Question about Samsung PCJ612R 61" Rear Projection Television
White box on lamp
There is a white box that is on the side of the lamp does anyone know what this is. What ever it is that is my problem thanks.
0 characters
1 Points
My panasonic projection tv wont turn on .i opened it up and theres a box on the right side that looks like its shorting out/sparking.does anyone know what it could be?
this is a lamp problem , the sparking u see on the box is the power supply for the lamp and is sparking because is trying to turn the lamp on , replace the lamp first before u do anything else
Aug 26, 2010 | Panasonic PT-60LC14 60" Rear Projection...
Tv turn off afterbeeing on for afew minutes
Nov 24, 2009 | Samsung HLN5065W 50" Rear Projection...
Shuts on and off constantly. Lanp light blinking. Sound but no picture.
I would suggest if you haven't done so alreay is replace the projection lamp. The symptom you are describing indicates a failing lamp. The lamp part number will be located on a orange and white sticker on the side and it will say LAMP CODE and will start with a number of BP96-. If the sticker is missing then you will have to remove the lamp from the TV and get the number off of the cage of it. Please take a moment to rate my answer. Thanks....
Nov 21, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Lamp will not come on
On the DLP televisions, if the color wheel is defective the lamp won't start up. First thing to check is if you are getting some kind of arcing noise in the lamp area. If you do hear an arc then suspect the lamp is bad first even though it physically doesn't look bad. The color wheel is part number BP96-00250A and is very common to fail on these older models. The lamp varies so that you will find an orange and white sticker on the side of the TV with a lamp code such as BP96-00224J, that is your lamp part number. Please take a few moments and rate my answer. Thanks..
Nov 21, 2009 | Samsung HLN5065W 50" Rear Projection...
Orange projection lamp on. Picture is a bluish green, no true white.
If you are in warranty contact Lg electronics since they own Zenith. I was having similar difficulties and they are sending me a replacement tv even though I am out of warranty by 3 years.
Jun 09, 2008 | Zenith D52WLCD 52" Rear Projection...
Sony LCD Grand wega black and white picture
12000 hours you are lucky most last 2000 hours
lamp not the usual suspect for this
confirm black and white on all inputs and it will be more sinister, if only one input, it could be the signal source
Jun 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Akai PT46DL10 Image in Black and White
If you remove the lamp, you will be able to see that the lamp is defective. In order to know if something else is defective, the new lamp should be install.
Let me know if you need further assistance.
May 26, 2008 | Akai PT46DL10 46" HDTV-Ready Television
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Apr 07, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung PCJ612R 61" Rear Projection Television Logo
Top Samsung Projection Televisions Experts
Steven Wander
Steven Wander
The Wyzzyrd
Donald Griswold
Donald Griswold
Level 1 Expert
Are you a Samsung Projection Television Expert? Answer questions, earn points and help others
