Question about HP Computers & Internet
My computers volume dose not want to work its been not working like this for over 4 moths can you help me please p.s. my computer mark is hp
    President:
  • 2,110 Answers
Try to Install Audio Driver ...U can download it from HP web site..
Posted on Nov 29, 2008
My hp 2009f desktop volume is not working
First check if you have mistakenly click mute on your media player or on volume control.
Is your Sound driver is updated? check if proper sound driver are install or not through Device manager of your computer. to do that right click my Computer----properties---Device manager------and see if there is any yellow question mark or if the device is disable.
If you find any yellow mark then i'll suggest you to download sound driver from the HP site and install it.
you can check your BIOS setting is on board sound option is Disable of not.
Aug 10, 2012 | Computers & Internet
Audio driver dose not working
if your computer came with a motherboard disk the sound drivers could be on it
click start control panel sounds and audio volume advanced speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question mark? right click to re-install drivers
if you dont have a motherboard disk you will need to download the sound drivers
if you need help with the driver download post a reply
hope this helps
Aug 09, 2011 | Computers & Internet
My speakers stopped working after i got virus and i removed all the virus with my k12 disk they gave me, but my speakers wont work, Help! Please!
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 11, 2011 | HP P5302M Computer Speakers
I just bought a computer and the first day the speaker was working fine and now i cant hear any volume i checked everything making sure its not in mute
the drivers might have been corrupted by something or you might have got a virus run your antivrus program and test for a virus then
you might have to uninstall then reinstall either the sound drivers or the sound card make sure you have both of these devices baked up to a disc before uninstalling
a yellow? question mark means you need to install/update driver right click to install driver
as for the sound
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 28, 2010 | HP (PP036AA) Computer Speakers
My aduio not work please send me about
if you mean that you cant get any sound on your computer
hope this helps
Nov 17, 2010 | HP Compaq for Presario V3000 Motherboard
What is the difference between a bug and an error
The first physically documented computer bug was documented by Dr. Grace Murray Hopper when she was programming the Mark II Calculator (computer). When the system was not functioning correctly after troubleshooting the system, she found a moth between contacts of a relay. After removing the moth the system functioned and the moth was taped in her notes documenting the bug.
A computer error is displayed when a known problem in the computer code (program) expects a result from the hardware (electronic circuit) or software, and it does not fall within the code parameters. In most cases the error can return information about why the computer had a problem.
Conclusion:
A bug is an unknown failure of the system which usually is intermittent and causes the system to crash or results in some type of failure. An error returns information about the system failure which is displayed or documented on the display or in log file.
Jul 02, 2010 | Contax Cameras
Pendrive not working
1. Click Start. Click Run. Type cmd and press OK.
2. Type "set DEVMGR_SHOW_DETAILS=1" (without quotation marks) and press Enter.
3. Type "set DEVMGR_SHOW_NONPRESENT_DEVICES=1" (without quotation marks) and Press Enter.
4. Type "start devmgmt.msc" (without quotation marks) and click press Enter. It should open Device Manager.
5. Click View. Click Show hidden devices.
6. Click "+" to expand "Storage Volumes" and right click on everything that is under Storage volumes. Also, expand Disc Drive and uninstall everything present under this apart from your Hard Disc (Please make u dont uninstall Hard Disc)
7. If there any unknown devices right click it and click Uninstall.
8. Reboot the computer.
If this does not work please let me know.
Thanks
Nov 14, 2008 | Transcend (589307) Media
Sound
Sounds to me like you are missing the drivers for the soundcard...the drivers are basiclly the software thatallows your computer to communicate with the hardware (in this case the soundcard).
What you can do is download the drivers and install them , which should get you your sound back!
You can download them here:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-45570-1&lc=en&dlc=en&cc=us&lang=en&os=228&product=3224049
Oct 02, 2008 | HP Pavilion dv9720us Notebook
My hp speakers dont work
dear sushiudon
plz check your speakers with another pc is it working there.plz post your findings
Apr 02, 2008 | HP P5302M Computer Speakers
Computers & Internet Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
