Question about Dishwashers
Whirlpool dishwasher g2p dw1 faults half way through cycle. Upon emptying. I think
  • daniboy06 Dec 07, 2008
    thanks for the interest.
    Model is a G2PDWI/1 WH
    I removed the waste hose from the waste and trap and put it straight out the the back door. System didnt fault and drained ok. As soon as put waste hose back in position fault accured within minutes. Could it be a pump problem?
    Many thanks
    Dan
  • eric bosman
    eric bosman May 11, 2010
    model number please
SOURCE: whirlpool dishwasher fault code f6
get a Maytag
Posted on Sep 05, 2008
onthejob5130
  • 640 Answers
SOURCE: whirlpool g2p dwi
either the latch thats on the door is bad,,or the catch on the tub is out of line,,,now if the dishwasher door drops hard and wont stay up ..you need new door spring and the weight makes it pop[ open..
Posted on Dec 24, 2008
SOURCE: Whirlpool dishwasher Fault codes
Fault code related to Flow meter. Cleaned the connections and reconnected.It worked fine for 2 weeks and failed again.Replaced the water chamber which contains the flow meter and the issue is resolved. The water chamber cost me 87euro including postage from Quinnspares in Co.Derry Ireland.
Posted on Jan 28, 2009
ginko
  • 19396 Answers
SOURCE: my bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Posted on Feb 07, 2009
SOURCE: Whirlpool DU 1050
Hi, I bought a brand new Whirlpool Gold GU2275XTVS that had the same problem after I installed it (standing water in the bottom after the cycle--although it would drain out if I pressed the drain/cancel button...not sure if that applies to you). It's less than a month old and still under warranty, so we had a technician come look at it but he couldn't figure it out. I've been searching these appliance repair forums for answers but found none that applied to my specific problem. I'll share what I found in a second, but first here are the most common problems associated with slow/not draining: 1) your air gap (if you have one) is clogged, 2) your drain hose is kinked or clogged, 3) your garbage disposal drain plug was never removed or the disposal drain is clogged, 4) your pump is damaged or doesn't run at all. There are a lot of appliance forum Q&As that address these issues. If you checked each of the above problems and still have the problem--especially if you have a brand new dishwasher and clogs should not be an issue--then read on...
I unhooked my drain hose and tried the simple "blow test" (just blow into the hose to see how difficult it is to force any water into your drain/disposal). If there is a lot of water in the hose it will be difficult at first, but after blowing water out it will get progressively easier. I discovered that it wasn't necessarily difficult to blow air through the hose, although oddly it got MORE difficult the harder I tried to blow air through. I then realized that the check valve (keeps drain water from returning to the dishwasher) was inside my drain hose instead of attached to the pump. If you have the same Whirlpool drain hose, the check valve is just past the first elbow of the drain hose where it attaches to the pump. I couldn't see it, but when I stuck my finger around the bend I could feel the valve. What's more, the valve flap was toward me--which means that it was (at least partially) closing off as water tried to drain out of the dishwasher instead of closing off any backflow. It came from the factory like this; luckily it was an easy fix. I simply pushed the valve flap through to the other side of the valve hole. Problem solved--it drains like a champ.
Hope this helps.
Posted on Apr 23, 2009
Whirlpool dishwasher just keeps filling? help please
check on the floor of the dishwasher on front left side. There should be a round float that is the overflow cut off. \make sure that it will go up and down. This is what shuts off the water.
Mar 07, 2014 | Whirlpool Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Whirlpool g2p dwi dishwasher putting specks of food on crockery and glasses.
The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure which can result in poor washing and leaving of specks. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Mar 11, 2012 | Whirlpool Dishwashers
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
Dishwasher makes noise during drain cycle
This really isn't a solution, but I found info on Whirlpool's site that the noise could be caused by the disposer and food or something in it. They said to use it a few cycles and see if the noise goes away, so that's what I'm doing. I always rinse dishes before going into the dishwasher, so don't really think there could be food particles etc. causing the problem, but we'll see. Not anxious to pay for a possible solution unless through a repair person. Thanks for your reply.
Jun 19, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Whirlpool g2p dwi
Feb 17, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
DWF 413 dishwasher
What about the pump, did you checked it ? Does it drains water out the machin ?
Jun 27, 2006 | Whirlpool 24 in. DU850DWG Built-in...
Dishwashers Logo
129 people viewed this question
Top Dishwashers Experts
