Question about RCA 27R411T 27" TV
Picture goes out, sound stays on
After the tv is on for about 2 hours we loose the picture and it goes to a grey screen that says unusable signal.The sound stays on. It is getting worse. We have to turn the tv off for about 1/2 hour before it will work again. We have direct TV with Tivo. Please Help.
  • ellensum Mar 28, 2008
    I had the same problem with our tv - but now our tv wont turn on at all. there is no sound no picture but itstarted just like the above. first the picture would turn black and white then the picture would go black. but it still had sound. now we have a tv that we used less than 6 months that doesnt work at all. does anyone know if this was a defect in this model # and how can i fix it
  • Anonymous Nov 22, 2008
    We have three of these and all but 1 have done the same thing. We have another model also, which all 3 died after 3 years.
    Sergeant:
  • 308 Answers
I am not familar with that particular set, but this is what I would check (assuming you don't have a surround sound system hooked up to it as it would sound like a tuner problem otherwise). If you have external Audio/Video jacks with cables hooked up to the Direct TV box, move the video cable and see if you lose video when it is jiggled. If so, you either have a bad cable or connection/connector. When you say you have to turn the TV off for about 30 minutes, do you leave the directTV box on? If so, then the problem seems to be with the TV. Otherwise, maybe the direct TV box is at fault -- leave the TV on and turn off the cable box for a half hour and try it again. You have a few possibilities here, good luck.
Posted on Jan 22, 2007
32 inch LCD TV samsung series 5
If there is sound, no doubt, its signal input is OK. The problem must be to your Tv itself. If the LVDS cable, the cable that connects between the T'Con board and LCD panel have a loose contact, this type of faultcan occur. Re-seat this cable once, and check. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Hundred Thousand viewers cannot be wrong.
May 05, 2013 | Televison & Video
No picture on intermittent basis -
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 27, 2012 | Vizio GV47LF Television
I was watching my TV last night and the screen went to grey. I tried other channels and they appear with the station but the screen remains grey. I can get a picture through the DVD recorder and it records...
Generally in these cases that means it's a faulty cable or loose connection.
On LCD's if the screen dies or anything internally for that matter, the screen would stay black. Grey means a signal is coming through, but it's being able to receive it.
Solution:
Check your cables for any loose connections or try alternate cables going to your tv set.
Hope that helps. If you need anymore help let me know :)
Regards,
iMatt
Apr 06, 2011 | Sony Televison & Video
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
61" RCA Projection TV, no picture, "unusable signal" message
Read the suggestion of unplugging the TV for at least 4 hours to re-set to factory specs and that took care of it!
Apr 03, 2008 | RCA HD61LPW165 61" Projection HDTV
"UNUSABLE SIGNAL"
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Jan 07, 2008 | RCA HD65W140 65" Rear Projection...
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
RCA 27R411T 27" TV Logo
169 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
