Question about Haier HRF10 Top Freezer Refrigerator
The fridge not cold
Dear Sir
My fridge is Service M781C. About one week age, the fridge is not cold. Could you tell me what is wrong please? I need to replace new one or just change some parts. or just is timer?
Thanks
Ming
4 Suggested Answers
drapplian119
  • 11 Answers
SOURCE: Our hotpoint fridge ran continuously without
I would agree that this is a thermostat issue. I would also clean the condenser coils.
Posted on Jun 16, 2010
heatman101
  • 43501 Answers
SOURCE: Fridge part of fridge freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
  • 2006 Answers
SOURCE: I just bought last week
Before you call for severcie you should run about 1/2 a gallon of water through the system to make sure the it is cleaned out and no air bubbles in the system. But if you do that and it still doesn't correct itself, then YES - call for service.
Posted on Aug 07, 2011
Why would an empty fridge turned on beep louder than the open door beep.The fridge back was very hot.(Tenants moved out a few days before)
there is a thermal alarm usually goes off if the fridge is not cold, and they do get hot on the back thats how they work, turning off for around 10min would reset the alarm.
Jul 11, 2017 | Westinghouse Refrigerators
HOW DO i TELL WHAT IS WRONG WITH A FRIDGE?
with a fridge of that age I would think that the compressor motor has died. It may be a capacitor if it is outside the compressor housing or an overload switch that can be reset but you will need a fridge mechanic to diagnose the fault properly. Be prepare for the bad news
Jun 25, 2014 | Kelvinator Refrigerators
Fridge not getting cold enough..
Depending on the age and the make and model it can be recharged. If you let me know I should be able to tell you or you can call Mt Hope Hardware at 330-674-7474 and ask for the service department. We will be happy to assist you. Thanks
Jan 20, 2013 | Refrigerators
The freezer is working extra well but the fridge is not getting cold even though it's set at 7
Check that the vent opening inside the fridge is not blocked. Depending on the age, some of them now have a filter that needs to be changed periodically. RepairClinic.com or Sears sometimes are able to give you an answer over the phone as to what else to check.
Feb 04, 2018 | Amana ABB2223DES Stainless Steel Bottom...
Can you tell me age by model # Whirpool ED25SMXL 25.4 cu ft
Thanks you for your question.
The age of your fridge should be a 1993 made the 25th week of 1993.
The age is determined using the 2nd letter for the year and the 3rd and 4th digits represent the week it was built.
I hope this helps you. You can also visit the link i have provided for your viewing.
http://www.electrical-forensics.com/MajorAppliances/WhirlpoolDateCodes.html
Aug 24, 2011 | Whirlpool Refrigerators
The fridge alarm will not stop. The fridge compartment is not cold and the freezer is just freezing. Since the problem started, have the fridge turned off for 3 days. Defrosted the freezer, turned it...
this alarm is activate if the temp. of the fridge rises and because the freezer section is full of ice form thats why affect the circulation of cold air. try to check the defrost timer if yuor unit have or heater if working if dont have defrost timer or heater try to lessen the setting of your themostat to cut of unit after reaching desired temp. or conduct weekly defrost manually.
Feb 12, 2011 | Fisher and Paykel Active Smart E522B...
Hi. I have a LG GRT382G in which ithe fridge is not cooling. Sitting at 8 degrees. We have defrosted it 3 times. Each time, it goes back down to 3 degrees, but a few weeks later it is not cooling again? A...
hello sir/mam
instead of blocking the pipe tell him to check the tempratur sensor and should be rectified it if necessary change the sensor.
Sep 15, 2009 | Refrigerators
Hi I have a whirlpool fridge the buttom don't stay cold an
This is most likely the defrost timer or Adaptive defrost system. I will need your model number to be able to tell you what your model has. The places to locate the model numbers are in the photo be.if a Sears model the numbers will look like this for example 512.3645897
Thanks, and let me know, Sea Breeze
Or just click
HERE
and enter your model number.
Aug 06, 2009 | Refrigerators
Freezer fan not working
Peace Friend,
ngfam1 At your service!
Ready?
If the freezer is cold and not the fridge, you need to make sure the freezer is filled to the top and covering the cod air vents and passages usually found in the rear or bottom rear of the freezer!
If they are blocked or covered whit packages the unit will not be able to transfer cold air to and from the fridge!
Yes, they share the air in most refrigerators!
What type fridge,model and age?
If not only a trained tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Sep 02, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Haier HRF10 Top Freezer Refrigerator Logo
62 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
