Question about Akai PT4799HD Rear Projection Television
WHY DOES MY TV TURN OFF BY ITSELF AND WON'T TURN ON FOR AWHILE?
MY TV TURNS OFF BY ITSELF AND WON'T TURN ON FOR AWHILE?
  • Akai Master
  • 5,138 Answers
There is 2 reasons for this poor solder on power AC board and a capacitor going bad. cap when failing will puff up on top.
Posted on Dec 22, 2008
4 Suggested Answers
  • 668 Answers
SOURCE: tv won turn on
This could be caused by a bad HV block. I would not take on replacing unless you know your way around HV circuits on Projection TV's. I would call a repair facility to give you a estimate to repair.
Posted on Jun 22, 2009
  • 80 Answers
SOURCE: My tv turns itself off while watching it after awhile
if it turns off and the timer light starts blinking you have a bad dm module, very expensive, it the light doesn't flash you have either bad front switches or something on the signal board, you can remove the speaker grill and disconnect both plugs and use your remote, this will disconnect the switches. if it still shuts off, you need baord repair, may be a bad solder connections, may be a chip/board needing replaced, you need a repairman and alot of money at that point.
Posted on Sep 15, 2009
  • 125 Answers
SOURCE: why does my tv turn off by itself
Bad capacitors on Deflection board cp114 cp120 cp150, they will be swollen.vented or puffed up on top
220uf 35v and 2200uf 16v use 25v
Posted on Apr 12, 2010
Why does my tv turn off by itself
Apr 05, 2010 | RCA HD52W59 HDTV Projection Television
The tv shuts off by itself. I will turn it on..and after awhile, it just turns off by itself, and then after about a minute I can turn it on again and watch tv for awhile, and then it will do it again.
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The faulty component(s) are heating up, tripping the fault control, and shutting down, it cools down again,and will restart, then the process repeats, it will eventually fail fully.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Mar 04, 2010 | Televison & Video
My akai dlp tv turns itself off then it flashes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Feb 17, 2010 | Akai LCT3201TD 32 in. LCD Television
Tv won turn on
Jun 22, 2009 | RCA P52926 52" Rear Projection Television
SCREEM TURN BLUE
The lamps inside of it are weakening, much like a fluorescent light burns out slowly...so get it into a reapir shop OR better yet, Call for an ESTIMATE or replace the whole thing.
May 23, 2009 | Sony KP-51WS500 51" Rear Projection...
Turns off randomly
mine does also does yours click at random times and the screen goes out in small places for a split second?
Apr 02, 2008 | JVC AV-32020 32" TV
Akai PT4799HD Rear Projection Television Logo
529 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
