Question about PfaFF Sewing Machines
Changing light bulb in Hobby 1016
I CANNOT get my fingers close enough to insert a new bulb. It took forever to get the old one out, but inserting the new seems to be impossible. Is there an easy way to do this? I would gladly remove the casing but cannot see how to do this either. Thanks for you help.
  • corley46 Dec 01, 2008
    This is definitely a design flaw that needs to be fixed. Thanks for your reply.
I called my son in for help, and he managed to get the bulb in. There is no solution other than struggling with the blasted thing. Not a good design.
Posted on Dec 01, 2008
I removed the old light bulb and now trying to replace it on bernina 930. the bulb is the right one but it won't go in
Ah-ha--have had the same problem. When you remove the old bulb, there is a black flipper inside that is spring-loaded and closes. You have to hold that flipper open in order to push the new bulb into place.
Inserting light bulb into Bernina 930
Mar 12, 2017 | Bernina Sewing Machines
How is it possible to replace the light bulb in the Bernina minimatic 807? I managed to remove the dead bulb, but cannot install the new one
Try using rubber gloves, like surgical gloves and moisten them slightly. Usually, that will provide enough grip while trying to insert it. Very difficult from experience. But, can be done.
There is a bulb insertion accessory tool included with some newer machines (although not Bernina--another brand) that is basically like a cut-off plastic chopstick with a suction device on the end. If you are creative, you may be able to fashion something of your own.
Dec 22, 2016 | Bernina Sewing Machines
How do I replace light bulbs in a Bernina sewing machine model 1080?
Check the bulb model number old versus new and make sure you have the same number bulb. The bulb number should be on the base of the bulb somewhere. If the bulb has tabs sticking out of the base, check to see that they are placed such that both tabs are on the same plane on the bulb base. Some bulbs have offset tabs that only go in one way to the socket. Try rotating the bulb 180 degrees and insert it again to the socket before trying to rotate it. Check your manual for bulb replacement procedure. Make sure also that you didn't rotate the glass bulb out of its base when you pulled the old one out, leaving the old base still stuck in the bulb socket. If this is the case, unplug the machine and use needle-nose pliers to remove the old bulb base before trying to replace the bulb.
Jan 14, 2015 | Bernina Sewing Machines
How do i change the light bulb on singer model 7426 ?
You have to unscrew the cover of your sewing machine on the left top and once it is unscrewed you take the cover off and insert a new bulb and then replace the cover.
Jul 08, 2014 | Singer 7426 Mechanical Sewing Machine
Needle will not pickup bobbin thread
This is generally caused by either the needle being inserted backwards or by the needle being bent. It may not look bent, but be ever so slightly bent that you can't even see it with your eye.
The best thing to do is to change your needle, make sure you are inserting it with the flat side facing away from you in the shaft. See if this doesn't solve your problem. Good luck!
May 14, 2011 | PfaFF Hobby 4260
Need threading instructions for pfaff hobby 1016.
Try this page for Threading and Bobbin Winding Diagrams for loads of machines.....even if your model is not specified, there's a good chance you will be able to work it out from similar machines. HERE
Best Wishes Martyn
Bargain Box in Australia
Sep 08, 2009 | Sewing Machines
Cannot get to the lightbulb on an Elna SU sewing machine to chang
On the left hand side of the machine on the end cap.
Changing the Light Bulb
The sewing light is located behind the face plate.
UNPLUG THE MACHINE. Wait until the bulb is COOL before you touch it!
1 2 3 Remove screw cap , screw and face plate .
To remove: pull out bulb from socket.
To replace: insert bulb into socket.
Attach face plate and insert screw and screw cap.
NOTE: Replace bulb with same type rated 12V, 5W.
I hope this helps. Don't forget to rate my answer.
Jan 31, 2009 | Elna 2007 Mechanical Sewing Machine
Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Mar 31, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
116 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
