Question about Euro-Pro 9000 Mechanical Sewing Machine
Euro-pro 9110 Please help! I can't get my bobbin in the machine properly. I have inserted it the way the book says, but for some reason I can't get it in. Can someone please help me!!!
  • Anonymous Nov 19, 2007
    I cannot get the bobbin to load properly. Ive done everything the manual says but the top thred will not pick up the bobbin thread. Help
Make sure you put the presser foot down when you do this. I had the same problem.
Posted on Dec 16, 2007
SOURCE:
The needle is hitting the bobbin casing in the back. I have re-inserted the needle to make sure it is in properly. I have a Singer 248
Hello Beth
Check the following:
1. Make sure that the needle being used is the correct needle for this machine, refer to page 6 of manual.
2. Yes, insert all the way up ... with flat to the back.
3. Make sure that correct bobbin is being used for this machine. Bobbins not specific for this machine may/will cause problems.
4. Make sure that the bobbin is correctly inserted in the bobbin case. Refer to page 26 of manual.
A free downloadable manual is available at Singer Fashion Mate 248 Instructions Manual Page 31
Please give me a thumbs up if this is helpful, otherwise please send me more information.
Happy stitching
Sewingirl/
Jun 12, 2018 | Singer Sewing Machines
.janome 344lx bobbin stuck at top of cycle...bobbin handle appears to hit casing. Needle goes through cycle without bobbin. Worked last time 6 months ago. Any ideas?
Hello Harwood
From the pic, the bobbin is inserted incorrectly .... this is the cause for the challenge.
Insert the bobbin inside the bobbin case, so that the 'finger' of the bobbin case fits at 12 o'clock into that little notch.
Now all will work properly.
Please give me a 'thumbs up' if this is helpful.
Happy stitching
Sewingirl/
May 12, 2018 | Sewing Machines
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
Sep 17, 2012 | Bernina Sewing Machines
Top thread will not pick up bobbin thread
Your bobbin is not installed correctly.There should be an excess thread coming out of the bobbin. Second-the thread wheel is the other way around,it should be positioned to follow where the extra hair of thread is to be going.And once you insert it in you'll notice a snap and the bobbin is settled firmly and locked into the shaft.
Oct 31, 2010 | Singer CG550 Mechanical Sewing Machine
Sewing machine won't raise the bobbin thread
Hi. The two main reasons why the top thread doesn't pick up the bobbin thread is either the needle is inserted wrong or the needle is bent. Since your machine was sewing properly until the thread broke, I'd be inclined to think the needle may have gotten bent. Sometimes this can happen if you sew over a pin.
Change the needle (making sure the flat side of the needle shank is inserted properly for your machine) and see if that solves the problem. Let me know if it helps, ok?
Robbie
Jun 07, 2010 | Singer Sewing Machines
The bobbin thread shows
I am having the same problem and can't seem to find the answer. Please email me if you have found a solution!
Debr535@yahoo.com
Sep 30, 2009 | Singer CE-200 Quantum Futura Computerized...
Thread keeps breaking and i can't get the stitch setting to go from stretch stitches to normal stitching
Be sure to check that the machine is threaded properly into the needle. Also look at the instruction book to be sure you have the bobbin inserted corectly and that the thread is place properly (threaded correctly) in the bobbin area. Some machines have a diagram on the machine, but if you do not sew frequently; it's easy to mis-thread the bobbin. Did your bobbin thread wind properly onto the bobbin (not loose or loopy). That too, can be a problem. Best of luck. Susan
Aug 04, 2009 | Kenmore 756A-30BH Mechanical Sewing...
Bobbin thread won't "pick up" right
Check that you have the needle inserted properly i.e if the needle shank has a flat side make sure you have it inserted per your instruction book ... also make sure the needle is inserted all the way. Also double check that you are using the correct needle type.
Jul 06, 2009 | Sewing Machines
Re-inserting bobbin case on a Singer 4552 sewing machine
Same problem. No help at all from manuel. Just glad to hear others are familiar with problem. Thought it was just me!
May 10, 2008 | Sewing Machines
Inserting bobbin
Bobbin in your left hand with the thread leading off from the top, pop the bobbin in, put the thread in the slot on the bobbin case and pull to the back,
Jan 19, 2008 | Sewing Machines
Euro-Pro 9000 Mechanical Sewing Machine Logo
99 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
