Question about Sony KV-40XBR700 40" TV
TV not working
My Sony TV just became a 300lb boat anchor, When the power button is turned on the standgy led blinks about 7 times you hear a click then the led starts blinking 4 times. Any ideas on what to do or how to fix this. Thanks
  • fachu Jan 06, 2008
    I have the same problem but since it weighs 300 lbs I can't take it to a repair dealer.  Any idea how much this would cost me to repair?
  • Anonymous Mar 22, 2014
    Tv led blinks 3 times but tv does not come on. It makes a sound like its going to come on but it doesn't I would like to know what part is broken. I'll try to fix it.
    Scholar:
  • 168 Answers
The symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, video if,sound if, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician.
Posted on Jan 20, 2007
SOURCE:
Five red blinks in Sony LED TV KDL 40W900A.
5 red flashes is a bad panel connection or internal panel short, very carefully take the panel connectors off and reseat them and see if that helps, unfortunately you may have a bad panel.
Oct 14, 2017 | Sony Televison & Video
Problem with Sony FD Trinitron WEGA KV-32HS510 32" TV
Blinking of standby LEDs to Sony TVs are fault indications. Form the number of blinks occur at one time, the repairman can get an idea of the faulty stage inside it. According to you, it blinks 4,6 & 7. Just visit this site, It has details about blinking codes to Sony TVs, both CRT based, Flat panels and Plasmas. I can't provide more advice to you, because the number of blinks are not constant. Check the site, and get it.
Jan 22, 2013 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Red LED Light Blinks 7 Times Tv Wont Turn On PLEASE HELP!
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
You must have through knowledge in electronics to proceed. This is a very skilled wor. You must have all measuring instruments, and ability to follow its schematic diagram.
Jun 12, 2012 | Sony KV-36XBR400 36" TV
KV-36XBR400 won't turn on, "standby/stero" light
You are correct. You are right about the power supply and replacing with led hdtv. You will be happy with a Samsung led. Time to upgrade.
Mar 04, 2011 | Sony KV-36XBR400 36" TV
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a Sony Wega KV-34HS420 TV that takes several tries to turn on. When I push the power button or remote power on I hear the normal click and the sound comes on for 3-5 seconds but then I hear a second...
Since the set appears to "recover", it suggests either a poor solder connection or bad cap somewhere in the power supply. The 7 blinks indicate the problem circuit is in the horizontal area. Check the regulator (STRxxxx) IC in the power supply. If you do not have experience working with TVs, please refer this repair to a shop. The regulator IC costs around $25.
Dan
Nov 16, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Standby LED blinking 6 or 7 times and TV won't turn on
That is an error code that tells the tech where the problem lies. It is probably somewhere in the power supply stage. Your best bet is to take it to a TV repair shoppe and let them deal with it. They have all the documentation in order to repair the unit, and they can tell you what the problem is before they work on it.
Cheers
Jan 02, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Sony FD Trinitron WEGA KV 32FS120
Hiii...
I'm not certainly sure how many time the led blinking ?
I hope hear from tou soon...
Thank's
[Vrya]
be_cek@yahoo.com
Feb 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-40XBR700 40" TV Logo
226 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
