Question about Maytag EPIC MFW9700S Front Load Washer
Maytag washer wont start spin cycle...
Once the spin cycle is supposed to start you can hear the motor humming like it is stuck please advise
  • Anonymous Dec 01, 2008
    I have the same problem. The water remained in the drum and did not spin. Today a repairman is coming out to check on the problem.
  • herbmorristo Dec 01, 2008
    Jr, I took the pump apart and found a nickel under the drainback flap ahead of the pump, easy fix thank you
  • 116 Answers
INSPECT YOUR PUMP HUMMING NOISE USUALLY PUMP MOTOR ARE PRETTY RELAIBLE
Posted on Nov 30, 2008
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Washer wont run but is trying to
check the motor for that, there may be smoething stuck ther. for the humming sound, when did this started happening? for the smell, check for frounded wire. for repeating each cycle, try to check for the housing if its still operational because the burnt smell and the cycle repeating is linked.
Mar 18, 2008 | Maytag PAV2300 Top Load Washer
Washer wont pump water unless in spin cycle
it is not supposed to pump water unless it is in the spin cycle. On most topload washers the motor turns one way for the agitate cycle and then the motor reverses during the spin/rinse cycle which in turn reverses the pump and causes it to pump the water out.
Oct 28, 2010 | Maytag PAV5157A Top Load Washer
I have a maytag washer (model -dependable care) and when we start the wash the motor just hums, the water does not fill, if we move the timer switch to rinse the motor engages and the unit works entire the...
Check your fill tubes remove the hoses and see if the filters are plugged, you are not hearing the motor humming. You are hearing the watervalve humming, the motor will not start until the tube is full of water.
Jul 16, 2009 | Maytag MDB6650A Built-in Dishwasher
Humming or buzzing during wash and spin cycles.
it's the motor that makes the humming sound..it may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
Jun 20, 2009 | Maytag PAV2300 Top Load Washer
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
Motor Hums on Top Load Maytag Washer
Hi, this is gil1714 in Scotland. Motor not starting properly, and humming. this machine has an induction
motor which has a starter capacitor on the side(the cylinder shaped object). these age out, so try replacing
with one of the same rating (printed on it ??mu). if that doesn't solve the problem, check to see if anything
is partially jamming the drum, or if the machine is overloaded . the other possibility is that the coils in the
motor are starting to fail, which would entail replacing the complete motor. hope this is useful gil.
Dec 17, 2008 | Washing Machines
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Sounds like the motor or capacitor (next to the motor), the capacitor helps the motor to start, once running a switch inside the motor disconnects the capacitor from circuit.
Maytag EPIC MFW9700S Front Load Washer Logo
463 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
