JVC TU-DB1SK : Unable to setup basic freeview
Trying to setup freeview box JVC TU-DB1SK manual with Masterplug 4-in-1 remote without a code - any ideas?
  • b_hurd Nov 30, 2008
    The problem is that in the manual provided there is no code for the unit JVC TU-DB1SK and hundreds listed for all the other manufactures products. Can you not provide me with a code for this unit (JVC TU-DB1SK)? I look forward to receiving your reply many thanks.
    Cheers Matey
  • 4,806 Answers
1050 1071 1199 1259 1280 1315
Press and hold TV until the LCD blinks then try each code and in between press standby, when the TV turns off that will be the right code. May work for you, if not post back
kind regards
Posted on Nov 29, 2008
  • Lee Hodgson
    Lee Hodgson Nov 30, 2008
    i should be able to get the codes direct from masterplug via email on monday, keep your fingers crossed!!!
    regards
  • Lee Hodgson
    Lee Hodgson Dec 01, 2008
    ok been on to masterplug, they say to perform a "global search"
    do this:
    GLOBAL SEARCH REMOTE CONTROL PROGRAMMING
    This operation can take up to 20 minutes and should be carried out if you have not succeeded in programming the remote control by means of the other methods.
    Warning: program one appliance at a time!
    B.1. Power / Play Searching
    1.
    Turn on the appliance to be programmed. (TV, SAT, VCR, DVD)
    2.
    Press and hold the remote key (TV, DVD, SAT or VCR) for 5 seconds until LED starts blinking. Then release the button, LED keeps blinking continuously.
    3.
    When LED keeps blinking in step 2, enter the code 0000; the LED flashes more quickly to indicate that the remote control is ready for the search.
    4.
    Press and slowly release the POWER button repeatedly. Each time you press the POWER button, a code will be transmitted. When the appliance powers off, it indicates that the code is found.
    5.
    Press OK button immediately to confirm. LED will fast flash 3 times and then turns off.
    hope this works for you
    kind regards
Signalex remote codes for digilogic freeview box
038,033,032,036. Try these codes. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/ It has setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 03, 2014 | Televison & Video
Urc 11 1625 Bush freeview box code needed
It seems very difficult to locate codes to this device. Anyway If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 30, 2013 | Televison & Video
How to turn on curtis freeview box without remote my dog chewed
reset the code go to www.fitness.manualsonline.com or www. remotecodelist.com
God bless you
Jul 01, 2012 | Televison & Video
I cant make the freeview box work without the operating instructions
OK - please follow these instructions carefully to setup the Freeview box. If you get stuck at any point in the instructions - or anything I've said doesn't make sense or match what you can see - just post another message here and I'll deal with each problem as it arises.
1. Switch the TV and Freeview box to STANDBY. There should be a red light on the Freeview box;
2. Connect the aerial cable to the freeview box. Make sure you are connecting this to the correct socket. This should be labelled "RF IN", "IN" or "Aerial/Antenna". If you have connected to a socket marked "RF/TV OUT" or "TO TV" or something similar, it wont work;
3. Connect the SCART cable to Freeview box and the back of the TV;
4. Switch the TV on;
5. Switch the Freeview box on - you should get a green light on the front of the box;
Most TVs will automatically switch to the external input when a SCART device is switched on while the TV is already on. This is why you should switch the TV on first.
At this point you should be able to see the installation / setup screen for the Freeview box displayed on your TV. If you cannot see this:
A. Press the INPUT button once on your SAMSUNG remote control once. This is the button in the top-right corner of your remote control.
B. If you still cannot see the installation / setup screen, press the MENU or SETUP button on the remote control supplied with the Freeview box.
The instructions from this point forward will be different if you had to press the MENU / SETUP button on the Freeview remote before anything appeared on the TV screen. If this Freeview box has been used before the installation screen will not appear, but you will get at on-screen menu after pressing the MENU / SETUP button. If this happens, please let me know and I will provide alternative instructions for setup.
Assuming you have been able to access the installation screen, it should be easy enough to follow the instructions on screen from this point. Use the UP / DOWN / LEFT / RIGHT arrow keys on the Freeview remote to highlight the relevant options and then press OK / SELECT to choose that option.
I don't want to make this too complicated by providing alternative instructions for every possible scenario. Please run through the instructions above and make sure you are getting an installation screen or "menu/list" displayed on the TV. If you need further instructions from there, I will provide them in another message.
Good luck - I'll await your reply.
Regards,
BElectric
Feb 09, 2011 | Televison & Video
Total Control 4 wont work my freeview box
im looking for sagem freeview code on total control.
thank you
May 17, 2009 | Televison & Video
Remote control codes
Go to the masterplug website and call them, they'll send you everything you need via e-mail.
Feb 04, 2009 | Philips Magnavox Learning Universal Remote
Masterplug 4 in 1 remote control codes for Panasonic TV
Panasonic Codes:
1056
1107
1108
1147
1148
1149
1150
1151
1152
1199
1206
1321
Aug 22, 2008 | Philips Magnavox Learning Universal Remote
Hi the codes for hitachi are 0074,0082,0081,0511,0201,0616,0234,0236,0255,0232,0554,0110,0537,0075,0594,0147,0216,0143,0550,0518 turn on tv, 1.press tv button on the remote 2. press setup button until it flashes twice enter code then turn off by power button (keep repeating 1-3 until tv goes off) hope this helps.
Samsung vcr 0278 or 0455 as above. Angela.x.
Feb 22, 2008 | Philips Magnavox Learning Universal Remote
JVC TU-DB1
I Had this problem and found it was the power supply that had packed in so I replaced the supply with a Maplin LO6BR its the same switched mode 1.5amp type as JVC use
Oct 03, 2007 | Audio Players & Recorders
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
