Question about Jl Audio E1200 Car Audio Amplifier
If my jl amp e1200 is on green, but no power is going to the sub
Everything in my car was hook up two days ago and my e1200 amp was working fine with my jl w3v2, until all a sudden, it just stop bumping. The fuse were not burn, the amp is still on green when turn on the car, but the wire from the amp to the woofer does not have any power going to the woofer. My amp does not smell like it is burn and it still turns on green, my woofer is not blown because i have tried it in my friend's car and it works, but somehow there is no power from the amp to the sub, what do you guys think it is wrong.
  • Mistakaotic Dec 05, 2008
    hey where are the fuses on this amp?
  • mcloven85 May 03, 2009
    mine does the same thing, has power to amp but no sound,although mine does not have a fuse unless it's on the inside which it shouldn't so therefore i don't have a clue what is wrong with it!!!! if anybody has any suggestions feel free to contact ma at mcloven85@aim.com.. thankx
  • 160 Answers
Your audio wires from the head unit have been pinched or discontected or the head unit is not putting out a signal
Posted on Dec 01, 2008
When i turn my volume up to a certain point the power light on my amp will blink off and on and the subs will cut off...what could be some possible solutions? is the amp not suppose to be tuned up? it...
Sounds like you are showing too low of an impedance load to the amp. The E1200 is only stable as low as 2 ohms. If your subs are wired to show lower than a 2 ohm load then the amp will go into protection mode as the volume or gains are turned up
Dec 23, 2010 | Jl Audio E1200 Car Audio Amplifier
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
I have a jl 500/1v2 and when i have the volume up for some time it teens to turn the amber color light on and turns off my amp and sub i turn down the volume for like 30 sec turn it back up and every thing...
its probably wires touchin or the ground not connected well with fat enough wire. i would try to rewire and do everything all over again because one wire or fuse is messing up i had t he same probelm. its the red light on the amp is ur amp shut off or ur warning light?
Jun 03, 2009 | Jl Audio E1200 Car Audio Amplifier
Wire three 10" jl subs to jl e1200
what is the impedance of your woofers it will be a number with an Omega symbol. Looks like a horseshoe next to your woofer . Like this JL Audio 10W1v3 8ohm. Please, Please tell me you bought 8 ohm woofers JR?? Because if not, it ain't gunna happen.. If you did buy 8 ohm woofers than wire them in parrellel which means all the +'s together and all the -'s together giving you a final impedance of 2 ohms and your amp will think your a car audio GOD... But if not be ready to smell plastic burning where your amp used to be.... let me know i can walk you thru the wiring but let me know what you have. ok. mark
Mar 18, 2009 | Jl Audio E1200 Car Audio Amplifier
My jl e1200 is very distorted
check your groud make sure theres contact and check your rca's
Mar 15, 2009 | Jl Audio E1200 Car Audio Amplifier
Will a jl amp e1200 kick a jl woofer 12w3v2 loud
yes a 1200 watt amp will do the trick.. the problem would be in the box the 12w3v2 sub needs a good size box and you should have one made for your car. and yes you will get the bass you want
Nov 16, 2008 | Jl Audio E1200 Car Audio Amplifier
Have a jl 500.1 amp
for that amp u need a compasitor to mantain the amps the amp draws the amp is being choked when the car is off and when its running its killing the cars charging system
Jun 25, 2008 | Jl Audio E1200 Car Audio Amplifier
Amp wont turn on
It's possible the ground is not a good connection. Sometimes it may look good but dirt or corrosion builds up resistance creating a voltage drop where the wire is grounded to the frame.
Jan 26, 2008 | Jl Audio E1200 Car Audio Amplifier
Only works for RADIO!!!
You're using the wrong control lead. There should be an amp control lead. You're using the power antenna lead.
Oct 31, 2007 | Jl Audio E1200 Car Audio Amplifier
Car amp's stopped working. Putting out a heart beat sound through subs but no bass.
could be low current ,disconnect all power including ground for 20min N.B most amps will seem to be shorted at output but this is normal due to damping ratio.
Jun 11, 2007 | Jl Audio E1200 Car Audio Amplifier
Jl Audio E1200 Car Audio Amplifier Logo
387 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
