Question about Packard Bell Easy One Silver 2101 Notebook
Main board wont Power up
I changed the harddrive and tried to restart it but it wont power back on. it came on for a few seconds and went off. not sure wat to do or if there is a damaged chip onboard.
    Novelist:
  • 198 Answers
Hello.. i didn't quite understand if the problem occured after you changed the HDD and then became permanent. However the possible reasons are the same in any cases. Please note that a laptop mainboard can power on even without hard disks, ram , video card even without it's processor. That's because the motherboard itself "scans" for them AFTER it has been powered and the BIOS loaded (yep you can't start without BIOS)during POST (power on self test). If your motherboard can't power on now try the following. Remove the hard disk and the ram memory and try to power on. Of course expect beeps and errors from the BIOS, but if the mainboard powers and some LED's flash or do something, it isn't the motherboard who is faulty. Insert RAM and repeat the test. If it still works, then the hard disk you've installed is not compatible. IF however after removing both RAM and hardisk and the mainboard still doesn't power,surelly there is a problem in the DC charge/power on circuitry, that requires a specialised service to fix it. Hope this will be usefull and good luck.
Posted on Jan 20, 2007
Toshiba 46 inch regza yellow light blinks and picture wont come on but I have full audio
Most likely the power supply board needs to be replaced. It could also be the T-con board or less likely the display itself.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 21, 2016 | Toshiba Televison & Video
I have a Sony Bravia kdl-40xbr9, when I turn it on it shows no picture or sound , the green light and Sony logo turn on normally. When I take the power cord out and put it back again , the Bravia sign and...
It sounds very much like a main digital board problem. Who advised you to replace the power[G] board and T'Con board; I don't know. I've went through this fault; a few months back with my carrier, but failed make it right because, the main board was not available either at the open electronic spare part market, or by the authorized service centre for Sony here, in my country. The people at the service centre asked me the set to be to their custody for repair; and I refused. They won't sell the main board outside; they say. What to do? It is still in my workshop.
So I advice you to contact the authorized service centre; in this case. Gopakumar Gopalan Google
Sep 17, 2014 | Televison & Video
My tv turns itself off after a few seconds or a few mins it just wont stay on
Good day!!!
That problem is usually have 2 causes..Its either power supply board or mainboard..
Please take this steps on how to determine the problem:
  1. Open the back cover.
  2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
  3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
  4. If the power supply output is normal..The problem could be on the main board...
  5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
  6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope thissolution will be helpful..
Thanks for using fixya...
Aug 12, 2011 | Televison & Video
Dell 4400 Main power in house went off while using my computer and then went back on about an hour later. Now when I try and restart the PC, the power button light turns yellow like it is in sleep mode...
The power supply or mother board probably went out. Did any other items in the house stop working? This happened to me years ago and the electric company reimbursed me for damages.
You can try unplugging the power cord for a few minutes, then retry listen for any beeps from the computer. If it is powering on but nothing on the screen and no beeps *********** board is probably toast.
Dec 10, 2010 | Dell Dimension 4400 Power Supply ** FREE...
My HP compaq nc6000 wont turn on, a orange light comes on at the front but wont power on, it doesnt have an internal battery only runs from main power supply.\r\n Please can someone tell me what the...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jun 08, 2010 | HP Compaq nc6000 Notebook
When powering on the tv it maintains power for only a few seconds and shuts off again. Than it wont power back on untill you unplug and replug it n again. than it does the same thing, shuts back off after...
Power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.The power supply board,that the board where the power a/c cord plug into it.
Jun 07, 2010 | JVC LT-42X688 42 in. LCD HDTV
Computer will power up but won't boot
It seems you have done things i would have done to find the problem.
Have you check the switch mode power supply?
Leave the components connected (test under load) and power up and check the voltages on oe of the power plugs (4 pin), the voltages for 12 volts (yellow wire) and 5 volts (red wire). The 5 volts is the most important power supply, it is for the electronic circuits. If the voltages are below 10% then this could be the problem.
Nov 25, 2009 | Computers & Internet
Restarts as I power up
does it restart when you power IT up or your computer?
Jun 13, 2007 | Brother MultiFunction Center MFC-440CN...
Packard Bell Easy One Silver 2101 Notebook Logo
119 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
