Question about Husqvarna Garden
Husqvarna chain saw stalls
I cleaned out carb adj hi lo set idle no water in gas new plug. runs good 15sec when i let it idle stalls out after 2sec
  • 211 Answers
Hi charlier 421
I think the small holes from the Venturi wall of the carb are clogged.To clean them you need carb disassembly.Near the needle there is a tehnological cover,under the diafragm(fuel pump).Taking off it you will see some small holes maiking conection with Venturi wall.Used ompresed air to clean them.
best wishes savumihai71
Posted on Dec 01, 2008
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I have a husqvarna 575 xp i can not get It to start and stay running. It has fuel and spark . Good spark but not sure on carb . settings.
the gas in the carb might bad might need to take apart and bolw out with some air and carb cleaner there are very tiny holes and the gas builds up a yellowish scale that can bolck the tiny holes i recomend a carb kit wich will give you new gaskets there are two adjustment screws on the carb if you take the spark plug out and it is wet you are getting to much gas and flooding it out try to turn the screws in if the screws have the little plastic caps on them remove them this will allow you to adjust the gas to the carb there is a hi and low the low is idle speed turn just enough so the chain dosent spin hi hold throttle down and adjust out till it will get wide open and sound clean no missing or struggling. i can post some photos of a chain saw taken apart to help you if you need it . please let me know if ther is any thing else i can do to help
May 25, 2011 | Husqvarna Garden
Husqvarna 55 rancher-just put new piston ring and cylinder.saw start right up and idles.when i try to acellerate it bogs and try to stall.when I let off gas it idles fine again.I tried turning mixture...
The plastic carb mount has a hole and a slot, this is the pulse channel from the cylinder to work the pump diaphram in the carb, if you look behind the plastic plate there is a tube that fits into the cylinder under the black induction rubber, this feeds a positive and negative pressure to the carb as the piston rises and falls, make sure you have re fitted the small seal in the cylinder that seals this tube or you will have big running problems.
Let me know if you need more help.
Mar 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
When you start the saw it runs for a sec then u hit the gas bogs then clunks out
Start with cleaning your air filter really well
Check your spark plug for a good solid spark that goes to the electrode and not to the side of the plug - if it fires to the side replace the plug
Has anyone fooled with the carb hi/low/idle settings?
Apr 01, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
While cutting the chainsaw bogs down and stops
Check the air filter and the muffler if either are plugged up it will not run smooth. Carb hi and low screws are very sensitive so if you change them, only move them a little at a time.
Jan 02, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husky 345 chainsaw will only run with choke almost completely out. New air filter, spark plug, and fuel filter. Also replaced gas.
turn both carb adj. screws out 1 1/2 turns from bottom and then fine tune them with it running. the one marked L is for low speed and the one marked H is for high speed. hope this helps
Sep 08, 2009 | Husqvarna Forest & Garden No.967012396 345...
Engine runs but wont idle!
set you carb adjustments at 1 1/4 and try that
Jan 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Saw will not start Husqvarna 350
Hi
An engine needs three things to run(fuel and air mixed together in the correct proportions,compresion of the fuel/air mixture and ignition).Make carb adjustments,check the compression and the spark from the sparkplug.Priming the engine(put some gas into the sparkplug hole).Try to start the engine.If engine is running only the gas from the cilinder,the chain saw has a fuel delivery problem.Disassembly the carb and clean the inner parts.Check the fuel and air filters,fuel hose and gas tank ventil.
good luck!savumihai71
Dec 04, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan 3700 will not keep running
SONUNDS LIKE WE STILL HAVE A CARB PROBLEM
Nov 23, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
478 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
