Question about E-Machines T1150 PC Desktop
T1150 emachine Computer not booting up correctly
I push power button and don't get any lights on the front of the computer. I don't get a signal to the monitor. However, both fans are running and it sounds like the computer has booted up. The fans start running immediately when I plug the power cord into the back of the computer instead of when I push the power on button.
  • Anonymous Mar 31, 2014
    power light on, fan runs
  • 31 Answers
Did you hear any beeps from the bios? Try to remove all the peripherals like all the PCI cards, specially the "video card", your ram's,. Once you removed and cleaned all of those, put it back,make sure that theres no loose connections and boot the computer.
Posted on Dec 01, 2008
Flashing light on front panel will not boot
Unplug the unit from the power at the wall socket. Wait one minute, Reconnect. Retry. Beyond that you'll have to check the hardware: memory, motherboard, internal power supply control, CPU, oh, and the microswitch behind the On button
Jan 16, 2014 | eMachines eMachine EL1333G-03W Refurbished...
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
I haved a Emachine EL 1300G-01W that has crashed
Power it down, pull the power lead out, remove the cover from the base and check that all the leads (to the hard drive and the motherboard) are seated correctly - by physically pushing them in. Then push and hold the power button on the front for 10 seconds. Then replace the cover and power lead and try starting it up.
Jun 05, 2010 | E-Machines eMachines Desktop PC
Have emachine T1150 - the on off button when pushed in is getting stuck and machine will no longer turn on. Can this be fixed and is it worth the cost ? Can I fix myself ?
The switch on the outer plastic front panel is usually just a plastic peice with a spring, it pushes the button in on the inside metal housing of the computer case, therefore not really much to worry about, you just need to remove the front panel to free up the plastic so it dose'nt get stuck in the hole, this is normally just caused through dust or resadue build up from your fingers when turning the computer on and off.
To get the front panel off you will have to remove the side panel, have a look to see if there any screws holding the front panel on, if not then it is just held on by expansion clips that expand with inserted into the metal houses of the case, just gentle ease away from the inner housing.
When you have removed the front panel just fiddle with the switch a bit and try to free it up, whilst the front panel is off you could try pressing the button on the front metal housing to ensure the computer does turn on.
when you have done this just replace the front panel and and put the case back together and you should have solved the sticky switch problem.
Mar 25, 2010 | E-Machines T1150 PC Desktop
I cannot boot up the computer. When I push the front power button, nothing happens. When I flip the switch on the back, or unplug it for 30 secs and plug it back in, the fan starts up and a yellow light...
I had this happen to my emachines T1842 about a year ago. I replaced the power supply and it worked fine. It was about 25 bucks but fixed my problem. Make sure the red switch on the back hasnt been messed with. it should be on 115. If you have moved it, it may have blown a fuse inside the power supply.
Feb 04, 2010 | E-Machines eMachines Desktop PC
I have a 3507 emanchines computer.When I push start button all it does is show green light clicking . Then it will stop and the white light will below will blink 7-8 times. The green light will click about...
sounds like an issue with your motherboard or something like that...try resetting the motherboard by unplugging the power, taking out the battery of the motherboard inside the computer and pressing the power button several times to drain the power. then put the battery back in, plug in the power cord and try to start it up. if it doesnt work then ur gonna have to contact emachines because ur mobo is either defective or broken...
Nov 12, 2009 | eMachines W3507 PC Desktop
Emachine destop not recognising acer lcd monitor
It sounds more like the computer isn't starting up. The "no signal" message is coming from the monitor itself to tell you it's on but there's nothing coming in to display. Normally no special drivers are required for the monitor, and you'd see at least the computer maker's splash screen and BIOS messages if the computer was starting up properly.
You'll need to determine what is keeping the computer from starting up. Make sure it's getting AC power and that the power light comes on when you press the front panel power button. You may need a power supply. If the computer comes on but doesn't boot you may have memory problems or trouble with the motherboard. But your monitor is working properly.
May 10, 2009 | Microtek C593 15" Flat Panel LCD Monitor
E machine T1150 wont start up
Make sure you have the memory installed correctly. Those beep codes identify it as bad memory. Try the old RAM.
Good luck with this.
Mar 19, 2009 | E-Machines T6420 PC Desktop
E-Machines T1150 PC Desktop Logo
169 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
