Question about Dell Inspiron 5160 Notebook
Dell Inspiron 5160 flashing orange / green power LED
Hi Pals, my name is Eduardo Morales and I have a Laptop Dell Inspiron 5160, When I connect the charged adapter only flashing orange / green power LED and press the power on buttom and not turn on the laptop.
Please some help-
Thanks
  • 2 more comments
  • HarryJames00 Feb 21, 2009
    Same problem, Green & Orange flash every 5 seconds and will not turn on. Anyone have a meaning of flashing error codes for this laptop
    Harry
  • dbsimmons Apr 23, 2009
    My 5160 will flash 4 Orange and 1 Green. I changed the power plug after it wouldn't charge at all. After that it wil charge but still flashes. The fan will not run also. I just restored it in hopes of fixing that along with other things. It fixed everythign except these. Any ideas?
    Thanks
  • Anonymous Mar 25, 2014
    Hi I have Inspiron 1545 laptop 5 years old,and i m facing 7 beep issue where system power LED is glow and fan rotates for 15sec then off, odd lights also bling for 15 sec only.plz help me and tell how to fix this issue
    President:
  • 1,223 Answers
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Posted on Mar 07, 2009
Battery light
Remove battery and try to power on the laptop.. If it powers on and boots up then the battery needs to be replaced.
Aug 18, 2013 | Dell Inspiron 5160...
Dell Inspiron 5160 doesn't charge
you mite have fried the power supply. or the battery.. try removing the battery and pluging it in,and then power it up
Jun 13, 2012 | Dell Inspiron 5160 Notebook
Battery led blinks orange on dell inspiron 5160
if the battery LED blinks orange, most likely there is a problem with the battery itself. Try to remove the battery and have the power cable connected to it. If there is no battery LED blinking, call Dell to replace the battery itself..
Aug 20, 2011 | Dell Inspiron 5160 Notebook
Front right led flashes 3 orange 1 green ,system starts to boot and then goes to a grey screen with curser i upper right corner and just sits there. i can just touch pwr button and computor shuts down
the flashing Orange and Green LED is a terminal battery failure:
http://www.fixya.com/support/r3696096-dell_portable_battery_led_flashes_orange
The system not booting to the hard drive could be a HDD failure or a corrupt operating system. Boot to the XP CD, Press R at the 1st prompt to access recovery console, then run CHKDSK /R
Oct 12, 2010 | Dell Inspiron 5160 Notebook
I have a Dell Inspiron 9400 ,the batterie indicator on my laptop is flashing orange 3 times and then green ,with and without AC power
The battery is reaching End Of usable life. Time to get a new battery.
http://accessories.us.dell.com/sna/category.aspx?c=us&category_id=6926&cs=19&l=en&s=dhs&mfgpid=167671&chassisid=8448&~ck=anav
The above link is for the dell store where you can order battery.
Nov 15, 2009 | Dell Inspiron 5160 Notebook
Battery light flashes 4times orange then 1green
We had the same problem. I figured out it was NOT the main battery, but the auxilary battery. The batter life WITH the auxiliary was 68% total, when I removed the 2nd battery the battery life shot back up to 98% AND the flashing orange / red lights were gone (both on the power source and off). I then replaced the auxiliary battery with a spar back up to make SURE that it was not a fluke and with the new backup battery firmly in place the lights still did not flash. Problem solved.
Jun 17, 2009 | Dell Inspiron 6000 Notebook
Orange blinking power light on inspiron laptop
I recommend purchasing a new Dell Inspiron battery.
The code 4 blinking orange or amber and one green, means a defective battery.
Thank You, Raphael
Jan 24, 2009 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160 Black screen on power up
There is a small board that the power button is integrated into that connects to the motherboard. When this power board malfunctions it will cause this issue with the machine. It can, and quite often does, damage the motherboard when it malfinctions. You should take the machine in for a power board replacement and a diagnostic to make sure that the power board hasn't damaged the motherboard.
Jul 14, 2008 | Dell Inspiron 5160 Notebook
Laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Dell 5160 orange light
removed battery, and acadapter FROM UNIT, HOLD DOWN THE POWER BUTTON 60 SECOND That should drain the power from it
Mar 26, 2008 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160 Notebook Logo
3,039 people viewed this question
Alun Cox
