXACT model number and i'll give ya the part number
GENE
Aug 27, 2011 | Frigidaire Kitchen Ranges
My bake or broil will not work but my stovetop works fine, as well as the clock and oven light.
Does the oven indicator light come on when you turn the oven on? Does the baking element or the broil element work by themselves but just don't work together? If nothing at all works did they stop working at the same time? Need to know to troubleshoot. Please reply with more info.
Feb 16, 2011 | Frigidaire FEF336BC Electric Kitchen Range
The lower element burned in my oven. I replaced the element, but the oven will not work.
unplug range ..remove the back cover plate check all wires all connections ..their must be a burnt /broken /dissconnected wire ..check where the wires connect to the bake an broil element ..and the bake broil switch..if all looks good .then the bake broil switch burnt out when element blew out..plus is the breaker tripped in the box ..it prob. tripped when the element blew out..let me know..good luck
Aug 28, 2010 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire oven not working in bake setting
Hi Thanks For The Question. I Would Check The Bake Element. Replace The Bake Element .Thanks The Appliance Doc
Oct 06, 2008 | Frigidaire FEF366 Electric Kitchen Range
Broiling works but baking does not work
CHECK FOR 240VOLTS AT THE TERMINALS OF THE BAKE ELEMENT. GAIN ACCESS BY REMOVING THE BACK PANEL OF THE RANGE. SOMETIMES THE TERMINAL WILL BURN OFF OF THE WIRE GOING TO THE ELEMENT. THE WIRE WILL JUST BE HANGING THERE. BE SURE TO UNPLUG THE OVEN BEFORE REMOVING BACK PANEL. IF THE WIRE IS BURNT, REPLACE THE TERMINAL AND REATTACH TO THE ELEMENTS TERMINAL. IF THE TERMINAL IS DAMAGED, REPLACE BAKE ELEMENT.
IF THERE IS NO VOLTAGE TO THE ELEMENT, REPLACE CONTROL.
Apr 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Kitchen Ranges Logo
107 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
