Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
My washer with a Model Number: MAH4000AWW keeps filling water no
Stop ,How I fix it?
Amigaman
  • 248 Answers
SOURCE: MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Posted on Nov 15, 2007
SOURCE: Top loading Maytag washer Model
When the machine worked would the machine stop in the wash cycle when you lift the lid? If so you might check your lid switch.
Posted on Jul 16, 2008
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
  • 62 Answers
SOURCE: I have a problem with a Maytag Washer Model Number
sounds like your belt is slipping and burning inspect that for wear. or you may have a pully prob
Posted on Oct 30, 2009
kel1guy2002
  • 3740 Answers
SOURCE: water keeps going and overflows
Hi and welcome to FixYa. I am Kelly
You will have to open the top panel for steps below
Water level control is handled by the water level pressure switch inside the top panel. It is about 3.25 inches in diameter, has 3 wires connected to it and a hose that looks like a small vacuum line.
Check that vacuum looking line for any holes, kinks or disconnects.
You will need about 3 feet of the same knid of line available from any autoparts store for this test.
Remove the machine side hose and connect the 3 ft hose you just obtained. DO NOT drop the machine hose into the machine.
Place the timer on the wash cycle and start the cycle
Result = fill
Force air into the hose orally until you hear a click.
Result = fill stop agitation begin
If it does not pass this test then the pressure switch is bad.
If water never stops flowing the water inlet valve has debris internally and will probably have to be replaced.
Don't forget to reconnect the machine side hose to the pressure switch.
Thanks for using FixYa!
Kelly
Then remove the vacuum
Posted on Feb 18, 2010
I have a maytag neptune, model MAH4000AWW The washer overfills, the water will not stop running.
Most likely is water inlet valve issue but could also be water level pressure switch or air dome tube. Check youtube for some great videos on repair.
Sep 24, 2013 | Maytag Neptune Washing Machines
The washer work but stop along the way,ie unable to complete the circle
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 13, 2013 | Washing Machines
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Front load washer filling up with water when off
if it's off or unpluged and still filling up you have a bad water valve,mark the hoses if they're not marked already so you know where the hot and cold fill hoses go after you change out the water valve on the washer,usually sediment gets stuck in the valve stopping it from closing and the water will keep filling into the washer,i've seen houses flooded from this,shut down the house valve that feeds the washer until you get the new washer valve.hope this helps and good luck,next time send the brand name and model number.
Oct 06, 2011 | Washing Machines
Water wont stop filling on wash or rinse cycle , complete flood
take out the two screws that hold the top console down,flip the console up and on the left side you'll see the water level switch,make sure the clear hose is connected to it,if that's off the water will keep filling into the washer,if it is on take it off and blow gently into the pressure switch or the water level switch and listen for a clicking sound,if it doesn't click you could have a bad water level switch,next,unplug the washer,disconnect the lid switch harness and with a screw driver pop the two metal clips holding the back panel to the top of frame,pull the frame backwards to you and remove the frame off of washer,have someone blow into the clear line and check for any pin holes in the clear line or see if it popped off the bottom plastic piece that it goes to.if it looks ok change out the pressure switch but if there's a hole in the clear line that switch won't work it can't hold pressure and the water will just keep filling up the washer and won't stop like it's doing now,send the model number and i'll look up your part for you,or call your parts store and give them the model number and order the pressure switch or water level switch,it's the same thing,let me know what you find
Jul 13, 2010 | Kenmore 22422 Top Load Washer
We have a ge washing machine model number WJRE5500G1WW. We were starting a new load of laundry and the washer was just filling with water. There was a loud noise we stopped the machine and it looks as if...
We have a ge washing machine model number WJRE5500G1WW. We were starting a new load of laundry and the washer was just filling with water. There was a loud noise we stopped the machine and it looks as if the entire central component that holds the washer separated from the metal shell. It is no longer suspended from the outer support framework
and is floating unsupported. Do you know what we should do to fix this
May 13, 2010 | Washing Machines
two problems here,
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water drip
There is a water fill valve that allows water in, mixes cold and hot water or shuts it off. Its location is where the hot and cold water hoses connect to the washer.
Get the model number off the machine and go to the web site below and you can see the valve and also the cost of the valve should you choose to fix it.
http://www.appliancepartspros.com/partsearch/
Good luck, let me know.
Regards,
Jul 31, 2009 | Washing Machines
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Sounds like you have an intermittent problem with the board or one of the on board switches.
Oct 22, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
