Question about Dryers
Hotpoint CTD00 Cracked intermediate tank
Hi, the lower left tank at the rear of my CTD00 is cracked, is it possible to replace it as it looks to me like the tank is part of the whole base.
  • 135 Answers
This is part of the main frame. the only fix is to smear with silicone sealant. i have done few of these with success.
thankyou for using Fixya.
Posted on Nov 30, 2008
Plastic refrigerator floor is cracked
No reason to replace refrigerator. Such a crack would have nothing to do with items feeezing in drawer. Cold air naturally sinks. Maybe try setting control a little lower.
Nov 17, 2017 | GE Refrigerators
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Jan 12, 2013 | Washing Machines
Our Hotpoint ctd00 keeps tripping the fusebox, we
Disconnect the heater thermostats by poulling a wire off each stat, and then try it, if it still trips, then could be faulty motor.
The stats are located at the rear of the dryer, behind removeable cover.
Mar 25, 2010 | Hotpoint Dryers
My hotpoint ctd00 wont heat up
I would suggest that you check the heater and thermostats, these are located behind a removeable cover at the rear of the dryer.
You will need a meter to test them with, you are checking for continuity
Feb 10, 2010 | Hotpoint Dryers
Hi, My Hotpoint CTD00 Condenser Tumble dryer makes a thudding sound with every revolution, sometimes it sounds like a pair of trainers are in there! What could be the problem?
Could be a worn drive belt, or more likely to be a worn rear drum bearing, common prob with dryers, you need to remove top cover, and look for anything obvious.
Please rate my solution.
Thganks.
Nov 02, 2009 | LG DLE2514 Electric Dryer
Hotpoint vbxr1060 spins but won't agitate
OK, this oil is defiantly coming from a busted transmission(gear box). you will need to replace the gear box asap. the housing has failed. its cracked and leaking oil. This will damage the clutch and prevent the agitation effect. the gears will eventually lock up and damaged the drive assembly if not replaced soon.
Jun 10, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Tumble dryer not heating/drying
To check the element and stats, you need to remove the rear panel of the dryer, there you will see the stats and the element, you need to check for contin uity with a meter set on the ohms range, do it with the stats disconnected, or you will get a false reading.. if one of the stats has gone, then you must replace both of them.
Check thst all filters are clean ,air intake and outlet clear, and wash the lower fluff filter out under a running water supply.
If still no joy ,then could be a control unit prob..
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
82 people viewed this question
Top Dryers Experts
Marvin
Marvin
