Question about Juki TL-98Q
My down needle and cutter are not working and though the motor runs, it suddenly will not sew. When I turn the wheel forward it will click once and when I turn the wheel backwards it will catch and stop. I cannot find any threads caught even with a flashlight. What are your thoughts?
    New Friend:
  • 186 Answers
Looks like you have spun your hook basket, unless you are familiar with the hook assembly you need a technician.
sorry!
Posted on Jan 31, 2009
Pfaff 7570 .. press foot to start...starts forward slowly ...will not stop without switching off power will not change speed ...will not select stitches
There could be several things going on with your machine, but once you take care of cleaning and oiling, you will be able to narrow down the other(s). Refrain from trying to run the machine as the drag on the motor in attempting to move the stuck parts could damage the motor.
Wheel on right side that controls the needle up and down is very tight...
Sep 17, 2017 | PfaFF Sewing Machines
How can I fix the needle assembly on my Bernina 930 Record...it all of the sudden doesn't move up and down?
There is a screw-in "hub", a round thingie, to tighten on the end of the machine, in the middle of the big spinning wheel. Hold the wheel and turn the hub clock-wise to tighten it ("Righty-Tighty, Lefty-Loosy).
It may be a bit tight to start with, they can "jam" open. Just turn it firmly as needed.
The reason the hub tightens and loosens is so you can run the machine quite fast when filling a bobbin up with thread without having all the gears and werkin's clatter as you do so.
Here is a VIDEO (better than just a photo, yes?) on how to operate your very model sewing machine! https://www.youtube.com/watch?v=drLD66Wa7U0
Aug 04, 2014 | Bernina Sewing Machines
Hyundai Sewing Machine not sewing all of a sudden
Does the light work? Does the motor make noise? Does the hand wheel turn? If the hand wheel turns does the needle move up and down? As you can see you need to be very specific before we can help you. There are another dozen questions you could save me asking with a better description of your problem. Have a great day.
Aug 28, 2013 | Sewing Machines
The needle on my model 1315 Kenmore sewing machine wont go up and down.
try turning the bobbin in the opposite direction & see if that helps
Jul 30, 2012 | Kenmore Sewing Machines
Arm wont move and needle wont go up and down any more in the middle of sewing, I was in the middle of sewing and all the sudden it froze up. It wont move any more and when you try you cant hardle move the...
Annoying solution, but works every time. Remove the ENTIRE bobbin casing from the base and then turn the wheel. The needle should lift right out. Reassemble bobbin casing and oil very well.
This generally only happens when you are sewing through several layers of fabric or though a thick fabric. If you are doing neither, the timing in your machine may be off and you will need to get it repaired.
Jul 04, 2010 | Singer 3116 Simple
Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
Dec 12, 2009 | Kenmore Sewing Machines
The side wheel controlling the needle/the sewing has suddenly gone very stiff & will only turn forwards not backwards. I have been sewing through polythene not fabric. Is it this which has caused the...
DO NOT LUBRICATE THE MOTOR!! The machine needs to split, ie the outer casing needs to be removed, inspected, and CAREFULLY lubricated. It also might be that as you have been sewing heavy fabric you could have knocked the timing out.
Oct 13, 2009 | Bernina Sewing Machines
Machine stopped sewing
The thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
May 28, 2009 | Sewing Machines
Sewing machine arm wont come down
You need to remove bobbin case and turn hand wheel backwards and forwards by hand till needle comes up and remove race hook cover and hook....remove all thread remands.. and reassemble.
Apr 01, 2009 | Singer 3116 Simple
Wheel won't turn
The same thing happend to me with an older model (Singer XL 10). I have been sewing a decorating stitch and the machine stopped suddenly. Now I am not able to turn the hand wheel anymore like I should (I can move it a little bit, but the needle does not move up and down and the wheel is getting stuck). When I try to use the pedal the motor makes a horrible noise and stops. The needle is not moving up and down.
Is there a solution for that problem? I moved from Europe to Australia and have not used my machine since. Today is the first day, I was cleaning and oiling it and it first sewed perfectly. In case that there would be thread stuck somewhere, how could I possibly clean that? I already took off the plastic from the head, but I can not see where the problem is.
Any help is appreciated. Thank you!
Best regards,
Nelly
Jan 12, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Juki TL-98Q Logo
104 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
