Question about Kenmore Vacuums
Won't work for carpet
I have the Kenmore cannister progressive model#11629812991. When I turn it to carpet to clean, it doesn't change. In the past when this has happened I just take it apart and clean the hair out. This time it still won't work and the overload reset button doesn't work either. Also the powermate Jr. has not worked for about a year. Help!!!
    President:
  • 1,673 Answers
You could have a bad switch in the handle on the hose, may also be that the female plug at the end of the handle has broken loose inside and has gotten pushed in to far for the male connector on the want to reach it and cannot make a good connection. The switch and wire hartness come together when you order it. If the plug broke loose, you can either glue it to the tube or replace the tube.
Posted on Nov 30, 2008
High pitched sound when power on
I had a vacuum cleaner that did the same thing. My vacuum had three suction levels. The noise level would decrease as I lowered the level. I also noticed that when I turned the vacuum off the sound didn't stop instantly, it wound down/faded off as the motor slowed down. I found the problem to be the bearings in the main motor. I've been told that the motor that powers the carpet brushes can also make the sound if the motor bearing fails.
Dec 29, 2012 | Kenmore Progressive Bagless Upright with...
Carpet roller brush will not turn
You probably need a new belt. You can get kenmore belts here:
Kenmore Belts
Jan 02, 2010 | Vacuums
I have a Kenmore progressive cannister vacuum cleaner.
There should be a pile height pedal on rear of the attachment, just behind the where the wand goes into it, near the handle release pedal. Just keep clicking on it to go through the height settings.
Please rate if this helps :)
Mar 05, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore Progressive cannister electric motor will not operate. Is there a fuse blown or some other reason? All filters are clean. Power works to wand only.
Apparently there may be a fuse in the canister itself, I have no instructions for getting to it though. There's another post on here you might want to check, perhaps that person can tell you how to get to it
http://www.fixya.com/support/t1581380-kenmore_progressive_canister_vac
Feb 20, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
Vacuum won't come on
The switch in the hose maybe bad, motor problem, or some of these cannisters have a relay mounted by the motor, it may be bad.
Mar 16, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Carpet attachment
Check the plug ends at the top of the wand and the plug going into the hose handle, also at the bottom of the wand. It sounds like they may be burnt, if so they will need to be replaced. One cause of these connections going bad is not turning the power head off when connecting or disconnecting. Therre are other causes, the switch in the handle is going bad, also some of these cannisters have a relay mounted by the vac motor, sometimes they go bad.
Mar 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore Progressive Motor is not working.
Could be a number of things, cord may be bad as well as a problem with the motor. There also is a fuse that could have blown. If you go to sears.com, click on parts, put in your model number, when the page loads, click on the first link and you will have a parts list, and scroll down there will be a parts break-down picture that you can look at. You can also order parts thru the Sears website.
Feb 28, 2008 | Vacuums
Kenmore progressive vaccuum
Did you replace the hepa filter with a new one? Those filters may not look bad, but after a period of time and use, air is restricted thru them. They should be changed at least once per year.
Sep 03, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore Bagless Issue
after cleaning the filter,replace the bag.But this time before you close the lid,make sure you remove the hose.after the lid is closed then put the hose back on.
leaving the hose connected to the lid after closing will create a gap between the bag holder and the bag.so just remove the hose first before changing the bag
Jun 16, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
147 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
