Question about Samsung HCL4715W 47" Rear Projection Television
Smeared color image
After the tv is on for about an hour or two the picture starts getting distorted at different places ( like water on oil paint)...slowly it gets worse all over the screen. then when i turn off the tv for about half hour and put it back again..it will run normally for another hour or two hours before the problem begins again. i called couple of repair places. one said color whell problem. othe said color processor problem is this the same problem as color convergance where a amp is required? if so where do i get it?
    Sergeant:
  • 308 Answers
Since this happens after the set warms up, I would check for bad solder connections or capacitors on the convergence board. If the problem was not readily apparent, then I would consider replacing the board, as I believe the replacement board has been upgraded from the original.
Posted on Jan 22, 2007
Need help fixing the picture on an older Samsung dlp tv
You need to replace your color wheel. Part# BP96-00674A. This has been a common problem with the samsung dlp's. I hope this helps.
Apr 23, 2016 | Samsung HLR4667W 46" DLP- DIGITAL LIGHT...
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
I'm having a problem with the color green being distorted on my TV. Is this a color tube issue, bulb issue, lamp issue?
This is a picture tube type TV. No lamp.
You don't describe the distortion.
A colour green picture that is twisted and shifted away from the other colours is a convergence problem. see Projection TV Convergence on this site.
If the green is smeared, out of focus, larger than the other colours like a halo around objects, things like that, it is the green picture tube. Sony has discontinued most of the picture tubes so you may not be able to get this fixed.
Mar 31, 2010 | Sony KP-46WT520 46" Rear Projection...
Pixeled picture, Red color, blurry and smeared images
Ghost image and snowy colorful pixelation with vertical black bars? You can try a hard reset by unplugging the unit completely for 4 hours. However you may have a prob with the YSUS and the YBU-L (YBuffer Upper-Lower.) Perhaps even the Logic Main may be defective. If you are still under warranty take it to a service center ASAP. If not Get out your Voltometer. You can email me for some help...
gysgt2u1@yahoo
May 08, 2009 | Philips Televison & Video
The picture on my 2 yr old Toshiba 42hm66 DLP tv starts flickering and with alot of rainbow looking distortion after an hour of veiwing. I replaced the lamp, but it sill has the probelm. Any idea what...
I hope this helps you but you might wanna look into some other posts too cause it goes farther then the lamps and color wheels. Basically it's a bad product and the consumer should be fixing it. But your problem seems to be the color wheel. Or just a good cleaning. We replaced the lamb in ours and still had a color problem. We're gonna do an exstensive cleaning and dusting of our unit and if it don't work. We're going straight to the manufactor. This is enough with this product! It's costly to repair and still don't have the quality picture it should. It's more then a simple fix and too costly for ppl to just fix and move on. For how old these products are this all should not be happening.
Dec 02, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Panasonic PT-52DL10 DLP TV
Color wheel bearing can make the noise you describe, and that will also cause color distortions.
Feb 15, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Plasma TV color problem
Sometimes, poor picture quality occurs when having activated an A-VHS camera or camcorder connected and having connected another peripheral at the same time. In this case switch off one of the other peripherals. Also, The norcent has a known problem with progressive scan - when connected to a progressive scan source, it yields a distorted screen with dual images and messed up colors.
Mar 22, 2006 | Norcent Technologies2703 27" TV
Samsung HCL4715W 47" Rear Projection Television Logo
78 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
