Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Follow this article to fix the
issue..
http://www.windowsguru.org/solutions.html
There are several causes of Code 39 errors:
Recommended resolution
Reinstall the drivers for
this device.
Uninstall and reinstall the driver
Uninstall
the driver from Device Manager, and then scan for new hardware to install the
driver again.
You may be prompted to provide the path of the driver.
Windows may have the driver built-in, or may still have the driver files
installed from the last time that you set up the device. However, sometimes, it
will open the New Hardware Wizard which may ask for the driver. If you are asked
for the driver and you do not have it, you can try to download the latest driver
from the hardware vendor’s Web site.
PIONEER DVD-RW DVR - 110D
SOURCE: Installing DVD-RW LiteOn iHAs124-04 b
make sure
that the dvd burner is getting enough power test all leads that are attached to
the dvd burner including electical extensions and make sure they have a secure
connection or just replace them there might be
bad/faulty or
the drivers may have been corrupted or you might have a virus run your
antivrus program
you might have to physically unplug the leads for this cd/dvd drive
restart your computer then plug them
back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the
driver then reinstall for this device
Click start control panel administrive tools,computer management,device
manager scroll down cd-dvd rom drives you might see a yellow question mark
? right click you will have options to update driver,roll back driver,or select
properties general troubleshoot, select driver click to reinstall drivers
click update driver or uninstall then reinstall if this does not fix the
problem it might be a registry problem if you cant see your disk drive in
windows explorer Click on
Start, Run, and type regedit and press
Enter HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column. Upper
Filters Lower
Filters Upper
Filters.bak Lower
Filters.bak If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
Close all open
programs
Click on the plus signs (+)
next to the following folders
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone.
hope this helps
Testimonial: "The fix was editing the Registry and deleting "Upper Filters" & "Lower Filters""
i have a toshiba laptop with this same 30 code, how do i fix it?
sorry its a 39 code, can anyone tell me how to fix it?
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
i have a sony crx850e for no reason my laptop is now tell me it doesnt exist under code 39 please help
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) I have an hp 751 ca u solve this?
solution doesnt work
I got the code 39 as well. I can't figure out what happened. I know that it started after i got the windows service pack update but, i can't find any driver, it won't update because the driver is current. I also found that when i click the check for solutions button it shows up for about 3 seconds then disappears. That's it then it just does nothing.
