->Click the Settings tab. ->Click on Paper Size. A list of paper sizes will appear. ->Select the size you want. ->If none of the selections are suitable, select Custom. A box will appear inviting you to set your own measurements. Enter the width and length that you want. ->Click OK.
On the custom page box, you must first enter a unique name for the custom size that you want to set up. eg. Invites. Once you enter the name the "save" button will be highlighted. Save the name, then fill in the custom sizes and click OK.
Your new custom size will be under Properties/Features/Size/More
This is common with these printers. When you go to print and the kodak dialog print box comes up you need to change the paper size manually for the printer. The printer does not always take the correct paper size from the program you are printing in if it is a custom document.
another word of advice. USE THE TEST SHEET FIRST. This printer does nto correctly print invitations you need to offset the items about 1 inch to the right or so. Test before you print the real things.
Your program should have a section in page setup to manage custom sizes. Enter this size. set size in your printer dialogue box and away you go! Inkypete
I had this problem on the 6300 and was able to fix it by doing the following:
After selecting print, select preferences.
Select the Features tab.
Under Resizing Options, select "Custom" from the drop down menu.
Put in the custom dimensions of the paper on which you are printing.
Save it under a new name (e.g., "Invitation")
When it is time to print,
Select "More" from the drop down tab under Resizing Options.
At the bottom of the list of those options, you will see your custom sized saved.
Select it, and happy printing.
if you are printing from word 2010 and have an HP printer;
-set up your document on your screen how you want it to look, go into your print preview section, your printer should be listed towards the top of your page and directly under it should be "printer properties" click here, select the features tab in the next window and change your paper size to the correct size for your document.
-you may also need to go into the page layout tab in the main screen, select the size button, click on "more paper sizes" at the bottom of the window, select the paper tab and change the size of your paper again to the size of your document
-lastly, while in the "paper" tab window select "print options" towards the bottom right corner, left side of new screen click on advanced, scroll down to print and make sure there is NOT a check in the box that says "scale content for A4 or 8.5 x 11" paper sizes
I have an hp photosmart c4480 and was having the same problem printing wedding invitations. Same size 5.5"x8.5'. Im not sure if this will work on your printer, but this is what I had to do.
Click on Print, then Properties, then features. About half way down there is a drop down box under sizing options. Click on custom Create a name, and put your width and height in. Click Save and then OK Completely X out of the print options. Then Click File, print, properties,features, click the drop down box under sizing options. Click more and scroll to the bottom and it should be there.
If your options are different then mine, I'm sorry for wasting your time.
