My nec nw-752 won't rinse and spin but will spin when i press spin only.can anyone help me.carolyn
ghost4548
  • 776 Answers
SOURCE: nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Posted on Jun 30, 2009
Sebin
  • 712 Answers
SOURCE: NEC washing machine model NW-891 can't get past
It is the problem of the board, which can be fixed, by a specialized mechanic. Contact a nearby mechanic with sufficient tools. Sometimes you will have to replace your board which will be expensive. In that case, if your unit is an old one, try to get an exchange.
Posted on Jul 05, 2010
mumma_1
  • 903 Answers
SOURCE: washing machine won't drain and spin after rinse
It sounds like you have a blocked pump. I have read that the pump is connected directly to the motor. You will need some tools at hand before you try to disconnect the pump from the motor.
Make sure that you disconnect the machine from the power supply. Tilt the machine back to access the pump from the bottom of the machine. It will be connected to the motor with clips. Have some towels ready to mop up the water.
I hope this works for you.
Posted on Jul 27, 2011
caroldon
  • 17130 Answers
SOURCE: My nec nw 752 is not working. It lost all power
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Aug 09, 2011
caroldon
  • 17130 Answers
SOURCE: My NEC NW-81R top loader when it turns on does not
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Thank you for using fixya.
Posted on Sep 24, 2011
I have a nec nw-691, when you put it on spin cycle it brings error message --lid open??? plz help
Yuo might try making sure it is still level but I'd just try using a lower spin speed. How have to use "gentle spin" when I wash towels or my washing machine has errors and stops. If still too damp just use a gentle spin only cycle once more to finish the job.
Apr 16, 2015 | Washing Machines
We have a NEC NW-752 top loader. It is currently not draining water. In fact just gets to the draining time in the cycle and just makes a slight buzzing noise as if it is trying to drain, but does not do...
Hi Wesley, it sounds as though the pump isn't working.
You may have cleared the filter and made sure the hose is clear, but the buzzing is a classic indication that either the pump motor is seized or something like a coin or an elastic band, which is hard to see, is preventing it from spinning.
The buzzing would also indicate that electricity is getting to the pump..
I would be surprised if the problem is not in the pump motor, either seized or jammed.
Unplug the power and take the inspection plate off the back.
Undo the screws holding the pump and check that there isn't more screws UNDER the machine. Use your camera to record your progress and a felt marker to make sure the housing goes back on the same as it was..
This is not a difficult job if you go slow and steady.
You may need to replace the pump motor. Usually a generic motor is OK. Check that the diameter is the same and that the sealing ring is in place. It will be a firm fit. I think NEC uses spade connections on their pumps. So be aware what type of contacts the motor has. The power wires can go on either way around. (Active or Neutral) If it has an Earth wire, it MUST go back where it was ..
Good luck
Cheers
Nomess
Jan 07, 2015 | Washing Machines
My NEC NW-81R top loader when it turns on does not make the usual introductory series of beeps and is stuck at a spin cycle but won't start. The only button that works is the power button...any...
Sep 24, 2011 | Washing Machines
My nec nw 752 is not working. It lost all power half way through a wash cycle. Can you please tell me why?
Aug 09, 2011 | Washing Machines
NEC washing machine model NW-891 can't get past the rinse cycle it just keeps on rinsing, emptying and rinsing again and again
Jul 05, 2010 | Washing Machines
I have just run a wash cycle and when it had finished the clothes were still very wet and water was laying in the bottom of the drum. I have tried to do a repeat wash but the machine will not work but...
You have most likely selected by mistake the no spin option coupled with extra rinse  - press again the rinse button to unselect that and put the spin speed at max.
Jan 16, 2010 | Hotpoint WMA50 Front Load Washer
Nec nw-891 washing machine will not complete the programmed cycle
Jun 30, 2009 | Washing Machines
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine nec nw-652
i am having the almost the same problem with what i have, if it is turn, the water will just keeping on pouring in non stop, it does matter wether it is wash, rinse, dry or spin the water will just keep on pouring in at all time, it is not a good machine at all.
Sep 09, 2007 | Washing Machines
Washing Machines Logo
146 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
